Quantcast Door adjustment...And an annoying rattle. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Door adjustment...And an annoying rattle.
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 10-04-2006, 08:23 PM   #1
MoJeeper
Does anybody know if there is a door adjustment. When I close my door the latch mechenism hits the striker but lifts the door up when it latches making a loud clunking noise.
As for the rattle, I have a LOUD annoying rattle behind the passenger side airbag. Anybody have any idea's on what it could be? It is is tinny noise like its metal against metal. Also how hard is it to remove the airbag so I can check behind it.
99 Green TJ SE
3" Full Traction Lift
4.88's, 33" MT's
My Jeep
MoJeeper is offline   Reply With Quote
Old 10-04-2006, 10:16 PM   #2
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
It's possible your doors are sagging a bit...possibly your door pins are getting a little worn?
As for the rattle...I probably wouldn't remove the air bag. Take out your glove box and see if you can detect anything behind or above it before taking apart your dash. A lot of times when you take apart a dash in any vehicle you create more rattles.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline   Reply With Quote
Glock Forum
