Quantcast DQ? #2 - does UL top fold inside jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > DQ? #2 - does UL top fold inside jeep
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-24-2005, 10:26 PM   #1
04-RUL
or layup on top of the back, like an old VW bug.
took it down, first time today, and it looked like a sleeping bag wadded up back there.
watched the video, and folded it best i could. that's a 2 person job.
and it's not really fair, that you guys did NOT tell me it's really a 2 peeps job to go back up.
wife wanted to go out to eat (duh) and i wanted to just come home and eat.
so guess what, she comes in cooks (microwave...) and i have to do top by myself.
like herding cats.
if you guys had told me, i would have bought her some McD's, and then made her help me put the roof up.
so it's all your fault, and none of mine, because i watched the stupid video, no matter how much i wanted to doze off.
04-RUL is offline   Reply With Quote
Old 03-24-2005, 10:38 PM   #2
ponq
DQ#3 what's a UL?
I figure your talking about some soft top.
I can put mine up by myself?
1997 2.5 5 speed with 111,111 miles
ponq is offline   Reply With Quote
Old 03-24-2005, 11:02 PM   #3
rhinoss
Are you refering to the soft top on the Unlimited? It does look like it's quite a bit more of a task than the standard TJ.
rhinoss is offline   Reply With Quote
Old 03-24-2005, 11:04 PM   #4
lokua
the trick to making it fold up neatly is to pull it down one bow at a time and shove all the material through the bow behind the backseat. if you do it carefully it should fit down most of the way. also i never have ppl help me put my top up. it takes me like 5 min to put it up or down and i take my time. with a little bit of practice u will get real good at it and u wont even want ppl to help u cuz its takes longer to explain the right way to do it than to just do it urself.
lokua
lokua is offline   Reply With Quote
Old 03-24-2005, 11:55 PM   #5
Rocky529
Jeep
Rocky529's Avatar
I got a regular TJ and it only takes me like 10 mins tops.. only because I don't want to scratch the windows.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 03-25-2005, 07:49 AM   #6
99TJSport
lokua
Amen to that. Whenver someone helps me they either screw it up and I have to fix it or it takes longer to explain than to do.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline   Reply With Quote
Old 03-25-2005, 09:54 AM   #7
ryndavd
takes time to learn ur routine. when i first got my jeep, took me a little while. but everytime i took the top down i learned an easier trick. be patient.
97 TJ
RE 4.5 SF/2"bl
Aussie locked front
33x12.5 MT Baja Claws
ryndavd is offline   Reply With Quote
Old 03-25-2005, 12:43 PM   #8
Mr. Joeboto
I have an 04 UL, too, and every time I put the top down it looks different. Don't worry about it 04-RUL; just throw the top back and enjoy the ride.
Mr. Joeboto is offline   Reply With Quote
Old 03-25-2005, 04:09 PM   #9
Gunner11
It get easier with time. I can get mine up and down with very little problem.
04 Silver Unlimited
RE 3.5 Standard
33X12.5x15 BFG AT KO
ProComp 1079
Air Force Jeep Club Member #8
Gunner11 is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
