Double-JJ CA's for daily driver? CA input needed.
#16 | |
TITS
Awesome, then you have cleared up my decision on who I'm going with. Currie control arms it is.
#17 | |
Under Construction
Hell I've tried several times, and I can't write what I want to say so I'll just post a link to the thread: http://www.naxja.org/forum/showthread.php?t=978010 If no poly joint, or JJ, and the Clevite bushing can't handle the abuse of off roading, is the lesser of three evils a WJ bushing? Or is there another option? |
#18 |
Currie makes a kit to replace the front UCA bushings with Johnny Joints. http://www.currieenterprises.com/cestore/product.aspx?id=1277 |
#19 | |
Brake Wizard
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#20 | |
want it rite or rite now?
probably more due to the lift height with short arms, not the joints...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#21 |
#22 |
Vendor
I have to correct the misinformation being given here: Clevite bushings are very good for both street and offroad use, and last nearly forever. There are plenty of other bushings made for use as aftermarket replacements for OEM bushings that are garbage, and will give up or fall apart after just a few months or even weeks of use. If you use genuine "Clevite" (Tenneco) bushings, they last for years under heavy usage.
In my past life I used them from time to time on custom suspension setups. A couple of examples here: This Bronco has a rear triangulated 4 link, using large rod ends at one end of each link, and a Clevite bushing at the other. It's been changed 2 or 3 times throughout it's history, but the original bushings it was set up with are STILL in use today, after about 4 years or so. He competed in UROC, WE-Rock, and UROC Rockcross during that time. This is a recreational buggy, triangulated 4 links front and rear, using a Clevite bushing at one end of each link, and an RE flex joint at the other. It's been in the same configuration for about 5 years now, all on the original bushings and joints. ![]() Naturally, you can choose to use them or not, but please don't be caught up in the "it's OEM, so it must be inferior" mentality. That's the thinking that made polyurethane control arm bushings prevalent throughout the industry.
www.teraflex.biz TERAFLEX offers 50 + different JK suspension kits!! 2011 Catalog Link YOUTUBE 1-888-837-2359 ext 308 Joe j.thompson@teraflx.com |
#23 |
Savvy Off Road
![]() JJs both ends and I like the ride a lot in my 03.
Email me for the fastest response: gman@savvyoffroad.com Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD The ONLY place to get Savvy/Currie Lifts and parts! The best price and support! PM MrBlaine for Black Magic Brakes! http://www.savvyoffroad.com 2006 LJ Unlimited Black Hole 2005 LJ Test Mule 2003 TJ Project Unrolled 2003 TJ Project Click Here |
#24 | |
Brake Wizard
Clevite is also the OEM brand and the story I related about swapping out the bushings in the two week test came straight from a Jeep Suspension engineer. How would I even know to make that up?
#25 |
TITS
Guys, I've made up my mind about what arm I'm going with. Please let this thread die or close it in order to not get too off of the original topic. Again, thanks for EVERYONE'S input.
#26 |
Vendor
I never said you made anything up, I just wanted to state my experience with the bushings. I chose some non-Jeep examples because they've been used hard, offroad only, for a long time. I have plenty of Jeep examples as well, but generally they're dual-purpose rigs without the abuse those posted above have endured.
I apologize if I riled you up, as it appears I did--that was not my intent. I just wanted to offer a differing view and experience.
#27 | |
Brake Wizard
To add to that, you and I both know that if you droop your axles when you install arms with Clevite bushings in them and then tighten down the control arm bolts, that the bushings will fail in very short order because you've preloaded them one direction. Why is that?
#28 | |
Vendor
![]() The bushings perform well through a certain range of motion. If they're preloaded one direction, they'll exceed that range. If they're tightened while somewhere in the middle (ride height), then they only move (from center) half as far.
#29 | |
Under Construction
I'm learning valuable info! |
#30 |
Savvy Off Road
[QUOTE=TeraFlex;6371488]That's funny, I just made motor mounts a couple weeks ago for my project using Clevite bushings.
![]() QUOTE] I can wait to see that motor flex! ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
