Do you really need a new driveshaft for a TJ with 4 inches of Lift? - Page 3 - JeepForum.com
 1Likes
post #31 of 57 Old 06-06-2010, 06:07 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Originally Posted by Cavitation View Post
Before you install a TC drop try to run with out it. If you get vibes try 1/2 to 3/4 inches of washers. If that does not fix it get the SYE. I have an RC lift 2.5 inch springs and 3/4 inch spacers. 1/2 inch drop on the TC and it was fine. And by the way 2.2 shocks are ok in my book. I have 6 inches of up travel and way more droop.
AL
Try a MML,they work well to reduce or eliminate the t case drop with smaller lifts.
TheBoogieman is offline
post #32 of 57 Old 06-06-2010, 06:08 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
How about an MML instead.
That helps, but not enough with a 4" suspension lift...IMO
Knuckelhead is offline
post #33 of 57 Old 06-06-2010, 06:36 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What's wrong with doing it right?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #34 of 57 Old 06-06-2010, 06:48 PM
Knuckelhead
AFSOC Retired
Nothing at all, do it right the first time...
post #35 of 57 Old 06-06-2010, 06:55 PM
TheBoogieman
Deeply Disturbed
A MML is wrong.
post #36 of 57 Old 06-06-2010, 07:00 PM
Knuckelhead
AFSOC Retired
A MML is wrong.
It's not the full solution when using a 4" suspension lift...
post #37 of 57 Old 06-06-2010, 07:03 PM
TheBoogieman
Deeply Disturbed
I guess not blowing $1000 on a Vanco brake kit would be wrong also.
post #38 of 57 Old 06-06-2010, 07:12 PM
Knuckelhead
AFSOC Retired
Don't be an ***, there are many solutions for all situations...
My WJ conversion cost about $650...
post #39 of 57 Old 06-06-2010, 07:16 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What kind of skewed logic is that? If you buy a product like Van's brakes that are sorely needed on 99% of all TJ's on 35's, how is that blowing money?
I am Savvy
mrblaine is offline
post #40 of 57 Old 06-06-2010, 07:19 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
A MML is wrong.
My buddy left out of here yesterday on a 3" lifted TJ on 33's that has horrible take off vibes that continue pretty much throughout first gear and partially into second. Only at freeway speeds do them become tolerable.
You're telling me all I have to do is install a MML and the vibes will be gone?
I am Savvy
mrblaine is offline
post #41 of 57 Old 06-06-2010, 07:28 PM
Knuckelhead
AFSOC Retired
We both know that doing it right the first time pays off...
post #42 of 57 Old 06-06-2010, 08:00 PM
roundlitefan
roundlitefan's Avatar
Originally Posted by Knucklehead
I don't recommend or run a TC drop, it defeats the purpose...
Nobody will argue with what you are saying. A TC drop DOES defeat the purpose of a lift...kind of. Lets say it defeats the purpose of the lift if you plan on maximizing ground clearance for offroad.
Another purpose of a lift is to fit bigger tires. Like it or not, a lot of Jeeps are for cruising around and mall crawling....spending an extra $1000 to get rid of vibes on a Jeep that will never be driven off road is potentially a big waste of cash.
Nobody in their right mind will argue with doing something right. What can be argued though is building something to suit it's intended purpose if money is tight. The OP said it will not be driven offroad. My feeling is that this Jeep is being dressed up for cruising around town.....which is fine IMO. Telling him or her that they NEED to spend the money for a SYE, CV driveshaft, adjustable rear uppers, etc is not helping the OP in any way; and it is not honest. You are trying to convince the OP to build to fit YOUR needs, not necessarily with his or her best interest in mind.
If this Jeep is a street queen, the OP will be just fine with a 4" lift and a big TC drop that steals ground clearance.
Red91xj26 likes this.
roundlitefan is offline
post #43 of 57 Old 06-06-2010, 08:04 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Very well put.
Many on here are quick to jump in with advice for how they plan to use their jeep, and do not take the time to ask what the OP has in their plans.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #44 of 57 Old 06-06-2010, 09:05 PM
Cavitation
Boogieman, The plans are in for a MML and 1 inch BL then a flat skid and adj short arms and bumpers and winch. I am only starting with this disease. It has put my case of BRD on hold for a spell.
AL
Cavitation is offline
post #45 of 57 Old 06-06-2010, 09:10 PM
LuckRider
LuckRider's Avatar
If you are planning on a flat skid, there is no way around it, you will need a new drive shaft with adjustable arms and a slip yoke eliminator.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
1998 , drive shaft , lift kits , offroad
best way to get about 4 inches of lift jf09 YJ Wrangler Technical Forum 25 11-10-2010 11:39 PM
2" Front coils lift, will it be 2 inches of lift? jfdavis17 JK Wrangler Technical Forum 2 11-15-2009 08:32 AM
lift inches? cruzjjcruz JK Wrangler Technical Forum 2 07-04-2007 08:39 AM
im looking to lift a 2006 unlimited 6 inches, which company makes the best lift kit?? lostatsea346 TJ Wrangler Technical Forum 4 11-09-2005 09:44 AM
2 more inches of lift baller88 TJ Wrangler Technical Forum 7 02-28-2005 09:21 PM
