Double Cardan Vs. Cv Drive Shaft
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#16 | |
Farm Wheeler
Don't think so. Most in the Jeep community use the terms double cardan and CV to mean the same thing. They are really refering to the double cardan style shaft with two u-joints and a centering ball on the transfer case end and a single u-joint on the differential end.
Keep in mind that free advice can frequently be worth less than you pay for it. |
#17 |
____________________________________ 88YJ, SOA, 35s, locked FR. Wheeling Jeep. 99TJ, stock, 31s, Daily Driver Jeep. 03 Grand, GF's Daily Driver Jeep. |
#18 |
if i ever have to install another ds, i'm going with Cornay. i assume price has something to do with me not hearing much about them on any of the forums.
Cornay® - Welcome |
#19 | |
Farm Wheeler
#20 |
Like I said -- I didn't remember, had to go find that. Maybe they've stopped using them, as it was considered a weak point? I have no idea. Man, JK's been in production almost 4 years already. Yikes, time flies!
Pete
#21 |
Farm Wheeler
It was right after the JK hit the dealer lots that I was crawling around under one and I can barely remember what I had for dinner last night. Did I have dinner last night?
#22 | |
I believe the joint in the pictures you posted is called a Rzeppa joint. Both the Rzeppa joint and Double-Cardan joint are what I consider to be CV joints. Luke. |
#23 | |||
hodophobic
If you feel the need to jump on me about this, why don't you call them what they really are? Rzeppa and DC joints. Just calling it a CV might confuse somebody. Obviously the OP was confused about the difference. Double Cardan Joint ![]() Rzeppa Joint ![]() Tripod Joint ![]() Thompson Coupling [yt]Dh5C4e4exhM[/yt]
Bestop LJ Halftop for sale. Warm up the cabin faster in the winter! Jeepiki, the Wiki just for Jeeps You can't argue with ignorance. Quote:
#24 |
Do it right or not at all
![]() Join Date: Jan 2003
This is an old thread but since it has been revived, driveshaft expert Tom Wood considers a double-Cardan and a CV joint to be the same thing. His opinion is good enough for me and I'll continue to use the terms interchangeably.
In all of his technical writeups, Tom uses the two terms interchangeably and even places one in parenthesis following the other like where he says "The real benefit to a C. V. (double cardan) drive shaft is smoother operation at higher operating angles and longer life. The C.V. assembly works by intersecting the joint angles at the center pivot point and delivering a smooth rotational power flow or surface velocity through the drive line." at Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist on his Driveline Geometry 101 tech page. That above animation is cool but that's not the only form of CV joint, the driveshaft industry widely categorizes a double-Cardan (two u-joints with a centering joint) and many other types as a CV (constant velocity) style joints as well. ![]()
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#25 | |
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#26 | |
hodophobic
a rectangle is a square but a square isn't a rectangle.
but for the purposes of Jeepforum, and jeeps in general, CV and DC joints are the same object. but in the world of joints, they aren't always interchangable. hence TW using parenthesis to specify which CV joint he's talking about.
#27 | |
Straight Up Fool!
This is like DeJaVu...
They are all types of CV joints. Double cardan type CV joint - the kind most Jeeps use on the drive shafts, utilizing two U-joints RZeppa type CV joint - the "ball type" you usually see on front wheel drive imports Tripod style - a plunger type, resembles a three ended u-joint inside of a machined housing (sometimes also of FWD car axles) Birfield joint - another style of "ball type" CV joint, theses are the ones people are usually talking about when they refer to older Toyota front axle shafts So yes, a double cardan joint is a CV joint. But no, a CV joint isn't nescessarily a double cardan joint. So you can't ask if a DC joint or a CV joint is better. That's like asking "Which is better - oil or lubricant?"! BTW - CV joint means constant velocity joint, meaning that it theoratically does not change speed as it rotates through it's range of motion when operated at an angle...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#28 |
^ great info man.
2000 Sahara TJ 1997 Limited ZJ |
#29 |
Is anyone making a drive shaft with a thompson coupling?
A shaft with two couplings one on each end would pretty much allow the transfercase vs differential to be at just about any angles... Eliminating the need to install adjustable control arms etc. Last edited by bean66; 09-30-2009 at 02:03 PM.. |
#30 | ||
Straight Up Fool!
Looks like a high tech variation of a double cardan joint. Probably pretty expensive!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
