Does Height Of Spacer Effect Ride Quality? - JeepForum.com
post #1 of 6 Old 04-02-2011, 10:00 AM Thread Starter
applerock
Curious if the same spacer material and brand will ride different depending on whether it's a 1.5", 2", 2.25" or 2.5" spacer?
I would like to compare apple to apples here. Like comparable Poly, Delrin or Aluminum spacers, just different heights.
I'm also assuming the same (hydro) shock is used. Say a (the proper length) Skyjacker Hydro for an example.
applerock is offline
post #2 of 6 Old 04-02-2011, 11:13 AM
mrjeep03
i'm new to the jeep thing, but the jeep i got sagged in the front by a long ways, it has a heavy duty bumper and winch, i put on 1.75" spacers on top of the coils, just the fronts. i have noticed a smoother ride. the spacers are that hard black plastic, it raised the front and leveled the jeep...but i noticed that when backing up slowly the rear driveline seems like its binding, other than that, it seems ok...
mrjeep03 is offline
post #3 of 6 Old 04-02-2011, 11:44 AM
Imped
Imped's Avatar
Material doesn't matter. The higher you go, the higher the angle of the control arms, the smaller the wheelbase, and the more axle offset. If all you're doing is spacers and shocks, I wouldn't recommend going over 2" or so.
OlllllllO
IndyORV
Imped is offline
post #4 of 6 Old 04-03-2011, 09:24 AM Thread Starter
applerock
I measured (with 265/75/16 tires) that I have 3" from tire to fender flair in front and 4.5" in the rear. (stock)
Also put the jack under the bumpers and lifted to different heights to get an idea what my TJ would look like with different lifts.
Like the look (and lack of issues) of a 1.25-1.5" spacers in the rear, and 2" or 2.25" spacer's in the front. Figure that'll reduce my 1.5" difference to .75" between front/rear.
Original plan, this spring, after much research here, was to put on a 2" BDS lift/shock combo for around $390 shipped. However, do to recent financial "setbacks and obligations" I have reduced my budget. (at least for the time being) Found some Poly and Delrin spacers on a few ebay venders for pretty cheap, like $25 per pair. Figure I'll get some Skyjacker Hydros (with the rebate they've got going on) and for $155, I'll be all set. I have no issues now with steering, handling or lack-of-power with stock suspension/265/75/16 combo.
Would the 1,5"/2.25" combo be too much lift in the front?
Or would I be better off sticking to the 1.25"/2" combo?
I'm, not too concerned about the rear. Either 1.25" or 1.5" seems like it's work...with no issues between tires and springs and/or perches.
It's the front that concerns me a little more. 2.25" may be pushing it. Yes, no? Imped suggested 2" max. Does this still ring true after my description?
(Since some of you may ask) I may be considering (depending on $$$) a front bumper for next summer. The Besttop Highrock. That should lower the front a tad. I think it's like 80-85 lbs.
post #5 of 6 Old 04-03-2011, 10:04 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I ran the 2.25" spacers in the rear and 3" springs up front and it sat perfect.I had no vibe issues and needed nothing else, but longer shocks.I lift all my Jeeps 3/4" higher in the front and 1" higher if I have a heavy bumper or winch
TheBoogieman is offline
post #6 of 6 Old 04-03-2011, 10:10 AM
biffgnar
biffgnar's Avatar
I currently have 3" springs in front and 2" spacers in rear. I think it balances out well. I'll eventually swap those spacers for new springs in the back but expect to stick with the 1" difference. I don't have a lot of bumper weight upfront (Savvy) but do have a winch on the bumper and York under the hood which add weight.
Romney in 2020!
biffgnar is offline
lift , spacers
Do the coils have any effect on ride quality ? LMG23 TJ Wrangler Technical Forum 55 04-08-2010 11:30 PM
Ride Quality Moxzart TJ Wrangler Technical Forum 6 07-05-2007 10:15 PM
Effect of quality discos on road performance? STW TJ Wrangler Technical Forum 3 04-18-2007 09:33 PM
If shocks to short -what effect or ride? IAJack TJ Wrangler Technical Forum 4 11-30-2006 04:18 PM
Ride Quality jhaught4 TJ Wrangler Technical Forum 1 05-04-2004 01:58 PM
