Double cardan drive shafts? - JeepForum.com
post #1 of 5 Old 08-14-2005, 05:07 PM Thread Starter
skenzer
skenzer's Avatar
I have a 2" lift.....this lift has caused some issues with my rear driveshaft angle. That being said....and yes....it really has caused some issues. I know, I was told that "you would have to be in a special club to have issues with a 2" lift and drive shaft angles"....well, I'm in a special club!
Now, I can either do a 1" t-case drop which would suck and I really don't want to do that..or...a friend mentioned the option of going with a double cardan drive shaft.
Anybody have any knowledge of these things? Will it help in my situation?
Thanks
2001 Cherokee Limited
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
Lot's more to do....
skenzer is offline
post #2 of 5 Old 08-14-2005, 05:10 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You'd also have to buy a SYE kit and adjustable length control arms for the rear axle to install a CV (double-Cardin) driveshaft which would be pretty expensive.
You're better off just installing a short t-case drop at this point. A half-inch of transfer case skidplate drop done with washers used as spacers around each of the six t-case skidplate bolts would do it for less than a buck.
Jerry Bransford is online now
post #3 of 5 Old 08-14-2005, 05:18 PM Thread Starter
skenzer
skenzer's Avatar
Thanks Jerry,
I have about 4 washers spaced in there now. :-) Maybe it's just not enough yet. I measured the drop at about 3/8". I'll add a couple of more and see how that goes.
I did notice a bit of an improvement though. Is it even possible that I acutally noticed an overall improvement in excelleration also?
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
skenzer is offline
post #4 of 5 Old 08-15-2005, 08:20 AM
Mudinyeri
Mudinyeri's Avatar
If your driveshaft was binding before the additional drop, yes you would see an improvement in acceleration. Even if it wasn't binding, you might see a little bit of improvement just with the more efficient DS angle. You probably wouldn't notice that though. My acceleration varies about that much just with changes in the atmospheric pressure!
Great minds discuss ideas; Average minds discuss events; Small minds discuss people.
Eleanor Roosevelt
Mudinyeri is offline
post #5 of 5 Old 08-15-2005, 08:44 AM
Jeepin' Rock Cl
As an alternative, you could always go with a 1" body lift and 1" motor mount lift.
Jeepin' Rock Cl is offline
Double Cardan Vs. Cv Drive Shaft n8tmi TJ Wrangler Technical Forum 41 06-27-2012 05:09 PM
Can you make a Double Cardan drive shaft? KJFactor YJ Wrangler Technical Forum 5 08-21-2009 05:46 PM
single cardan vs. double cardan u-joint? Adjustable track bar compatibility? Mr. Tarmac TJ Wrangler Technical Forum 1 03-03-2007 11:43 PM
Measuring for Double Cardan Drive Shaft dojohnso TJ Wrangler Technical Forum 5 01-04-2006 10:07 AM
Double cardan type drive shaft without SYE? Baas TJ Wrangler Technical Forum 18 09-03-2004 10:48 AM
