Door Lock Cylinder Interchange, Re-Key? - JeepForum.com
post #1 of 21 Old 01-13-2008, 12:33 PM Thread Starter
DusterRT
One of my door locks is buggared up from an attempted break in..the dealer wants $45 for one of those little suckers!
Anyone happen to know what the interchange is on these, and if a lock from a salvage yard can be re-keyed to match the rest? I've got an '06 if it matters. I would like to think something like that would be pretty universal across the various models..though most seem to have the locks integrated with the door handle these days.
Thanks for any input!!
Travis
DusterRT is offline
post #2 of 21 Old 01-13-2008, 03:28 PM
JEEP97TJ
bump for you
Blacksburg, VA
JEEP97TJ is offline
post #3 of 21 Old 01-13-2008, 04:00 PM
orangetj05
orangetj05's Avatar
you should be able to but the dealer will still have to rekey it
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
post #4 of 21 Old 01-13-2008, 04:30 PM
carpekd
I think the $45 wouldn't be that bad of a price...
carpekd is offline
post #5 of 21 Old 01-13-2008, 05:06 PM
.Jch.
.Jch.'s Avatar
I didn't think it was that bad either, considering for some dealers to make you a new key its like 85.
_____
l JEEP l
OllllllllO
2006 Unlimited
Black Jeep Club V2.0 Member #2006
.Jch. is offline
post #6 of 21 Old 01-13-2008, 05:52 PM Thread Starter
DusterRT
The dealer I went to said they come completely disassembled and they can't/won't key them so I'd have to go to a locksmith as well, likely doubling the price but I haven't checked. Maybe it's something I could tackle myself unless it requires specialized tooling.
As far as the price, I was thinking a pick-n-pull might not even charge for something that small (ie, snag it out of an unusable door since they'd probably want to sell a whole door rather than parts).
DusterRT is offline
post #7 of 21 Old 01-13-2008, 06:07 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Your dealer is retarded, find another one. I've taken removed lock cylinders into my dealer in Irvine several times to get them re-keyed because I'm helping someone swap on full or half doors.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 21 Old 01-13-2008, 06:59 PM
dz1087
dz1087's Avatar
I haven't looked at the type of locks the wranglers have but..,
If you can see the tumblers from the outside of the cylinder, then when you stick the key in, take a grinder like a dremel or something and grind down the tumblers that are sticking up. This forces the lock to mold to the key. Worked great with Toyota locks.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline
post #9 of 21 Old 01-13-2008, 07:02 PM
motobob13
Does anyone know if it is the same on the jeep tumblers? Heck I could probably even do that!
motobob13 is offline
post #10 of 21 Old 01-13-2008, 07:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
How do you know which one is the correct height to grind the others down to? And, what if one doesn't come up high enough?
I am Savvy
mrblaine is offline
post #11 of 21 Old 01-13-2008, 07:58 PM
HowIRoll
HowIRoll's Avatar
It is easy to pull the lock cylinders out, you could do it yourself in about an hour. I switched the doors from one jeep to another and swapped them out in the living room. Just take the panel off and it is pretty self explanatory, getting it re-keyed shouldn't be a big deal at all. hth
Check out my build thread:
http://longhornfabshop.com/
HowIRoll is offline
post #12 of 21 Old 01-13-2008, 08:17 PM
JEEP97TJ
When I bought my Jeep, the passenger side lock was messed up, what's it take to get the lock cylinder out, and to reinstall? Would by nice to be able to unlock that side rather than having to go through drivers side all the time.
Blacksburg, VA
JEEP97TJ is offline
post #13 of 21 Old 01-13-2008, 08:26 PM
gudoldboy
It doesnt matter if the pins dont come up high enough.. The ones that extend above the cylinder are the ones that matter... I worked in different stealership parts depts for years.. We swapped out pins all the time (no charge) and never worried about short pins..
Patriotguard.org Standing for those who stand for us...
Originally Posted by Keelentime View Post
just ordered my new bikini and bra....
Thank god this is a jeep forum, or that would have sounded a bit fruity :rofl:
gudoldboy is offline
post #14 of 21 Old 02-17-2008, 02:07 AM
TNG97
Put the key in and you will know which ones are too high...
Does anyone know what year they changed the GM style key (single side) to the double sided key?
TNG97 is offline
post #15 of 21 Old 02-17-2008, 08:47 AM
tsc
somewhere in 92 on the key change i think
tsc is offline
cylinder , door , lock
Driver Door Lock Gets stuck in LOCK position WsRpAoNrGtLtEjR TJ Wrangler Technical Forum 24 02-05-2014 04:20 PM
Door Lock Won't Lock/Unlock from inside StevieO40oz TJ Wrangler Technical Forum 6 08-29-2009 10:09 AM
Half Door Lock cylinder issues, help please JfirEfightErP TJ Wrangler Technical Forum 1 08-24-2009 03:46 PM
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
TJ half/full door interchange alancurtis2 TJ Wrangler Technical Forum 4 08-20-2007 02:13 PM
