Does Higher octane Help? - JeepForum.com
post #1 of 22 Old 05-18-2007, 01:43 PM Thread Starter
IWantMyMTZ
I remember when I took a shop class some years ago the shop teacher was telling us that your engine is calibrated, and designed to run on the octane gas that your maual says to use. He said those that decide to "treat" their engine to a higher octane gas every once and a while are just wasting money and screwing their engines settings all up.
I see exactly what he means but just out of curiosity does anyone run higher octane and get better gas milage?? any difference? just wondering...
2005 Jeep Unlimited - 4.0L Auto.
Pretty much stock except for 31'' MTZ tires.
I have a 4 page wish list though.......
IWantMyMTZ is offline
post #2 of 22 Old 05-18-2007, 01:46 PM
Rocky529
Rocky529's Avatar
Your shop teacher was 100% correct. There are zero benefits in running a higher octane that what your engine is rated for.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 22 Old 05-18-2007, 01:46 PM
hoseclamp
hoseclamp's Avatar
If you don't need it it's a waste, save your money.
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline
post #4 of 22 Old 05-18-2007, 01:50 PM Thread Starter
IWantMyMTZ
just what i thought.....i was reading a thread a second ago about gasoline having enough detergent in it to clean out injectors to where you really dont need injector cleaner anymore. i got to thinking that maybe higher octane gas was better quality, cleaner, ect....
thanks for the input...
post #5 of 22 Old 05-18-2007, 01:52 PM
ROXN4LO
This is correct as far as engine performance goes. However, some brands of gasoline DO add specific detergent agents solely to their Premium gasolines. So, although the additional octane is not doing anything for the engine, the additional detergents are supposed to clean better than the cheaper (lower octane) gas they are left out of. If that's all marketing BS, I don't know.
2001 TJ Sport: 4.0L, NV3550, D30/D44, 35x12.50x15 Maxxis Trepadors on DC-1s, 4.56 gears, Cromoly shafts & ARBs F/R, Full Traction 3" Lift, 1.25" JKS BL, Jeeperman Tire-Carrier Rear Bumper, Jeeperman Receiver/Winch Front Bumper, B&M Shifter, Kilby Gastank Skid, TBT Steering Skid, Nth° OPS, TBT Rock Steps, SkidRow Radiator skid,, IPF H4 (Fatboys), KC 100W Driving SlimLites.
ROXN4LO is offline
post #6 of 22 Old 05-18-2007, 01:57 PM
GringoLoco
GringoLoco's Avatar
In some engines with carbon buildup, like mine, a higher octane rating will quiet some of the pinging at lower rpms. It isn't helping anything, just masking a problem. People notice this and think that they NEED the higher octane, when in fact they need to clean the carbon out of their engine. I'm just too lazy lately.....
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #7 of 22 Old 05-18-2007, 01:59 PM
tjones07
I heard running higher octane is bad for the jeep's engine, not just a waste of money. I forget where i saw this..any truth to it?
'99 Sahara 4.0
2.5in Rancho Lift, Rancho SS, 32in AT's, 1.5in wheel spacers, quick disconects, Warn front bumper, M8000 winch, 3/4in front coil spring spacers, SYE kit, Tom Wood's custom driveshaft, K&N, Hella lights, Winshield light brakets, CB/PA system.
jones
tjones07 is offline
post #8 of 22 Old 05-18-2007, 02:02 PM
Crashnburn80
Crashnburn80's Avatar
Most major brands such as Chevron (the best) use their detergents (Cheverons is Techron) in all grades of gasoline. Its the discount or cheap gasoline that you need to be weary of. Your gasoline should idealy meet 'Top Tier' requirements.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #9 of 22 Old 05-18-2007, 02:03 PM
sahara tj
I agree there is no reason for running a higher octane than you need to. One exception with mine was going up long hills it pinged like crazy running 87 octane. Switched to 89 octane and the pinging went away. 4.0, Auto, 3.73 gears, and 33" tires.
sahara tj is offline
post #10 of 22 Old 05-18-2007, 02:18 PM
edzakory
Higher octane is needed in engines with higher compression ratios to prevent pre-detonation or "knocking". An anti-knock agent is added to gasoline to increase octane. The agent does not improve MPG on engines not needing the additive.
If your engine knocks or is not running smoothly on the octane your owner's manual specifies, you may have the wrong heat range plug, i.e., too hot. Another reason, buildup on the valves, may cause pre-detonation. Since cleaning agents have been added to gasoline and tetra-ethyl lead is no longer used as an anti-knock agent, plug fouling and valve contamination are not as prevalent as it used to be.
edzakory is offline
post #11 of 22 Old 05-18-2007, 02:22 PM
EDGEY
EDGEY's Avatar
I heard the same thing, higher octane cleaner gas burns hotter doing more damage to your engine. Don't know how much truth there is to it.
R.I.P. - 2004 Black Jeep Wrangler Unlimited LJ - 4" Rough Country N2.0, 1"BL, 1.25" JKS BL/MML, 33x12.50 BFG ATs, RC 2.2 Stabilizer, SpyderTrax 1.25s, XRC Rock Sliders, Pocket Flares
2008 Black Jeep Wrangler Unlimited Rubicon - 3"BDS, 35x12.50 Mickey Thompson Baja MTZs, Mickey Thompson Sidebiters, Bushwacker Flat Flares, Smittybilt XRC Modular Bumper
EDGEY is offline
post #12 of 22 Old 05-18-2007, 02:48 PM
kenskis
I believe this is basicaly right
Gasoline contains a mix of hydrocarbons, and the amt of good burning octane C8H18 is where the octane rating comes from. It is necessary on engines with higher compression ratios. If your engine was designed with 87 in mind use it. 89 in an 87 engine can possibly do some good, but it will be so small (because your engine isn't meant for that) you will not notice a difference, and you're throwing your $ at big oil. If you engine is kocking on 87; 89 is a tempoarary fix, not a permanant solution. I'm not sure exactly how modern electronics factor into this basic idea.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #13 of 22 Old 05-18-2007, 03:17 PM
92blazn
92blazn's Avatar
2010 JK Wrangler
Sorry but have to jump in say HELLLLLLLLLLLLL NO
if you drive a Z06, Viper, Supercharge Stang then yes
What gets me fired up is , these damn dealers tellyou put in the high octane in a normal engine WTF 5.3L Chevy motor dont need HI OCTANE
I worked with this one lady I got in a pissing match with cause she thought her 1.8L yota need the HI OCTANE , told her full of ship you money at $3.30 a gallon
sorry that just arrrrrrrrrrrrsssss me
2004 TJ (SOLD), 2010 4 Door 4x4 JK , 99 TJ , 99 WJ
Originally Posted by The Mean Fish
I'm not actually going for the wheeling, I just want to watch Ed drive his Jeep. :o
92blazn is offline
post #14 of 22 Old 05-18-2007, 03:36 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There's no truth whatsoever to that rumor. There is no additional "energy" in gasoline containing more octane than there is in a lower octane fuel so there's nothing to make it burn hotter.
Understand that octane is an additive and it's SOLE purpose is to increase the level to which it must be compressed before it detonates (from compression). So a high compression engine needs a gasoline with more octane so the engine's compression won't be enough to detonate the gasoline prematurely, i.e. before the spark plug is supposed to ignite the air-fuel mixture. Spark knock/detonation is just the fuel prematurely self-igniting from compression.
So if your engine runs without pinging with 87 octane, treating it to an occasional tank of 89 or 91 octane does nothing except make that sale more profitable to the dealer and manufacturer.
What can make an engine ping when it's running the recommended octane gasoline? Usually nothing more than a build-up of carbon inside the combustion chambers usually caused by not driving the engine aggressively enough. The built-up carbon continues to glow slightly after the last combustion stroke so during the next compression or combustion stroke, the glowing carbon can ignite the gasoline prematurely causing ping or knock.
And as said above, major brands of gasolines all contain basically the same amount of fuel injector cleaners and other additves. The amount of octane contained being the only real difference between their various octane levels of gasolines.
Getting
Jerry Bransford is offline
post #15 of 22 Old 05-18-2007, 03:37 PM
tj99
tj99's Avatar
True, higher octane gas also burns slower than lower octane. That's why it reduces the knock tendency. If your vehicle isn't designed for the octane with higher compression it will take more fuel to make the same heat / power.
Years ago I had an old 73 Plymouth 318 that I put a half a tank of Turbo Blue racing gas in. It was so expensive, about $2 a gallon that I could only afford a half a tank. Filled it up with premium the rest of the way. It got the worst mileage after that ever.
I just found this article, it explains it pretty good.
http://www.bajajusa.com/High%20Octane.htm
1998 2.5L 5Spd - Sold
1999 4.0L Auto - Mine
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
Can higher octane gas reduce NOx? White_YJ YJ Wrangler Technical Forum 17 01-21-2015 07:59 AM
Will higher octane gas benefit my jeep ? Xzero117 YJ Wrangler Technical Forum 10 08-13-2009 12:36 PM
lower octane at higher elevations? rouxbicon TJ Wrangler Technical Forum 3 08-12-2009 01:27 PM
93 Octane!!!! MilitaryJK4455 JK Wrangler Technical Forum 15 04-08-2009 07:57 AM
Gas Octane? adidas69 TJ Wrangler Technical Forum 5 11-26-2006 05:31 PM
