Do RE TT shocks work can up? - JeepForum.com
post #1 of 5 Old 01-14-2006, 03:05 PM Thread Starter
ScratchMan
I am installing the rear RXT2220 shocks and the can is about 1/8th " away from the spring perch when the axle and fully dropped and shock fully extended. Even though it is so close, it looks like it shouldnt really hit the perch. Will this be a problem? Thanks.
1999 TJ White
4.0L, 5spd, 3.73 Gear, Dana 30/44
31x10.5 Procomp MT, A to Z Fab rockers, Not stock bumpers
JKS Quick Disconnects, Body Damage!
ScratchMan is offline
post #2 of 5 Old 01-14-2006, 03:16 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've run other brands of twin-tube hydraulic shocks upside-down, I would imagine RE's can be run that way too.
Jerry Bransford is offline
post #3 of 5 Old 01-14-2006, 03:20 PM Thread Starter
ScratchMan
thanks.... now for the work of removing and reinstalling that pin and bushing in the other end of the shock without a vise!
1999 TJ White
post #4 of 5 Old 01-14-2006, 04:47 PM
Jerry Bransford
Administrator
That IS a chore without a vise, have fun!
post #5 of 5 Old 01-14-2006, 04:50 PM
MCanavan
Make sure you use white lithium grease. I have a smaller vise and couldn't push the pin in with the vice so I had to ream it through. Not fun.
MCanavan is offline
Everything you need to know about how Shocks work and why you need them...... Joe Dillard YJ Wrangler Technical Forum 24 03-30-2017 07:24 PM
will these shocks work?? 04 TJ-98 TJ mike68 TJ Wrangler Technical Forum 4 10-22-2008 09:37 PM
shocks no work... =( wranglerswrock YJ Wrangler Technical Forum 4 08-19-2007 04:32 PM
Will these shocks work? JeepnTXJ TJ Wrangler Technical Forum 4 10-03-2006 08:49 AM
Will my shocks work if..... Cidk TJ Wrangler Technical Forum 5 02-07-2004 12:33 PM
