Door surround bolts/screws stuck - JeepForum.com
post #1 of 6 Old 06-24-2010, 11:07 PM Thread Starter
Korvin
I was trying to remove my door surrounds today; however, the bolts/screws/whatever just did not want to budge.
The knobs on top seem to just spin and spin, but nothing loosens. I have shot PB blaster in through the bottom in an attempt to loosen it all up, but have not had any improvement.
Any ideas or experiences that I could benefit from?
I attached a picture of what I am refering too in case I just did the worst description in the world.
Thanks!
Korvin is offline
post #2 of 6 Old 06-24-2010, 11:12 PM
tomegood87
on the bottom side of the surround can you see the bolt unscrewing? Or the knob may not be locking to the bolt.
tomegood87 is offline
post #3 of 6 Old 06-25-2010, 07:57 AM Thread Starter
Korvin
Yeah, the screw is definitely not turning. I am pretty sure the knobs are just rotating on top of the screws.
I had the idea to pry off one of the knobs to see if I could just use vice-grips to turn the screws and all I ended up doing was snapping the knob in half. Thankfully super glue fixed that...lol.
So yeah, I am not sure how to approach this now. I figure I could drill/hammer out these suckers, but I don't see me being able to tap in new threads. Also, I wouldn't know what to screw in to hold the surrounds on at that point.
Korvin is offline
post #4 of 6 Old 06-25-2010, 09:11 AM
InfernoGirl
Your plastic knob has broken from the bolt... Some of mine are like that too... Just pull off the knob, and unscrew the bolt with some vice grips. I've epoxied my knobs back on, but it only holds for a while.... Some day I'll replace them. They don't have to be torqued down with much force, just enough to keep them from rattling....
Dirty Mudder seat covers/Steering column covers/spare tire covers
Like my Dirty Mudder FB fan page here:
01 Jeep Wrangler Sport 4.0L, auto
Mine
07 2D Rubicon Flame Red His
InfernoGirl is offline
post #5 of 6 Old 06-25-2010, 09:16 AM
chubbena
I would press hard or pull hard on the knob and turn to see if it helps.
chubbena is offline
post #6 of 6 Old 06-26-2010, 08:06 PM Thread Starter
Korvin
Ok. Mission Accomplished. Though not easily.
After drowning these things with PB blaster and nothing happening I decided to try the screw remover tool route.
It didnt work. Looking back, I probably had the hole drilled out too big on the top of the thing for the tool to grip, but also knowing what I do now....I dont think that would have worked still.
So, I went on with drilling out the whole thing. I chose a bit that fit the hole just right so it would drill out the sleeve and the bolt thing at the same time. It only took a bit of drilling to break the hold of the sleeve on the bolts so I was able to unscrew them instead of drilling out the entire length. Checking out what was left of the threads, it seemed those things almost bonded with the sleeves or something lol.
Anyways, my solution as to how to secure the front of the door surround/frame is that I grabbed a 4" 1/4 bolt, 2 washers, and a lock nut to replace each drilled out bolt.
Works great.
Korvin is offline
door , surround , bolt
door surround for a YJ? TJ mod? fsacb3 YJ Wrangler Technical Forum 6 03-08-2011 09:45 AM
Full Hard Door Hinge Screws Stuck ninjan8 TJ Wrangler Technical Forum 7 02-05-2010 11:38 AM
door surround bolts utlover JK Wrangler Technical Forum 6 01-25-2010 09:20 AM
Door surround bolts.. 4wheel4real TJ Wrangler Technical Forum 4 10-24-2007 03:39 PM
Door Surround Stuck yurmom22 TJ Wrangler Technical Forum 7 11-21-2003 07:19 PM
