Do rear coil springs have a top or bottom? - JeepForum.com
post #1 of 4 Old 07-17-2010, 01:49 AM Thread Starter
johnxjeep
When installing coil springs, does it matter which way is up ?
To me they look alike bottom and top.
Thanks.
The rear ones.
johnxjeep is offline
post #2 of 4 Old 07-17-2010, 06:35 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Either way is fine.
TheBoogieman is offline
post #3 of 4 Old 07-17-2010, 08:21 AM Thread Starter
johnxjeep
Sweet,
I put the rears on last night and I was concerned I put them on the wrong way.
post #4 of 4 Old 07-17-2010, 08:39 AM
superslayer
If its a progressive rate spring, yes, the end that has more pitch goes on the axle side. If its just a regular consistent spring, you're fine.
superslayer is offline
coil , spring , direction , rear
Need to 4 inch coil springs, front and rear pfifer TJ Wrangler Technical Forum 6 08-01-2009 03:31 PM
Is there a top or bottom to my rear coil springs? stangman68inftc TJ Wrangler Technical Forum 0 01-30-2009 05:05 PM
Rear Coil Springs zener6 TJ Wrangler Technical Forum 2 10-14-2008 01:03 PM
Rear Coil Springs Bhirst TJ Wrangler Technical Forum 11 03-14-2007 09:24 PM
Coil springs damaging rear shocks? flsar TJ Wrangler Technical Forum 1 09-08-2001 08:58 AM
