Double Cardan Vs. Cv Drive Shaft - Page 3 - JeepForum.com
post #31 of 42 Old 09-30-2009, 09:15 PM
mike_dippert
mike_dippert's Avatar
Originally Posted by bean66 View Post
Is anyone making a drive shaft with a thompson coupling?
A shaft with two couplings one on each end would pretty much allow the transfercase vs differential to be at just about any angles...
Eliminating the need to install adjustable control arms etc.
if you can, go look at the size of a DC joint, now imagine that sticking out of your pinion...i'd want a skid plate for that... i'd rather just tilt my axle back w/ adj arms, it'd be cheaper in the long run.
i can see it being useful on the front where you want optimum pinion AND castor angles though.
mike_dippert is offline
post #32 of 42 Old 09-30-2009, 09:23 PM
mike_dippert
Originally Posted by NotURMailman View Post
I doubt it, I believe that is a fairly new design...
Looks like a high tech variation of a double cardan joint.
Probably pretty expensive!
Thompson Couplings Ltd
I'm tempted to email them asking about size and strength comparisons to a typical 1310 or 1350 DC joint. I highly doubt it would work in the front axle, for the torque rating we would need it, looks to complicated to make that small to fit in the knuckles.
this is a cool vid on it's operation. [yt]xgQgm3GwaFs[/yt] i'd buy one if i was rich.
post #33 of 42 Old 09-30-2009, 11:24 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
that is really cool. shows how driveline vibrations are caused and how we break u-joints when turning & hitting the gas too!
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #34 of 42 Old 10-01-2009, 12:38 AM
Border Dave
Got Sand?
Border Dave's Avatar
That really was an interesting video, but they didn't even attempt to compare the Thompson Coupling with a double cardan joint.
Border Dave is offline
post #35 of 42 Old 10-01-2009, 12:39 AM
billymac4511
So I had to go look at the TCVJ website tonight. (Awesome post though! What a great looking product...)
Found this:
V-Series
Constant velocity variable angle Joints - shaft angles to 40 degrees
Reduces energy loss by reducing friction, heat and vibration, especially in applications where motors and devices have angular misalignment as well as compound angular misalignment.
Applications
Steel and paper rolling mills
Diesel motors and pumps
Electric motors and pumps
Helicopter propeller shafts
Large industrial off-Road vehicles
Marine drive lines
Looks like they are all ready making them for off-road industrial applications. I'm assuming this means skidders, logging skids, ect. I like the setup, but it looks very complex... it would be a great upgrade if you could put a big boot over it to keep gunk out. I can just imagine a stone making it's way inside and destroying the guts to that thing.
Give it another year and I bet they will produce them in a size small enough for passenger vehicles... especially if they are as amazing as they claim to be... [almost] no friction when bent?... with everyone screaming about fuel economy, that's sure to get some kind of response!
billymac4511 is offline
post #36 of 42 Old 10-01-2009, 05:18 AM
mdm
Farm Wheeler
a rectangle is a square but a square isn't a rectangle...
Care to rethink this?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #37 of 42 Old 10-01-2009, 09:32 AM
bean66
Maybe he had dyslexic moment?
Probably meant:
A square is a rectangle but a rectangle isn't a square.
bean66 is offline
post #38 of 42 Old 10-01-2009, 09:42 AM
Unlimited04
Probably meant:
correction:
A square is always a rectangle, but a rectangle isn't always a square.
Useful Write-Ups:
Funny:
post #39 of 42 Old 10-01-2009, 08:23 PM
mike_dippert
correction:
Probably meant:
yeah, you guys know what i mean...
read what i mean, not what i type...
post #40 of 42 Old 06-27-2012, 03:44 PM
Indy
Indy's Avatar
So is a DC rebuildable just by replacing the ujoints?
I'm the only gay eskimo.
Indy is offline
post #41 of 42 Old 06-27-2012, 04:25 PM
ftgiles
As long as the fixed part of the centering ball is in good shape.
Stu has two write-ups...
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
http://www.stu-offroad.com/axle/driv...iveshaft-1.htm
ftgiles is offline
post #42 of 42 Old 06-27-2012, 05:09 PM
biffgnar
biffgnar's Avatar
Centering ball assembly replaceable as long as hasn't damaged post which may be what you mean. Just did my rear driveshaft last night actually.
Romney in 2020!
biffgnar is offline
Can you make a Double Cardan drive shaft? KJFactor YJ Wrangler Technical Forum 5 08-21-2009 05:46 PM
single cardan vs. double cardan u-joint? Adjustable track bar compatibility? Mr. Tarmac TJ Wrangler Technical Forum 1 03-03-2007 11:43 PM
Measuring for Double Cardan Drive Shaft dojohnso TJ Wrangler Technical Forum 5 01-04-2006 10:07 AM
Double cardan drive shafts? skenzer TJ Wrangler Technical Forum 4 08-15-2005 08:44 AM
Double cardan type drive shaft without SYE? Baas TJ Wrangler Technical Forum 18 09-03-2004 10:48 AM
