Quantcast Double Cardan Vs. Cv Drive Shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Double Cardan Vs. Cv Drive Shaft
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-15-2009, 08:11 PM   #1
n8tmi
WHICH DRIVE SHAFT IS STRONGER FOR THE REAR OF 97' TJ? DOUBLE CARDAN STYLE OR A CV STYLE? TRYING TO DECIDE ON SYE STYLE. HACK AND TAP OR OTHER.
n8tmi is offline   Reply With Quote
Old 04-15-2009, 08:16 PM   #2
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Isn't it the same thing?
I would stay away from a hack and tap. Some may say that it's fine, but I just don't like the idea.
Personally I have the older JB supershort kit.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 04-15-2009, 08:42 PM   #3
CaleTJ99
Front drive shaft out of an xj, cheap, take it to a driveline shop, $80 for the shaft and to have it cut, your good to go.
Originally Posted by Solidkm View Post
and never monday we all know you invented 4 wheel drive, and you cold forged the S35 in the depths of moridor, but this is 44 vs 88. so when the next 35 thread comes up. you can play for that team:kiss:
CaleTJ99 is offline   Reply With Quote
Old 04-15-2009, 08:54 PM   #4
mike_dippert
hodophobic
mike_dippert's Avatar
constant velocity (CV) joint
works like this
a double cardan uses U-joints instead of that weird ball thingy those toyota ppl are so fond of (front axle)
Bestop LJ Halftop for sale. Warm up the cabin faster in the winter!
Jeepiki, the Wiki just for Jeeps
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is offline   Reply With Quote
Old 04-15-2009, 09:16 PM   #5
TJ311
They're basically the same thing. I think ONLY Double Cardan shafts are made for Jeeps. But I seriously wonder why a true CV shaft (ball type) isn't used or preferred in 4x4 applications. Serviceability maybe? Cost? I know it's not power reasons because I've seen some of those shafts handle 800HP or more. It just seems like they could handle some extreme angles.
Any thoughts on that?
TJ311 is offline   Reply With Quote
Old 04-15-2009, 11:22 PM   #6
Jeepster83
works like this
those are actually some very strong axles and can operate at some very steep angles. theres a company building axle shafts for TJ's now but i dont remember the name of the company.
a lot of people call the double Cardan drive shaft a CV shaft so when you bring up this subject most people will say they are the same. when you get to specifics they arent the same at all. dippert gave a perfect example of a cv shaft.
IMO id go with the SYE and double Cardan drive shaft. the hack and tap just seems like too much work for an inferior setup. i believe the new input shaft you get with the SYE kit is stronger than the stock one so the hack and tap job isnt as strong.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 04-15-2009, 11:26 PM   #7
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
http://www.longfieldsuperaxles.com/
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 04-16-2009, 12:09 AM   #8
mrblaine
Brake Wizard
mrblaine's Avatar
They can be built to handle the angles, but their typical failure is they can't handle the higher RPM's the driveshaft needs to turn. The driveshaft turns an average of 4 times faster than the wheels do. That's a big increase in surface feet per minute that the bearings get subjected to.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 04-16-2009, 06:45 AM   #9
n8tmi
Thanks So Much For The Input.
Old 04-16-2009, 01:20 PM   #10
Jeepster83
Originally Posted by ChiliPalmer View Post
thats the company. once i can afford a set of these ill be putting them on my axle.
Old 04-16-2009, 10:10 PM   #11
mike_dippert
hodophobic
FYI, once you upgrade the Ujoints on the front axle (by switching to longfields), the R&P become the next weakest link.
Old 04-16-2009, 10:26 PM   #12
Jeepster83
Superior ring and pinion will be part of my front axle upgrades
Old 09-30-2009, 07:38 AM   #13
billymac4511
I know this thread is a few months old, but I've been recently dealing with similar issues. I found a great writeup on pirate4x4.com
It explains not only how to do your universals, but also offers a disgustingly in-depth explanation so when you're done reading it, not only is your brain made of driveshaft goo, but you can replace/repair a driveshaft and/or joint while you are drunk, asleep and have your eyes closed. It will also teach you how to match up angles correctly and explain what Glidecote, Phasing and a Trunnion all are.
The four-part writeup is found here.
billymac4511 is offline   Reply With Quote
Old 09-30-2009, 08:09 AM   #14
PeteYJTJ
I'm not a JK guy, but don't JKs have CV joint (ball type) rear driveshafts, rather than ujoints? I thought I saw that somewhere.
Pete
____________________________________
88YJ, SOA, 35s, locked FR. Wheeling Jeep.
99TJ, stock, 31s, Daily Driver Jeep.
03 Grand, GF's Daily Driver Jeep.
PeteYJTJ is offline   Reply With Quote
Old 09-30-2009, 08:10 AM   #15
Unlimited04
Unlimited04's Avatar
read this: http://www.jeepforum.com/forum/f9/what-cv-shaft-why-do-i-want-one-854790/
Unlimited04 is offline   Reply With Quote
Glock Forum
