Do I need a new axle shaft?? YOKE broke - JeepForum.com
post #1 of 10 Old 03-28-2013, 02:53 PM Thread Starter
SilverJeepTJ
So this winter I was wheeling prety hard and managed to break my front axle ujoints and the yoke is cracked now. Do i need new axle shafts or can i just replace the yokes? any recomendations?
Thanks again
SilverJeepTJ is offline
post #2 of 10 Old 03-28-2013, 02:58 PM
rchase559
The yoke and axle shaft is one piece. If the yoke is junk you will need the entire axle shaft
rchase559 is offline
post #3 of 10 Old 03-28-2013, 03:05 PM Thread Starter
SilverJeepTJ
thanks thats what i figured but i wanted to make sure before i spent the cash. so I should probably just get the chromoly shafts??
post #4 of 10 Old 03-28-2013, 04:37 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you can afford alloy chromolly inner & outer shafts, by all means go for them. www.superioraxlegear.com has them.
Hardened shafts will usually prevent u-joint breakages.
Jerry Bransford is offline
post #5 of 10 Old 03-29-2013, 06:03 PM Thread Starter
SilverJeepTJ
so another question, inner and outter? is that the two sides of the ujoint?
post #6 of 10 Old 03-29-2013, 06:15 PM Thread Starter
SilverJeepTJ
ok nevermind, got that figured out, should i stay with 27spline or go with 30? I know i will have to upgrade the diff, but is it worth the time and $?
post #7 of 10 Old 03-29-2013, 06:22 PM
Jerry Bransford
Administrator
You will absolutely (!) be fine with upgraded 27 spline hardened alloy shafts. That's what I upgraded my previous TJ to after breaking my passenger-side D30 inner axle shaft & the new shafts held up perfectly to some seriously difficult rock crawling with 35" tires & locker.
post #8 of 10 Old 03-29-2013, 07:25 PM
geiman
It would be nice to get superior shafts, but it seems as if they will never get their backlog issues fixed. I'd look at Ten Factory; I've yet to hear anything bad, and they seem to have been started by some very good people.
geiman is offline
post #9 of 10 Old 04-08-2013, 04:29 PM Thread Starter
SilverJeepTJ
Whats the option for a "Disconnect Eliminator" whats that all about?
post #10 of 10 Old 04-08-2013, 04:40 PM
Jerry Bransford
Administrator
I believe you're probably asking about something sold for '95 and older Wrangler YJ front axles that disconnected the passenger-side axle shaft from the differential. It isn't used on or needed for a '97 or newer TJ.
