does a junkyard ECM have to be reprogrammed? - JeepForum.com
post #1 of 6 Old 02-21-2012, 10:08 AM Thread Starter
26679cj5
I have a 2000 TJ with auto and california emissions and was going to order a replacement ECM from a junkyard, but the guy i talked to told me I needed to call a dealership and see if the part needs reprogrammed for my vin number. I called my local dealership and they said it does, but I'm confused because the ECM in my TJ right now is actually out of a Cherokee and it runs fine except that it is always showing the check engine light due to it not detecting the cherokee's electric fan relay(which keeps me from knowing when it is actually throwing a code i need to be concerned about).
26679cj5 is offline
post #2 of 6 Old 02-21-2012, 10:36 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
As you have found already, the correct part number ECM will run just fine without re-programming. If your state performs emissions testing and they inspect the ECM, the VIN programmed into the ECM will need to match your Jeep.
You can get the ECM re-flashed, but be aware that many Dealerships will refuse to do the job. There are a number of on-line and eBay sellers that will flash your VIN, and the current programming, into an ECM and send it to you.
CJ7-Tim is offline
post #3 of 6 Old 02-21-2012, 10:49 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I completely swapped my 97 TJ's ECM when I converted it from a manual transmission to an automatic transmission. The subsequent smog test here in California (probably the toughest in the nation) did not detect the different ECM or flag any VIN error.
Jerry Bransford is online now
post #4 of 6 Old 02-21-2012, 04:09 PM Thread Starter
26679cj5
I did some more research and found out that the 05 and 06 models do need to be vin matched for everything to work correctly, but previous models don't.
26679cj5 is offline
post #5 of 6 Old 02-21-2012, 07:29 PM
Jerry Bransford
Administrator
Good to know, I was very curious about that.
post #6 of 6 Old 02-22-2012, 04:54 AM
mike_dippert
mike_dippert's Avatar
Matched to what, exactly? The auto module is contained within the ECM, and I'm not aware of any other computers in the Jeep. Unless there's something in the gauge module, I've never heard of reprogramming those though.
I know 01-04 came with a variety of ECM's due to engine and mapping changes. I think 97-00 are more or less the same, but don't take my word on that.
mike_dippert is online now
Going to a Junkyard soon... wrangler2007 TJ Wrangler Technical Forum 18 01-03-2010 09:23 PM
So who in here has done the junkyard TBI? Vincedahl YJ Wrangler Technical Forum 6 01-29-2009 01:29 PM
Can the ECU be reprogrammed? AlexTJ TJ Wrangler Technical Forum 11 05-24-2008 01:58 PM
junkyard TravisR YJ Wrangler Technical Forum 11 03-29-2006 06:11 AM
Junkyard D44 MCanavan TJ Wrangler Technical Forum 22 02-07-2006 07:43 AM
