Do you really need a new driveshaft for a TJ with 4 inches of Lift? - Page 4 - JeepForum.com
 1Likes
post #46 of 57 Old 06-06-2010, 08:15 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
nothing wrong with a t-case drop or MML.
vibes are the symptom of a problem.
that problem is u-joint binding.
a t-case drop or MML can put the output shaft in a better angle and reduce vibes...BUT...a u-joint's operational angle decreases the faster its rotating...so the t-case drop or MML may not fix the root problem = u-joint binding.
and these t-case drop or MML don't fix the driveshaft length problem....the more you lift it, the less spline engagement you'll get, especially when you start flexing and drooping the axle...and the u-joints bind even more with droop.
adding a tummy tuck adds lift seen by the t-case.
i've noticed differences in vibes with less than 1.5░ pinion/output misalignment on my single cardan shaft....and my shaft is longer than yours
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #47 of 57 Old 06-07-2010, 12:03 AM
IslandTJ
Originally Posted by Smitty98TJ View Post
I am about to get a lift kit for my 98 tj sport, i hear a lot that you have to get a new driveshaft with 4 inches and over of lift, is this true, i wont be doing much offroading, just a little bit of muding here and there.
I believe the threshold between spending some money compared to a lot of money with Jeeps, is 3+ inches - either in a suspension lift or when increasing a tire's diameter (starting form a baseline of 30"). FWIW, I run a 2" suspension lift and it works great with my particular build and the type of trails I run here in the Pacific Northwest.
Regarding drive shaft length and drive line angles:
For the most part, I think a simple 1" motor motor mount lift combined with a transfer case drop, ranging from 0-1.5" will work with Jeeps and suspension lifts less than 3 inches. Anything exceeding a 3" lift would benefit more from a SYE and complement driveshaft.
Now Jeeping in Oregon
IslandTJ is offline
post #48 of 57 Old 06-07-2010, 12:07 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A transfer case drop of 1.5" for a 3" suspension lift would be supremely stupid. There is simply no other way to explain completely negating the effect of your 3" lift.
Or put another way, if you raise your belly skid 1", that's the equivalent of putting on 2" larger in diameter tires. The inverse holds true as well. If you drop your belly 1.5", that's the same as putting on 3" smaller tires. HOW is that in the realm of smart?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #49 of 57 Old 06-07-2010, 12:17 AM
IslandTJ
It was a range not an absolute, dropping the transfer case from zero through 1.5 inches. Before I installed my MML, I had to drop my transfer case with 4 washers per bolt, I don't know the exact measurements of 4 washers but it may have been 0.25".
IslandTJ is offline
post #50 of 57 Old 06-07-2010, 12:19 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Mine was an absolute and you are incapable of convincing me to think or believe differently. Pure waste of time and money.
I am Savvy
mrblaine is offline
post #51 of 57 Old 06-07-2010, 12:37 AM
IslandTJ
Aloha mrblaine,
Not trying to convince you. Our Jeeps are not even in the same league or state and at one point in time, were on the same continent, I find it hard to believe you have owned or driven a stock unmodified Jeep longer than me. I am an old man, so I probably have less time than you and my pockets aren't deep enough to have a built rig like a majority of the Jeepers here, let alone you .
Malama pono .
IslandTJ is offline
post #52 of 57 Old 06-07-2010, 08:48 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Aloha mrblaine,
Malama pono .
My comments were not to be taken seriously by you. I'm more hoping that the cobble together folks take heed and perhaps re-think their budgets before they start slapping stuff together.
Funny thing about how folks judge what others know by how long they've been doing something. I make no bones at all about how long I've been doing this. I bought my first TJ in May of 99.
What most don't know is my wife and myself went to some place here in SoCal that required the use of 4 wheel drive every single day for an entire year going after work to some local places and then ranging further every weekend except for the weekends and week nights that I was working on it.
In that first year, I built and changed the rig for the tires I needed at the various times starting with 31's, then with 33's and then with 35's.
By the end of that year, we had been to Moab and Johnson Valley with all of our mods to keep going done along the way.
Jeep educations can be gathered up in many different ways. I sometimes wonder which directions I would have taken had I any access to anyone who could have shown me some shortcuts to save me from having to learn everything by myself through trial and error.
As far as comparing rigs, I suspect your is a bit more capable than our bone stock 04 on 31's.
I am Savvy
mrblaine is offline
post #53 of 57 Old 06-07-2010, 09:20 AM
IslandTJ
Ho`oponopono - it's all good mrblaine .
IslandTJ is offline
post #54 of 57 Old 06-08-2010, 09:42 PM Thread Starter
Smitty98TJ
Alright guys thanks for all the advice, i've got a steady job now so around the middle of August i'm getting a 3 inch Black Diamond suspension lift kit, with some steelies, and 33x12.50 BFG KM2's
Smitty98TJ is offline
post #55 of 57 Old 09-23-2015, 05:18 PM
jdpoissa
Looks Great!
Hello - your jeep looks great. Is this your daily driver. I have a 2001 that I want to lift....just need to make sure i get in the right stuff under budget. How do your tires wear on the street?
jdpoissa is offline
post #56 of 57 Old 09-23-2015, 09:16 PM
joe_jeep
Originally Posted by Cavitation View Post
I have an RC lift 2.5 inch springs, and 3/4 inch spacers.
I have 6 inches of up travel and way more droop.AL
So you have 14" travel shocks?
A 3" lift with that much travel would b a nice setup!
I would like to see pics of that.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #57 of 57 Old 09-23-2015, 09:28 PM
joe_jeep
does the Pope crap in woods?
umm, he was a Franciscan missionary, that lived in the Andes mountains.
he was a conservative, that pissed off alot powerful church people.
he was actually sent away from the mission, to live off the land for a couple years.
im pretty sure he pooped in the woods at some point!
though I doubt he has recently.
npr did a story about him today.
if you left him In the woods, with a crave case, im sure he would!
glfwda #6624
joe_jeep is offline
1998 , drive shaft , lift kits , offroad
best way to get about 4 inches of lift jf09 YJ Wrangler Technical Forum 25 11-10-2010 10:39 PM
2" Front coils lift, will it be 2 inches of lift? jfdavis17 JK Wrangler Technical Forum 2 11-15-2009 07:32 AM
lift inches? cruzjjcruz JK Wrangler Technical Forum 2 07-04-2007 07:39 AM
im looking to lift a 2006 unlimited 6 inches, which company makes the best lift kit?? lostatsea346 TJ Wrangler Technical Forum 4 11-09-2005 08:44 AM
2 more inches of lift baller88 TJ Wrangler Technical Forum 7 02-28-2005 08:21 PM
