07-06-2010, 02:14 PM
#1
Does my jeep have a lift on it?
My wife and I picked up this jeep a couple weeks ago as a toy and we have been wondering whether or not it has a lift on it. The lot that we purchased the jeep from had it listed as having a lift on it but im unsure if it does. I told the seller that I didnt think it was lifted and he swore up and down that it was. Personally i think that it is just the 32in tires that make it "look" lifted.
This is our first wrangler and we dont really have any jeep friends around to ask or compare. Basically i just dont want to purchase i lift kit if it already has one on it and me not knowing the height of whats on it.
thanks guys
-wes
ground to top of roll bar measures roughly 72inches
ground to bottom of stock front fender flare 36.5inches
ground to bottom of stock rear fender flare 37.5inches
ground to bottom of front headlight 34.5inches
ground to bottom of rear taillight 34.5iches
2008 WK...stock... XK/WK OWNERS GROUP #7
corn fed 2004 neon srt4
boosted 2004 s2000
07-06-2010, 02:16 PM
#2
Def lifted, prob a 2-3" lift. The shocks aren't stock but on a 97 that isn't a definite indicator.
Current: 2013 Jeep Wrangler Unlimited
Past: 2013 Jeep Grand Cherokee Laredo
1998 Jeep TJ SE
#3
SWAG
looks life maybeee a 2 inch lift to me, maybe 2.5 inches?
07-06-2010, 02:17 PM
#4
You wouldn't have that much clearance without some sort of lift with 32's.
I say it has a lift. Pictures of the suspension would help.
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
07-06-2010, 02:18 PM
#5
Keep Chopping
xwhatever. it has a lift.
can you post some close up pics of the shocks and springs?
#6
Snap a picture of the front coils.. If there is a thick piece of plastic between the body and the spring then it has a spacer lift, about 2 inches. There will be a smaller one, I believe 7/8 of an inch that is there from the factory, which is not a lift.
Anywho, Welcome to the family!
Originally Posted by mdm
Avoid "Hey guys! Watch this!" situations. They tend to have bad endings.
07-06-2010, 02:19 PM
#7
It'd be nice to see a pic of the front suspension, but I'd agree with the 2-3" lift. Probably a 3". Looks like you have a little more clearance with the 32's than I do with a 2.5" lift and 265/75-16s (~31.6").
07-06-2010, 02:22 PM
#8
SWAG
correct me if im wrong guys but its 19" from center of wheel to the flare... measure that, then subtract 19 from it and you'll get your lift height
#9
Yes, it is lifted. Look at your control arm angles... 32"s would rub with out a lift.
I recommend you use the search function to read over the hundreds of threads that ask the same question.
Here is a good thread for you to start on.
http://www.jeepforum.com/forum/f9/wh...ke-lift-46712/
There is lots of good information in the stickies that can help you as well. (Shows stock dimensions)
http://www.jeepforum.com/forum/f9/st...1/#post4118287
Here is a good one for you:
http://www.jeepforum.com/forum/f9/fa...7/#post6077636
Or just crawl under there and look for part names, or aftermarket parts. Compare what you see to pictures of stock Jeeps from the forums.
To Veterans past and present, thank you for your service! 99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
02 Toyota Celica GT-S-DD/beater
07-06-2010, 02:53 PM
#10
New to Jeeps but not new to rides and the forums or the search function. The search button is the first place I go.
The first link that you posted is one that i have been to often, but the majority of the pics are no longer there, the second on only shows stock specs. My jeep is stripped, diff tires, armor and bumpers, so it makes it a little more difficult to tell. I have never seen the 3rd link. using it as a guide tells me i have a 2in lift since my fronts compressed are 14in and my rears are 10in
none of the hardware has any manufactures names on them so that isnt any help.
trust me guys, ive searched
boosted 2004 s2000
07-06-2010, 02:55 PM
#11
SWAG
maybe springs from a rubicon?
07-06-2010, 02:57 PM
#12
Well are all of your control arms stock? From what I see it looks like they are.
You are most likely looking at 2-3" lift IMO. Your CA angle looks pretty similar to my 2.5" OME.
P.S. picks of FD?
07-06-2010, 02:59 PM
#13
yes, they are all stock.
-wes
boosted 2004 s2000
07-06-2010, 03:03 PM
#14
boosted 2004 s2000
07-06-2010, 03:05 PM
#15
No longer a Jerk....
looks like a 3 inch to me, looks good and congrats!
ΜΟΛΩΝ ΛΑΒΕ
Originally Posted by TheBoogieman
Jeepinmichguy is a jerk.
Originally Posted by mrblaine
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
