Do you really need a new driveshaft for a TJ with 4 inches of Lift? - Page 2 - JeepForum.com
 1Likes
post #16 of 57 Old 06-06-2010, 02:53 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Smitty98TJ View Post
So i take it that it is a good lift, just not the shocks. What shocks would be best? What brand would you guys suggest on a 2.5 or 3 inch lift?
i wouldn't run a RC lift if it was free, i'd sell it to Boogieman.
Look at OME, RCD, AEV or BDS for a 2.5-3" lift.
and do make sure you read this: http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #17 of 57 Old 06-06-2010, 02:54 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
How many RC lifts have you had?
TheBoogieman is offline
post #18 of 57 Old 06-06-2010, 02:57 PM Thread Starter
Smitty98TJ
Alright so would you suggest the 2.5 inch suspension with the 1.25 inch body lift and a 1 inch motor mount for a good set up for 33's?
Smitty98TJ is offline
post #19 of 57 Old 06-06-2010, 03:02 PM
TheBoogieman
Disturbed
Yes,that would work fine.
post #20 of 57 Old 06-06-2010, 03:03 PM
Unlimited04
zero, i buy stuff with good reviews
Useful Write-Ups:
Funny:
post #21 of 57 Old 06-06-2010, 03:04 PM
jeepmojo01
I am in high school so i'm trying to make my tj look good without spending to much money lol, just trying to spend enough for a lift, rims, and tires.
Good luck, we are all trying to make it look good and functional without spending too much money. With a 4" lift you better be ready to spend some cash to make it almost like driving stock again(without a TC drop). The PO of my 04 Rubi put a 3" BDS lift and a 2" BL(not my first choice) but I had to go with a Tom Woods driveshaft to get rid of my TC drop. Do some research on this topic....a new driveshaft is not the only thing that you need when you put on a 4" lift, if the kit you buy does not come with all the adjustable parts required to do the job correctly. Good luck with your build.
Yellow Jeep Club Member #2004
jeepmojo01 is offline
post #22 of 57 Old 06-06-2010, 04:19 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I am about to get a lift kit for my 98 tj sport, i hear a lot that you have to get a new driveshaft with 4 inches and over of lift, is this true, i wont be doing much offroading, just a little bit of muding here and there.
You'll need an SYE, DS and adjustable control arms to do it right...IMO
Knuckelhead is offline
post #23 of 57 Old 06-06-2010, 04:38 PM
roundlitefan
roundlitefan's Avatar
Every TJ is different for some unknown reason. I had a 2000 with a 4" lift that had no vibes ever, with only a TC drop. This is probably the exception rather than the rule though.
I would plan on needing a TC drop and a MML at a minimum for 4", or a SYE CV driveshaft and adjustable rear upper control arms at worst.
Why not consider a 2.5"-3" lift with a 1" BL? Gets you the same result with a lot less possible problems, and you might get away without messing with your rear driveshaft.
roundlitefan is offline
post #24 of 57 Old 06-06-2010, 04:45 PM
TheBoogieman
Disturbed
So you give reviews of products you've never used.
post #25 of 57 Old 06-06-2010, 04:52 PM
Unlimited04
i haven't given any reviews of RC stuff. I don't have to...theres plenty of other people that do that...
http://www.jeepforum.com/forum/f9/2-...er-mml-986652/
http://www.jeepforum.com/forum/f9/re...g-lift-786205/
http://www.jeepforum.com/forum/f9/rc...-about-952450/
http://www.jeepforum.com/forum/f9/pr...ft-kit-956262/
http://www.jeepforum.com/forum/f9/ne...y-ride-926909/
http://www.jeepforum.com/forum/f9/qu...hocks-1043951/
http://www.jeepforum.com/forum/f9/rc...-front-966304/
http://www.jeepforum.com/forum/f9/rc...doing-1039380/
http://www.jeepforum.com/forum/f9/ro...r-god-1046047/
have you run OME?
Useful Write-Ups:
Funny:
post #26 of 57 Old 06-06-2010, 04:55 PM
fang_x
I lifted mine 4 inches (suspension), and had no problems with the driveshaft's, the kit included a transfer-case drop of 1 inch though... we tested it without the transfer-case drop and felt vibes, added it and it was smooth again.
the kit had everything you need, except for bolts for the control arms.
was a skyjacker
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #27 of 57 Old 06-06-2010, 04:58 PM
Knuckelhead
AFSOC Retired
I don't recommend or run a TC drop, it defeats the purpose...
post #28 of 57 Old 06-06-2010, 05:03 PM
nikeo02
Going to agree. Installed a 4 inch Skyjacker, and with the TC drop, everything works fine.
nikeo02 is offline
post #29 of 57 Old 06-06-2010, 05:05 PM
Cavitation
Before you install a TC drop try to run with out it. If you get vibes try 1/2 to 3/4 inches of washers. If that does not fix it get the SYE. I have an RC lift 2.5 inch springs and 3/4 inch spacers. 1/2 inch drop on the TC and it was fine. And by the way 2.2 shocks are ok in my book. I have 6 inches of up travel and way more droop.
AL
Cavitation is offline
post #30 of 57 Old 06-06-2010, 05:06 PM
TheBoogieman
Disturbed
How about an MML instead.
1998 , drive shaft , lift kits , offroad
best way to get about 4 inches of lift jf09 YJ Wrangler Technical Forum 25 11-10-2010 10:39 PM
2" Front coils lift, will it be 2 inches of lift? jfdavis17 JK Wrangler Technical Forum 2 11-15-2009 07:32 AM
lift inches? cruzjjcruz JK Wrangler Technical Forum 2 07-04-2007 07:39 AM
im looking to lift a 2006 unlimited 6 inches, which company makes the best lift kit?? lostatsea346 TJ Wrangler Technical Forum 4 11-09-2005 08:44 AM
2 more inches of lift baller88 TJ Wrangler Technical Forum 7 02-28-2005 08:21 PM
