Does my 3 speed auto have a overdrive? - JeepForum.com
post #1 of 13 Old 04-12-2004, 06:33 PM Thread Starter
Scott B
I have a 99 tj with a 3 speed automatic and just wondering if it has an overdrive, at about 30 mph it shifts into drive, and at about 40 mph it shifts again and drops the rpms down. I don't think it has a overdrive but cofused what the shift is at 40.
Scott B is offline
post #2 of 13 Old 04-12-2004, 06:46 PM
airduds
airduds's Avatar
No overdrive. What you feel/see is the torque converter locking up.
airduds is offline
post #3 of 13 Old 04-12-2004, 06:49 PM
KaiserJeep
There is no overdrive in a 3-speed auto. However all modern Jeep automatics utilize a locking torque converter. When it locks it will indeed drop a few engine RPMs - the same amount as the converter slippage at that speed. Once locked, the exact 3rd gear ratio is in use, which in the case of the 3-speed TJ transmission is 1:1, but not overdrive. You are not the first to mistake this for another gear - and many Jeep owners never seem to notice this at all.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #4 of 13 Old 04-12-2004, 07:21 PM Thread Starter
Scott B
Hey thanks, that answered alot of my questions.
Scott B is offline
post #5 of 13 Old 04-12-2004, 09:39 PM
CobraKhan
CobraKhan's Avatar
I definately notice it. I wasn't sure what was causing it until now. But, I really notice it at 50 mph, I feel a little kick down in the rpm. Like said above, it is only a few hundred rpm though.
Does this only happen in third gear, or in all three gears?
97 Sahara, Black&Tan
Guinness for Strength!
Rear disc brakes, 33" BFG M/T on 15x8 Rock Crawlers, IPF H4 headlamps, 3.5" RE SF with all adjustable arms and trackbars, Flowmaster series 40 with Rusty's backpipe, Highlift...
CobraKhan is offline
post #6 of 13 Old 04-14-2004, 05:08 PM
KaiserJeep
Only in 3rd gear for '97-'02s or in 4th gear on the newer TJs.
Gary
post #7 of 13 Old 04-14-2004, 07:54 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
I noticed it day one in ours...but I DEFINITELY think there still needs to be another gear, PLUS the lockup...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #8 of 13 Old 10-31-2004, 07:07 AM
Gary Gill
Would this be true for my 98 TJ as well?
73 de N9ZYE Gary
One time owner of a 98 TJ Chili Pepper Red RJC #258
Gary Gill is offline
post #9 of 13 Old 10-31-2004, 08:14 AM
jessejames
2003 - first year for 4 speed automatics....that is why I bought an auto.
jessejames is offline
post #10 of 13 Old 10-31-2004, 08:50 AM
StealthTJ
Yes, '97's ~ 2002 all use the same 3 speed auto tranny.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #11 of 13 Old 10-31-2004, 10:56 AM
Gary Gill
Thanks for the info.
73 de N9ZYE Gary
post #12 of 13 Old 05-31-2005, 06:56 PM
FloridaJeeping
FloridaJeeping's Avatar
Damn, I just found this old thread and had been scratching my head for some time now... I have "counted" 4 gears over and over when I get my TJ up to highway speed and could have sworn it had a 4th or OD gear. Duh do I feel kinda dumb now. But this shows what a search will turn up.
98 TJ Sport
* The final weapon is the brain.
* All else is supplemental.
- John Steinbeck
FloridaJeeping is offline
post #13 of 13 Old 05-31-2005, 07:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'm sure that 30 years later, I still have friends that would swear in court my old Triumph TR-6 British-made 2-seat sportscar had an 8-speed manual transmission. It didn't of course but I could sure fool them into thinking it did with its electrically controlled 2-speed rear axle. To this day I don't know how that 2-speed rear axle worked but it was fun fooling my friends into thinking my TR-6 (kind of like an MG) had an 8 speed transmission by secretly shifting the axle back and forth via a turn-signal like lever on the steering column between High and Low as I shifted the 4-speed trannie.
Just goes to show that trannies and how many speeds they really have can fool the best of us.
Jerry Bransford is offline
auto overdrive too tall toastervet TJ Wrangler Technical Forum 22 10-21-2008 08:45 AM
Rubi's W/ 5 Speed vs Auto & Overdrive treehugger TJ Wrangler Technical Forum 3 12-31-2006 12:15 AM
Overdrive for the 3 spd auto? cspoffroad TJ Wrangler Technical Forum 5 08-16-2005 11:39 AM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 09:33 AM
