does anyone know where to get cheap rocker guards that aren't diamond plated?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > does anyone know where to get cheap rocker guards that aren't diamond plated??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineParacord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.com
Unread 09-24-2008, 12:05 PM   #1
bortz1892
don't need rails or anything fancy....just want something so i can take off my stock running boards and not have it look stupid.
bortz1892 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 12:11 PM   #2
DixiesCJ3B
I really dont know about the rockers....but if you take off your stock side steps i think that it looks a ton better then when they are on...i took mine off and never looked back
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Build Thread
Are You An Offroad Junkie
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 12:21 PM   #3
Jeepster83
i wouldnt say theyre "cheap" but they werent expensive. fabtech 1/4" steel rocker guards - $260 from quardatec.
all the others i found were into the $300 range and they were only 3/16"
heres what they look like on my Jeep
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 12:22 PM   #4
bortz1892
$260 is rediculous for 2 straight pieces of 1/4 steel.
Unread 09-24-2008, 12:25 PM   #5
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Nothing is "cheap" unless you use plastic.Warn makes some for around $200.I got steel ones on ebay for $50,but they are diamond plate.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 12:25 PM   #6
BoarderX47
Here you go, free shipping too!
http://www.4wd.com/productdetails.as...9&partID=40449
BoarderX47 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 12:28 PM   #7
Jeepster83
you asked for non-diamond plated rocker guards - i delivered. if you can find a better price for what youre looking for, go for it.
Unread 09-24-2008, 12:42 PM   #8
TheBoogieman
Demonic Jeep Freak!
Cheap.
Unread 09-24-2008, 01:14 PM   #9
LittleBee
Here is side plates under $200. But they are all diamond plated.
http://www.jeep4x4center.com/warrior...rangler-tj.htm
"Too weird to live, too rare to die,"
LittleBee is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 01:32 PM   #10
flowrida2480
how bout these. look solid but you'll have to paint them yourself http://www.nates4x4.com/catalog/prod...products_id=53
1995 YJ
4.0L inline 6
5 speed Manual
All stock except 31" tires but not for long.....
[COLOR="Red"]Red Jeep Club #490[/COLOR]
flowrida2480 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 01:36 PM   #11
Jeepster83
those are more bling than protection. looks like the price is right, but it doesnt protect anything underneath and if you were to land on the slider with any weight on it at all it would rip the whole rocker apart. look for something with a little more protection under the tub if you do any wheeling. if you dont then get them, just dont expect them to do much in the way of protection.
Unread 09-24-2008, 02:49 PM   #12
TheBoogieman
Demonic Jeep Freak!
These?
If so,remove them and it will look better.I needed to cover scratches and no protection so I did this 2 years ago.
Unread 09-24-2008, 03:03 PM   #13
Imped
Imped's Avatar
I run Trail-Gear rocker guards without the step. They were $199 with free shipping from ebay. They are very solid, give great underbody coverage as well, and have already been well worth the price.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 04:20 PM   #14
willydigger
Olympic 4x4 1/8 inch rockers are $125 from Quadratec.
WHODEY
willydigger is offline   Reply With Quote Quick reply to this message
Unread 09-24-2008, 05:31 PM   #15
DEET
All you need is some angle from a steel supplier that is the height you want and an angle grinder with a cut off wheel. I bought two peices of 6"x5'x1/8" angle and cut the angles and the underside for bracket clearance and it worked great, I don't have a digital camera so no picks. If you don't mind donig a little shade tree fabrication you can save a ton of money.
Beer is proof that god loves us and wants us to be happy.
BLACK JEEP SOCIETY MEMBER
DEET is offline   Reply With Quote Quick reply to this message
