Door Lock Fell Out!!! - JeepForum.com
post #1 of 5 Old 09-10-2009, 03:15 PM Thread Starter
rdude5
so today as i got home from school i got outta the jeep and closed the door. I looked back and noticed that the whole cylinder for the lock had come almost completely out of the door. Has this ever happened to anyone? How do you fix this?
rdude5 is offline
post #2 of 5 Old 09-10-2009, 03:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's a push-on spring steel clip inside the door that goes on sideways to hold the lock in place. It sounds like that clip probably broke or somehow fell off. Removing the inner door panel gives complete access to it, look in the bottom of the door for the clip or its pieces.
Jerry Bransford is offline
post #3 of 5 Old 09-10-2009, 07:22 PM Thread Starter
rdude5
hey thanks for the advice. I took the panel off and sure enough there was the clip at the bottom of the door. Luckily it wasnt broken. Just put it back in place and works great!
rdude5 is offline
post #4 of 5 Old 09-10-2009, 08:19 PM
2004sahara
mine done the same...must be another jeep thing!
2004sahara is offline
post #5 of 5 Old 09-10-2009, 09:51 PM
Tick
Tick's Avatar
You have doors?
Tick is offline
Driver Door Lock Gets stuck in LOCK position WsRpAoNrGtLtEjR TJ Wrangler Technical Forum 24 02-05-2014 04:20 PM
door lock linkage open, door siezed closed Vladimer TJ Wrangler Technical Forum 5 10-04-2011 09:32 PM
Door Lock Won't Lock/Unlock from inside StevieO40oz TJ Wrangler Technical Forum 6 08-29-2009 10:09 AM
Door lock not working: How do I safely remove the door panel? mlawdawg TJ Wrangler Technical Forum 7 01-18-2009 10:59 AM
My upper soft door frame just fell apart JeepZJlover TJ Wrangler Technical Forum 5 08-01-2005 10:38 PM
