door hitting window frame - JeepForum.com
post #1 of 4 Old 03-05-2005, 12:09 PM Thread Starter
db_17_85
Is there a way to adjust the door/windshield frame so that this stops. It is the top left side of the window. With the soft doors on it actually sits outside the windshield frame (resting on it). Any help would be great.
db_17_85 is offline
post #2 of 4 Old 03-05-2005, 11:42 PM
Sparty
Sparty's Avatar
soft doors...
can you bend them?
That was a last-resort suggestion on my full-soft doors.
Sparty is offline
post #3 of 4 Old 03-06-2005, 09:22 AM Thread Starter
db_17_85
the bottom half is hard, just the soft window half. Suppose I could try bending that part, but I have some hard top halves that do the same thing...no bending those...
Minot AFB, ND......where spring brings two wonderful gifts...dakrats and the stange sewage smell...
db_17_85 is offline
post #4 of 4 Old 03-06-2005, 12:07 PM
Dragonmaster
Dragonmaster's Avatar
the front hinge bolt for the bottom hinge and the door side on the top hinge have slotted holes, loosen the bolts, (requires mirror removal) and adjust.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
steel door window frame rot cwthom YJ Wrangler Technical Forum 1 09-01-2009 10:46 AM
Quarter window does not stay in door frame rideallday JK Wrangler Technical Forum 12 09-09-2008 04:05 PM
Full door window frame rust TwinSprings TJ Wrangler Technical Forum 14 11-02-2006 01:01 PM
98 TJ Steel Door Window Frame Cover RCRUA TJ Wrangler Technical Forum 3 06-20-2006 04:10 PM
How do you remove the upper door skins from the window frame? SteelBlueTJ TJ Wrangler Technical Forum 2 06-12-2005 09:43 AM
