Do you for sure need Pinion Depth gauge when regearing? - JeepForum.com
post #1 of 15 Old 12-13-2012, 07:58 AM Thread Starter
Hella
Okay well long story short I bought all the stuff for a gear install and was going to do it at school with my teacher because they have all the tools and so on. Well now the teacher cant do it and im kinda stuck with 600 dollar paperweights. I have done a regear before on a chevy 10 bolt but once again that was at school with all the tools. I have rubi dana 44's oh and I need a case spreader too
04 TJ "Leyla" Rubi..
Hella is offline
post #2 of 15 Old 12-13-2012, 08:01 AM
rchase559
You don't really need a pinion depth gage, or at least I haven't yet. You can use the markings on the pinions and measure the current shim stack to get a decent starting point.
There are a few pictures on here and other sites of people building their own case spreaders as well.
rchase559 is offline
post #3 of 15 Old 12-13-2012, 08:05 AM Thread Starter
Hella
okay thanks, I really appreciate it, ill have to look into fabbing something up.
Hella is offline
post #4 of 15 Old 12-13-2012, 08:30 AM
freeskier93
You don't need a pinion depth gauge or case spreader. In fact, unless I was installing an ARB, I wouldn't use a case spreader if one was available to me.
freeskier93 is offline
post #5 of 15 Old 12-13-2012, 08:42 AM
Jason
X2. I did mine with neither tool and it's fine. I used the old depth and markings and calculated a starting point.
We're men! We don't need no stinkin directions!
Jason is offline
post #6 of 15 Old 12-13-2012, 08:51 AM
happymudder10
I did mine without a pinion depth gauge. I don't know if I was lucky or what, but I just re-used the old shims when I put everything back together and I had a perfect pattern. I think people over complicate the re-gearing process.
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #7 of 15 Old 12-13-2012, 08:55 AM Thread Starter
Hella
okay so on my pinion it is stamped 182 then below that is 2.625. So the installed depth should be 2.625? I guess im having a problem picturing what its supposed to look like when installed in the diff.
Hella is offline
post #8 of 15 Old 12-13-2012, 08:59 AM
mdm
Farm Wheeler
Even if you are starting with a bare housing with nothing to use as a starting point, you can start deep and work your way out fairly easily.
Dead blow hammers are a handy device.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #9 of 15 Old 12-13-2012, 08:59 AM
Griff1918
I'm going to follow. Cause I would like to know
Griff1918 is offline
post #10 of 15 Old 12-13-2012, 09:06 AM
freeskier93
The 2.625 should be nominal depth. This is only helpful if you know what the nominal depth is for the old and new pinion, plus the size of the old shim stack.
For example. If the old pinion was marked 2.620" and the new is 2.625", you need to remove .005" from the original shim stack.
post #11 of 15 Old 12-13-2012, 09:47 AM
Mboelts
Read this about 100 times then you can do yours:
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #12 of 15 Old 12-13-2012, 12:02 PM
Jonny Jeep
Jonny Jeep's Avatar
A pinion shim stack of 42 thousandths should be close enough to start on a D44.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #13 of 15 Old 11-13-2013, 05:03 PM
rikkards
rikkards's Avatar
sorry to resurrect this thread but I am about to do a regear with an arb. do I need a case spreader? from what I have read it would be a non issue on a normal Carrier but because of the air intake and the locker it needs to be super tight. has anyone done an arb without using a spreader?
Machete don't tweet
- Machete
rikkards is offline
post #14 of 15 Old 11-13-2013, 05:14 PM
freeskier93
From what I've read about ARBs preload issues are only prevalent on D30s because the housing flexes a lot. In an off road situation where the ARB is locked and the carrier is under a lot of load the carrier can deflect enough to cause a momentary leak. For other axles though a normal amount of preload should be fine.
post #15 of 15 Old 11-13-2013, 05:21 PM
rikkards
rikkards's Avatar
thanks for the quick response. did I mention that this was a HPD30.
so you think I need one?
I had heard the reason was that if the preload was not tight enough it could cause the air intake shim to spin
Looking into this more I think the ring spinning is a red herring or maybe that was something with the old model.
Machete don't tweet
- Machete
rikkards is offline
