Quantcast Door off Season, does yours do this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Door off Season, does yours do this?
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-16-2009, 12:00 PM   #1
prjohnson
I was wondering because I always see people talking about pulling the fuse when you take your doors off to keep the light from running the battery dead.
Well, whenever my doors are off, the light cuts off on its own after about 15 min of the Jeep being turned off. I was just wondering if anyone elses Jeep does this? I've never pulled the fuse.
prjohnson is online now   Reply With Quote
Old 03-16-2009, 12:05 PM   #2
jeadams
But are they on when the motor is running. Mine is this way. It really stupid looking when your driving at night.
jeadams is offline   Reply With Quote
Old 03-16-2009, 12:10 PM   #3
p-rev
haha. my buddy put this in for me and it works great
p-rev is offline   Reply With Quote
Old 03-16-2009, 12:20 PM   #4
roger24
I put in a similar switch and wire it the same way., AND put a new fuse in the power wire so the circuit is still fuse protected.
don't waste the money on the $30 kit sold by the big box online vendors. all it takes is about $5 for a switch and some wire.
RL
2003 TJ with 4.5" RELA, Rokmen full armor.
roger24 is offline   Reply With Quote
Old 03-16-2009, 01:30 PM   #5
Brew461
Uhhh....If I understand you correctly: I think you need to turn your interior light switch off?
Mine: 03 TJ
Hers: 01 XJ
Brew461 is offline   Reply With Quote
Old 03-16-2009, 01:34 PM   #6
DBLJ
DBLJ's Avatar
No its because his doors arnt there to hold the pins so the jeep thinks the doors are open and turns the lights on.
DBLJ is online now   Reply With Quote
Old 03-16-2009, 01:37 PM   #7
LJameson
All you have to do is pull fuse #4. Jeep engineers specifically put this feature on there for when you take the doors off.
2005 LJ- Mostly stock/ DD
2000 TJ- Slowly Rebuilding
1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti |
LJameson is offline   Reply With Quote
Old 03-16-2009, 01:38 PM   #8
wrangler2007
Take the #4 fuse off and then the dome switch turn off? I took the fuse out of mine and it works perfect...???
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 03-16-2009, 02:05 PM   #9
TheSherp
I was wondering about this as well. My light comes on for about 20 seconds and then goes out. I have the doors off now and with the jeep running they con't come on until I turn off the motor, then it comes on for the 20 seconds.
TheSherp is offline   Reply With Quote
Old 03-16-2009, 02:21 PM   #10
asa
asa's Avatar
How about just pulling the bulb? i know the fuse works if you take it out. My bulb is dead and havent replaced it in the two years Ive had the jeep
2000 Sahara
SYE,Rough Country 4" X series lift, Currie HD Steering, Solid Diff Covers,Rough Country Steering Stabilizer, Poison Spider Steering Box Skid, Skid Row oilpan skid, Brown Dog 1 Inch Motor Mount Lift, JKS 1.25 Body Lift, JKS Quicker Disconnects, Currie HD Tie Rod, Optima Red Top Battery, Garmin Nuvi 200W GPS
NJM#48
asa is offline   Reply With Quote
Old 03-16-2009, 03:53 PM   #11
Hailchief
Pull the fuse...the light will still work with the turn of the switch on the blinker handle....Turns off and on fine.
Yes if I leave my switch turned on (light on) the light will go off by itself after a few minutes.
CHIEF
Hailchief is offline   Reply With Quote
Old 03-16-2009, 10:30 PM   #12
Jblankster
yeah for me, after a while they turn off, and (i think) stay off till i press the little button that the door closes on.
i just got pins because i didnt want to bother with the fuse.
Originally Posted by vincec View Post
wow the way I hear it around JF if a jeep dose not have a Dana 44 it like driving a ticking time bomb planted right underneath your balls.
Originally Posted by WVUJeeper View Post
One of the biggest rules of fighting is: Never pick a fight with an older guy. If he's too old to fight, he'll just kill you.
Jblankster is offline   Reply With Quote
Old 03-17-2009, 01:18 AM   #13
crateampscal
crateampscal's Avatar
my cousin has these. they work great. the hell with pulling fuses.
http://www.quadratec.com/products/13029_100.htm
DONT LET YOUR MEATLOAF!!!
crateampscal is offline   Reply With Quote
Old 03-17-2009, 01:28 AM   #14
LJameson
I seriously don't understand why people are spending money on these. Is there something I'm missing here? I mean, it takes no longer then 20 seconds to pull the fuse on my Jeep.
Old 03-17-2009, 01:40 AM   #15
bebout
just pull the fuse and be done with it. the interior lights will still work when you rotate the dimmer switch to the on position. when you turn the ignition off the lights will automatically come on for about 15-20 sec. and go out. mine has been like that since i first took the doors off and that's been over 2 years ago with no problems.
bebout is offline   Reply With Quote
Glock Forum
