Door bolt broke off - JeepForum.com
post #1 of 8 Old 04-16-2009, 12:18 PM Thread Starter
Napamike
Door bolt broke off
I broke off the head of the bolt that holds the door on. Anyone know of an online source where I can buy a replacement in same color (red)? I can't seem to locate any online. THanks in advance for your help.
Napamike is offline
post #2 of 8 Old 04-16-2009, 12:41 PM
uknowwho
RockAuto.com has the pins... Won't be painted to match though.
uknowwho is offline
post #3 of 8 Old 04-16-2009, 12:43 PM Thread Starter
Napamike
Door bolt
thanks- will check it out.
Napamike is offline
post #4 of 8 Old 06-19-2010, 09:05 PM
hodge44
I cant find them..
hodge44 is offline
post #5 of 8 Old 06-20-2010, 08:57 AM
Stinkbug
Stinkbug's Avatar
I don't have the pins but I have 2 red nuts... I had to modify my hinge pins to allow the doors to come off with the wilderness rack installed. You can have them if you want them.
Stinkbug is offline
post #6 of 8 Old 06-20-2010, 09:08 AM
vosevichs
I believe you have to buy 1/2 the hinge. On my 2001 the pin is not a seperate piece. I checked at the dealer.
Scott Vosevich
vosevichs is offline
post #7 of 8 Old 06-20-2010, 09:40 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I have a set of upper door side hinges that the bolt is connected to. If your broken one is the upper hinge send me a PM and I'll make you a deal on them.
xjfever is offline
post #8 of 8 Old 06-20-2010, 12:35 PM
hodge44
It is the lower bolt on the passenger door
hodge44 is offline
door , door hinge , door pin
Broke bolt head, then broke the extractor! HELP!!! EugeneTheTJ TJ Wrangler Technical Forum 11 08-22-2009 08:44 AM
Broke Bolt in Tub Pvt_Joker TJ Wrangler Technical Forum 9 07-07-2009 03:13 PM
Broke bolt for door hinge? UnsanePyro TJ Wrangler Technical Forum 2 04-16-2009 12:31 PM
D44 Cover Bolt Broke... What now? azcoyote TJ Wrangler Technical Forum 43 01-26-2007 05:45 PM
Door strap attachment piece broke off door, how to fix? trayson YJ Wrangler Technical Forum 3 05-04-2003 06:49 PM
