Downstream O2 Sensor Problems - JeepForum.com
post #1 of 3 Old 05-29-2005, 07:38 PM Thread Starter
JeeperAbe
Well it all started yesterday morning when i found out that both O2 sensors needed to be replaced. THe dealership wanted 300 to install and i was like no. Came home and went to the parts place and got both O2 Sensors and put the front one in, no problems, then i went to the rear one and i got the old one out and went to put in the new one and it doesn't fit, the probe it to big to fit into the hole. So i go back to the parts place and thats the only one they have for it, so then i look at a universal one and same problem to big, the only one that looked like it would fit was one for a Jeep Cherokee. Have any of you had any problems with it not fitting. I think im going to go to the jeep dealership to see if they have the right one and if it will fit.
The one thing im starting to think is that the dealership we took the jeep to to get the cat replaced didn't have the right cat and didn't bother to order one and put a spare one they had around the shop on and just spliced the plug wit and O2 sensor that would fit. Im so pissed because they have screwed us over on every car weve owned. Needless to say we dont go there anymore. So what do you guys think i should do???
1997 Jeep Wrangler SE 2.5l 4 cylinder auto, Stock.
Mods to come: 2" Coil lift, 31 MTs, Bumpers, Lights, Skids
JeeperAbe is offline
post #2 of 3 Old 05-29-2005, 09:36 PM
igofshn
Locked @ both ends
igofshn's Avatar
Take that one back and get it from the dealer. It will be the same price. I had the same problem and just got it from the dealer.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 3 Old 05-29-2005, 09:56 PM Thread Starter
JeeperAbe
Ok thanks..i took the one back already so ill go over to the dealer this week sometime.
Driving Without downstream o2 sensor? SailorJerry TJ Wrangler Technical Forum 4 09-14-2012 01:47 AM
downstream O2 sensor is at it again...ideas? jasonsalyer TJ Wrangler Technical Forum 8 10-14-2009 08:30 PM
Downstream air injection tube... ntenc1 YJ Wrangler Technical Forum 1 07-30-2009 06:39 PM
Downstream O2 sensors causing pinging? adam728 TJ Wrangler Technical Forum 13 07-17-2009 01:16 PM
Upstream or Downstream Oxygen Sensors? BrettDez TJ Wrangler Technical Forum 4 05-28-2007 11:54 AM
