Quantcast Does socket extension on torque wrench change torque? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Does socket extension on torque wrench change torque?
Old 10-08-2008, 01:44 PM   #1
itasor
2009 JK Wrangler
I always torque my lug nuts to 100 ft. lbs. using a 1/2" drive click-stop torque wrench. I use a 1/2" drive 3/4" size deep impact socket on the torque wrench.
My TJ has the "Gambler" wheels. I think because they are 15x8 instead of 15x7 like the stock steel ones, the lug nuts are set farther in compared to the tire. This makes it hard to get the wrench on the lug nut without the handle scraping the tire, even with the deep socket.
I have a short (2-3") 1/2" drive socket extension that I was thinking about putting between the wrench and socket. Will this change the torque that I'm putting on the lug nuts?
It would definitely make torquing and retorquing a lot easier.
itasor is offline   Reply With Quote
Old 10-08-2008, 01:51 PM   #2
mdm
Farm Wheeler
Yes it will. But not enough to matter. With most extensions that short you would need a pretty sensitive scale to be able to measure the difference.
mdm is offline   Reply With Quote
Old 10-08-2008, 01:55 PM   #3
mudb8
want it rite or rite now?
mudb8's Avatar
yes an extension does change the torque. I forget what the calculation is to figure it out,
using a 2" extension on your wheels isn't realy anything to worry about. when ya start talking 6" then your looking at needing to make a setting adjustment.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 10-08-2008, 01:57 PM   #4
tangofox007
Are we talking about an extension bar or an extension that effectively changes the length of the wrench?
tangofox007 is offline   Reply With Quote
Old 10-08-2008, 02:14 PM   #5
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
In theory, the longer the extension the greater the deviation in torque error. But the error is marginal for our use.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Old 10-08-2008, 02:19 PM   #6
mdm
Farm Wheeler
Originally Posted by itasor View Post
… the lug nuts are set farther in compared to the tire. This makes it hard to get the wrench on the lug nut without the handle scraping the tire, even with the deep socket.
I have a short (2-3") 1/2" drive socket extension that I was thinking about putting between the wrench and socket...
Old 10-08-2008, 02:45 PM   #7
itasor
2009 JK Wrangler
An extension that is placed between the torque wrench and socket.
Old 10-08-2008, 02:59 PM   #8
tangofox007
In theory, that doesn't change the effective length of the wrench and won't change the torque applied. In practice, an extension bar does make it more likely that applied torque won't be perfectly tangential to the fastener, allowing for some error. In the case of lug nuts, which are not terribly torque critical, it's not worth even considering. The practice of making mathematical torque corrections applies to extensions, like a crow's foot, which effectively changes the working length of the wrench.
Old 10-08-2008, 05:08 PM   #9
grinwa
Maybe this will help. Torque is a rotating force and adding a socket extension will not change the torque. Only if you use and extension like in the picture will it change.
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline   Reply With Quote
Old 10-08-2008, 05:15 PM   #10
athos76
An extension (i.e. 90 degrees from face of torque wrench)... will not change the torque...
Grinwa hit the nail on the head...an adapter WILL change the torque... extended away from the face adds torque, extending toward the handle decreases torque.
As a Aircraft Mechanic, torque wrenches are a must have, and I've seen mechanics get their license yanked by the FAA for not knowing if an adapter changes torque.
2006 I6 6-Speed X, 33" Goodyear Duratrac, RC 3.25" lift, Windstar CAI, York OBA (in progress), custom corner guards (in progress)
Stupidity is NOT a crime... therefore you're free to go.
Support STU-OFFROAD NOW!!!
athos76 is offline   Reply With Quote
Old 10-08-2008, 05:24 PM   #11
Jeepsr4me19
1976 CJ5
never mind I found the answer
this old wives tale has been argued for years and no an extension will not change the torque value. It does not matter if the extension flexes you would simply pull the wrench farther. It is simple laws of physics, whatever force you input into one end of that extension is what is going to be exerted on the other end period. If you were getting less energy out of it than you put into it where on earth does that energy go? If the extension twists then as I said the wrench would require that much more input as long as it is moving but when the torque setting is reached and movement is stopped then at that point the input force and the resistance is equal and that is what it will read. Now if you allow the extension to lean over from the center of the fastener so that the wrench turning center is no longer centered over the fastener then you would get an erroneous reading because of the leverage factor, but this is something else entirely. For this same reason a crows foot extension must be compensated for and some wrenches include a chart for doing this but again this is for leverage because the wrench is not centered over the fastener. If an extension required compensation then they would include that also.
I only read the pictures.
Jeepsr4me19 is offline   Reply With Quote
Old 10-08-2008, 05:30 PM   #12
grinwa
Originally Posted by Jeepsr4me19 View Post
Is this true if the extension twist instead of the bolt or nut?
I had a extension twist in the middle during a high torque load. Bolt didnt move. 110 foot pounds
Yes. You are still applying the same rotational force. The weak link was the extension. I twisted a cheap 2" 3/8 drive extention with a small 3/8 drive ratchet and not much force. Just a weak/cheap extension.
'99 TJ
Old 10-08-2008, 05:39 PM   #13
Jeepsr4me19
1976 CJ5
I was a aircraft mech for 6 years and I sometimes get stupid from all those jet fumes.
Old 10-08-2008, 05:44 PM   #14
silvrjeepr
Stack about 6 feet of extensions on a bolt and see if it's just as easy to take off...
Originally Posted by mrblaine
No Lurch, why do you ask?
silvrjeepr is offline   Reply With Quote
Old 10-08-2008, 05:52 PM   #15
grinwa
That has nothing to do with torque applied through a shaft but the ability to hold on to something straight. Use counter torque and it will work. Who uses 6' of extensions anyway?
'99 TJ
Glock Forum
