Do I need longer brake lines??? - JeepForum.com
post #1 of 4 Old 10-24-2013, 09:03 PM Thread Starter
angelsfanbp
I have a 1" BL and am considering doing a 2" - 4" suspension lift. At what point do I need longer brake lines?
angelsfanbp is offline
post #2 of 4 Old 10-24-2013, 09:07 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i've got ~2-2.5" of lift and needed longer brake lines....
it's easy to check...hang the axle from the shocks (full droop). turn the wheel to the left and right all the way, check to see if the lines are taut. if they are, you need new lines...how long? use some string and measure....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 4 Old 10-24-2013, 09:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
For the rear? NIMO...
Knuckelhead is offline
post #4 of 4 Old 10-24-2013, 10:31 PM
Timmay82
I have a 2" lift up front and a 1" in the rear with 35" tires. I went with a 4" Russel Kit. My stock lines were maxing out with that much lift. Having it off the frame was ok but I also have a 7 inch stretch so a 4" Russel kit worked out front and rear.
Disclaimer: All opinions expressed, (or even assumed) under the JeepForum user name: Timmay82, are strictly that of somebody else. If you don't agree, feel that you have been attacked and as such your feelings are hurt by the above said user, than you may present any issues that you may or may not have with somebody else!
Timmay82 is offline
