#1 | |
Drain Plug Removal with Pics!
Here's where to find the elusive drain plugs on your TJ.
First, you need to remove all the carpet from the tub. Then you can find them easier. They are black rubber plugs, and may prove somewhat difficult to remove the first time. There are a total of six. The easiest way to remove them is to use needle-nose pliers and grab the buggers. Carefully though, if you don't grab enough rubber, you might tear them. Be sure to replace them securely, otherwise you may get water from the road leaking through. Locate the ones in each footwell. Driver: ![]() Passenger: ![]() Then there are two in the rear cargo area: ![]() And one on each rear fender. Only the passenger side is shown, but they are identical: ![]() Here's the cargo area all nice and clean! ![]() Any questions ask, or PM me.
2000 4dr XJ 2WD, 4.0L auto Gone, but not forgotten- 1998 TJ Sport Nightcrew #162 "i'd want a bottle of 12 year old scotch and a 24 pack of rubbers. i'll go places with a hard-on that most people wont go with a mechanized infantry batallion." |
#2 |
Demonic Jeep Freak!
I though everyone knew that.
#3 |
Vermonter
i would be interested in knowing the best place to drill new drain plugs directly behind the front seats because that is where all my water tends to pool.
#4 |
I just take a drill and put a 5/8" hole in the middle of where the water is pooling. Of course you have to look underneath first to make sure you don't drill through anything but the tub. My water pools differently depending on whether I park in the street or in the driveway because of how the jeep is tilted so there's no real science to it.
Villanova Wildcat! 2005 Wrangler Sport, 4.0L, 6spd 2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15 HP D30: Aussie Locker, D44: Eaton Elocker |
#5 |
Just violated my Parole
i have 2 in the rear passenger foot wells
#6 | |
Sorry to hijack 98TJguy, just adding a little something
behind the driver/passenger seats there is three channels on either side that lead directly to a plug. its not a rubber plug and if you remove it, it will be permanent. but i leave my carpets out and dont sit back there, and HATE the water pooling up so i took mine out. if you take a chizel start from the front of the vehicle direction and hammer into the oval plug. there is two tabs on each end underneath the jeep that will bend out when you hammer them out. the factory puts a protective coating, almost like putty, on the plug to keep water out, but it keeps it in. if you look at 98TJguy's pictures illustrating the front rubber plugs, you can see the plugs that are located at the bottoms of the channels. they are the same in the back. they come out very easy and i have had water to my hood and they drain MINT ![]()
"Run what ya brung and hope ya done brung enough" Quote:
#7 | |
Southern Pride
2006 Jeep Wrangler Rubicon |
#8 | ||
EXACTLY. i didnt take all of mine out, just the two behind my seats, but in the winter i put my carpets back in so maybe ill take them all out ![]()
#9 |
Southern Pride
These look close. Maybe a little too narrow.
2006 Jeep Wrangler Rubicon Last edited by Jason D; 04-23-2009 at 07:03 PM.. |
#10 | |
Or atleast I think I do. its been since the start of winter when I put my carpet back.
2004 TJ Rubicon........My build thread, My URE Vid www.vanc4x4.net All Who Drive Jeeps Are Not Jeepers - Willy 3:16 |
#11 |
Newer TJs may very well have them, spyder6 said he had them there as well. Us older TJ guys are not blessed with rear footwell drains and we get lovely pools of water instead
#12 |
And here I thought those plugs were so you could urinate while on long road trips.
#13 | |
Trust me, I considered it ![]()
#14 | |
yeah i think its 97-02/03? that have two rubber in front, two on the "bed" area and two on the wheel wells. but i believe newer models have plugs behind the seats and we are stuck with a permanent removal
#15 |
I hate it when water pools up on my wheel well.
Nothing to see here. Move along. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
