#1 | |
Door Surrounds
Would door surrounds without the screw in knobs to hold it to the rollcage still work? I'm going to be using them with a bikini top and was just wondering about this. I was thinking that they would since the top will be held in place by the straps and windshied which would keep them from moving. Anyone had any experience with this?
#2 |
Viewer Discretion Advised
probably not all that well, but I suppose in theory they would work and you could get away with it in a pinch
#3 |
FWIW, I used zip ties to hold one side on at one point with no issues...
2008 Jeep Sahara Unlimited Terraflex 4" 35's 5.13 |
#4 |
Admin, Jeep in Pieces
I don't use the screw in knobs anymore at all, and mine work fine.
My new cage does not follow the factory lines exactly, but I was able to get the door surrounds to fit, just no knobs/screw/whatever.
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
#5 |
Well someone on USJeeps just PMed me with some for $75 and I'm pretty sure it has all the hardware. I had another offer for $75 but it didn't have the hardware. I thought about the zipties and don't see why it wouldn't work temporarily but I'm just gonna go with the full set for $75.
#6 |
Zip ties are like 30 cents dude. You could also buy screws with eyelets on them for cheaper and use those. It's your call, I wouldn't pay $75 for the knobs when a few zipties will work just as good.
EDIT: Duh me. If you can buy the full set for $75 over an incomplete for $75. Get the full set! |
#7 | |
#8 |
Ha! I edited it before you posted! Nya.
#9 |
the way many roll cages look in the magazines, I dont know if even the doors will still fit after installing.
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks. |
#10 |
I dont see why Zip ties wouldn't work. This is how I roll with my bikini and the door surrounds.
http://www.links4jeeps.com/writeups/bikini/ |
#11 |
You can buy bolts and washers that fit instead of the knobs for only a few bucks. One of my knobs broke years ago, and I stopped using them then. I have to use a wrench to put them on or take them off, but that is only once in spring and once in fall respectively.
Jarhead Jeep Club O|||||||O 97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders. My Build Thread http://www.jeepforum.com/forum/f22/my-jeep-history-1997-present-1304114/#post12717920 |
#12 |
Which Bikini Top are you buying/do you have? The newer Bestop Bikinis come with velcro (hook & Loop) fasteners built in for use without door surrounds. See step 4 (without door surrounds) at this link: www.quadratec.com/Assets/Installation/35977.pdf
R.T. Many men can do what others cannot, and most of it is useless - John F. Gilbey 2006 TJ SE, Flame Red, Black Soft Top, 1/2 Doors, 6 speed manual trans, BFG ATs & Rock Crawler Black Steelies. Red Jeep Club Member #389 |
#13 |
I personally like the hook because it pulls nice and tight and gives you a flat edge so water can roll off opposed to the velcro where its a round edge and water can roll right into the cab.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
