Do TJ's ride extremely rough on the highway with 6in+ lifts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Do TJ's ride extremely rough on the highway with 6in+ lifts?
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-19-2010, 09:23 AM   #1
drummerboy
I'm getting a new vehicle soon and I want a TJ lifted about 6 inches. My dad has a friend that used to deal TJ's and he said that if it's lifted like 6in+, then it's going to ride terribly on the highway and interstate. Is this true? Anyone had any experiences with this? I just want to know if this is true or not so I can show my dad and make an educated decision on how much to lift it.
drummerboy is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:41 AM   #2
VanBCguy
VanBCguy's Avatar
First question you should be asking yourself (is what I asked myself when I started to read this thread) is why on earth would you want and/or need a 6" plus lifted Jeep?
A VERY brief introduction answer to your question: no, they don't ALL ride "rough". #1 - define "rough" and #2 - some people actually take the time, effort and money to build a properly lifted rig (be it a Jeep, Toy, Ford, etc.) and do it right. But then some people (probably the majority) think that all there is to lifting a rig is tires, springs (leaf or coils) and shocks. There's so much more to it. SO much more.
My best suggestion to you? #1 - try to answer the first question posted above. Why 6" plus? Then #2 - research, research, research.
Let me give you a bit of perspective:
Choice #1:
Choice #2:
Now...not to say my Jeep (choice #2 pic) is anywhere near done or perfect yet, but which would you choose to drive a tough 4 wheel trail in? Choice 1 or choice 2?
Oh...and just so you know, I'm a 4.5" lift on 35's.
VanBCguy is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:45 AM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
With the right suspension installed, absolutely it will not ride stiffly. That means the right shock absorbers, the right control arms, and to a much lesser extent, the right springs. So when the suspension is set up properly with the right shocks and control arms, you can make a tall lift ride about the same as the factory suspension does.
That said, 6" is way too tall in my opinion for any Jeep with any tire size less than about 38". On a really tough trail, that much lift will create more problems than you will like.
What size tires do you want to run?
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:53 AM   #4
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if its a short arm, yea its going to ride & drive terrible at 6"+
2-3" is plenty for most people...4" is very common. 6"+ can be done right, you just need to learn about suspension geometry and what its going to take to do it. I'll guess $8,000-$10,000 or so by the time your done with SYE, tires, wheels, quality long arm kit, steering and brake upgrades, gears, junkyard HP axle for the front to get good caster & pinion angle...and then you're only going to be able to run 35s due to your axle strength, which you could have done on 4" of lift. Some of that you can do yourself, other stuff you'll have to have done at a shop.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:54 AM   #5
VanBCguy
VanBCguy's Avatar
Read the bolded area. Research that part. IMHO, I'd say 40's, but that's just opinion. But either way, 38's or 40's...those would be pigs on the road as a DD. Ugh.
And what Jerry describes in the above paragrapgh about suspension, springs, shocks...it's all so true. This is the area that I'm saying some people (probably most) think that lifting a rig doesn't entail all these factors. And what a person has to realize is that all these factors have to work in harmony with each other. You can't have one part that doesn't "speak" to the other.
Again, research, research, research. There's MANY build threads on here that detail what's being said here (Idaho Jeep, Spyder6, etc., etc.).
Unread 07-19-2010, 09:57 AM   #6
VanBCguy
VanBCguy's Avatar
2-3" is plenty for most people...4" is very common. 6"+ can be done right, you just need to learn about suspension geometry and what its going to take to do it. I'll guess $8,000-$10,000 or so by the time your done with SYE, tires, wheels, quality long arm kit, steering and brake upgrades, gears, HP axle for the front to get good caster & pinion angle. Some of that you can do yourself, other stuff you'll have to have done at a shop.
$8000-$10,000....I so want to live in the States! That would cost MINIMUM $15,000 here in Canada...for the cheapest of the cheap crap parts. With half of them being used off craigslist! Don't forget the new rear axle too. He'll probably be starting out with a D35 and want to upgrade that to at least a D44. That's more $$$.
To the OP: Don't get me (or anyone else here) wrong...a good lift of any size can be done. A lift of any size. But you have to ask yourself what you're lifting it to accomplish. Do you REALLY need 6" plus? IMO, no. My best suggestion to you is to research before throwing money at this project.
Unread 07-19-2010, 10:11 AM   #7
Unlimited04
ya.....i was being optimistic. it would probably cost $15,000+ here too.
Unread 07-19-2010, 10:15 AM   #8
Green4dr
i had a friend email me a month ago and he was gunna go the skyjacker 8'' short arm lift and 37s i was able to talk him down to the 4.5 long arm lift and 35s and he is plenty happy so just remember you dont need to be way up in the air just because it may look cool
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 10:19 AM   #9
drummerboy
So you guys would recommend running like a 4.5in and 35's rather than a 6in?
Unread 07-19-2010, 10:22 AM   #10
Unlimited04
first answer what you want to do with the Jeep. what tires do you NEED to run where you're going?
my suggestion - drive it and wheel it like it is for a year. save your money. then you'll know wtf you want.
Unread 07-19-2010, 10:22 AM   #11
Jerry Bransford
Administrator
Absolutely, that would be the perfect height for 35" tires. And any time I see someone ask about a 3.5, 4.5, or 5.5" lift height, I suspect they are thinking about a Rubicon Express lift. So if you are looking at a Rubicon Express 4.5" lift, their 4.5" lifts are really more like 5-5.5" in reality anyway.
Getting Savvy...
Unread 07-19-2010, 10:23 AM   #12
Imped
Imped's Avatar
Are you familiar with the geometric changes that occur when you go up? Even with 4.5" of lift, short arms will not be ideal IMO. The angles will be pretty steep, resulting in a higher instant center, higher antisquat, and rougher ride. If you don't get adjustable control arms, your wheelbase will be pulled in considerably. If you don't get adjustable track bars, the axle shift will be large too. Lastly, if you don't go with a fixed rear yoke and double cardan drive shaft, you'll need to address the vibes by dropping the skid plate and losing clearance. It's not just simple bolt-on and go man.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 10:24 AM   #13
mdm
Farm Wheeler
I think what people are doing is trying to get you to determine what you really need vs. what looks cool and indicating just how big an undertaking 6 inches of lift will be if you want to end up with a safe/usable rig.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 11:08 AM   #14
Apex
Recon death squad
Apex's Avatar
4.5" on short arms is liveable. I did it for about 8 months.
I would however recommend 3.5" suspension and 1" body. That will ride nicely and be plenty of room for 35" tires.
Apex is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 11:20 AM   #15
Boodyrider
With flat fenders and adjustable arms... 35s on 2" BB is also doable. Sure, clearances everywhere are tight, and wheel offset, bumpstops, trackbars, and limiting front steering is needed... but if tire size, ground clearance, and offroad capability are the issue... there is NO reason to go to stupidly tall lift for any tire size that can be driven on the road comfortably.
OP, also read up on low center of gravity (LCOG) builds.
and I absolutely second (fourth?) the suggestion that you drive it stock, maybe with better tires in a 30 or 31 height, for a year before you start building.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote Quick reply to this message
tj , wrangler , lift , suspension , rough , ride quality , highway
