Door Hinge Nuts Buried Into The Hinge - HELP!! - JeepForum.com
post #1 of 16 Old 05-04-2008, 07:50 AM Thread Starter
WindyCityGuy
I bought a 2004 TJ and the prior owner put normal nuts onto the hinge bolts and they were small enough to be pulled into the hole of the hinge itself so I cant get a wrench on them.
Any ideas on how to get the nut/bolt off??
WindyCityGuy is offline
post #2 of 16 Old 05-04-2008, 07:52 AM
Luckyduck
Do you have any pictures? would a thin socket work? If not get out the dremel (sp?) and cut a slit in it for a screw driver. I almost put regular screws in mine but they did not fit so I used the ones from my hard top
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #3 of 16 Old 05-04-2008, 07:58 AM Thread Starter
WindyCityGuy
I guess I could try to dremel/drill off the nuts. Are replacement nuts/bolts easy to find.
post #4 of 16 Old 05-04-2008, 07:32 PM
Luckyduck
I used the ones for my hard top but I also put on a light bar. If you want I think I can get you some Wednesday. I am going to the junkyard that day. Let me know if you want me to find you some.
CentralMass4wd.com
my build
post #5 of 16 Old 05-04-2008, 08:01 PM
rxl
rxl's Avatar
First time I took the doors off I threw the nuts away.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline
post #6 of 16 Old 05-04-2008, 08:06 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not possible. The pin for the upper hinge is the same diameter as the hole in the hinge. The shoulder on the upper hinge pin also stops just below the bottom of the lower hinge and any nut of any size put on the threaded part would bottom out against the shoulder.
Why don't you post up a pic so we can see what's really going on?
I'm guessing the door is stuck there's no nut at all.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 16 Old 05-04-2008, 09:19 PM Thread Starter
WindyCityGuy
Unfortunately maybe they swapped out nuts because its buried in there. will get some pics soon.
post #8 of 16 Old 05-04-2008, 09:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There is no in there to bury anything into. The hinge pin fills the hole completely.
I am Savvy
mrblaine is offline
post #9 of 16 Old 05-04-2008, 09:55 PM
charlescho
charlescho's Avatar
yeah a pic would be nice. its just a hollow tube all the way through...
but how are you going to get a picture of this??? good luck and ill be keeping an eye on this thread
ABC - A/Ox4 - SAMPLE - OPQRST
charlescho is offline
post #10 of 16 Old 05-04-2008, 09:56 PM
bctj
I believe he's talking about where the flat metal attaches to the body, not the hinge pin. The previous owner of my jeep did this with the windshield hinge light mount brackets. he put hex bolts on with too small of a head and no washers so the bolt head is not exposed enough to get a wrench on. I would suggest using easy outs.
bctj is offline
post #11 of 16 Old 05-04-2008, 11:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If that's the case, then take a socket and grind the end of it down to a taper that matches the countersink for the original flat head screws. It will then go on and let you remove the bolts.
I hope that's the case because I've mentioned the hinge pin and he neither clarified or refuted it.
I am Savvy
mrblaine is offline
post #12 of 16 Old 05-05-2008, 06:22 AM Thread Starter
WindyCityGuy
Picture coming.
post #13 of 16 Old 05-05-2008, 07:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Picture coming.
Is it the pin the door swings on, or the flat part that mounts to the side of the Jeep?
I am Savvy
mrblaine is offline
post #14 of 16 Old 05-05-2008, 08:19 AM
Luckyduck
I originally thought he meant the flat piece of metal. I highly doubt he means the sleeve. Lets see those pics!
CentralMass4wd.com
my build
post #15 of 16 Old 05-05-2008, 09:14 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What's confusing is the use of the singular "hole in the hinge itself" and not the plural "holes that mount the hinge" to the body.
I am Savvy
mrblaine is offline
TJ Wrangler Door Hinge Nuts - Thread? challosu TJ Wrangler Technical Forum 7 09-12-2009 10:05 AM
Passenger Door Hinge Nuts TedderX_ TJ Wrangler Technical Forum 14 04-02-2009 09:41 AM
Door Hinge nuts Green99Sport TJ Wrangler Technical Forum 36 01-05-2008 08:35 AM
Door hinge nuts cleanhull TJ Wrangler Technical Forum 10 10-28-2006 05:59 PM
Security door hinge nuts? ScratchMan TJ Wrangler Technical Forum 36 02-16-2005 06:33 PM
