Do I "have" to drop the transmission skidplate to change mount? - JeepForum.com
post #1 of 8 Old 02-02-2012, 06:07 PM Thread Starter
26679cj5
I've seen a couple how-to's on changing out the mount,but they both showed the skidplate/crossmember being dropped. I'm honestly afraid to try it,due to my frame being rusty in that area and worried about snapping bolts or breaking the nutserts. I'm wondering if I can just wiggle the mount out and another back in after I loosen the bolts for the mount.
26679cj5 is offline
post #2 of 8 Old 02-02-2012, 06:15 PM
freeskier93
No. The mount is bolted to the skid and transmission, it would be incredibly difficult to get it unbolted from the transmission without dropping the skid, probably impossible.
freeskier93 is online now
post #3 of 8 Old 02-02-2012, 06:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
It's doable, I can see an option...you could lift the whole body off the frame with a shop lift, then roll the frame out from under the body into a different bay. loosen the 4 bolts on the tranny mount, then use a hoist to remove the engine, tranny and t-case as one piece. then replace the tranny mount, and reassemble everything.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 8 Old 02-02-2012, 06:28 PM
RLWILLI
Originally Posted by unlimited04
it's doable, i can see an option...you could lift the whole body off the frame with a shop lift, then roll the frame out from under the body into a different bay. Loosen the 4 bolts on the tranny mount, then use a hoist to remove the engine, tranny and t-case as one piece. Then replace the tranny mount, and reassemble everything.
lol
RLWILLI is offline
post #5 of 8 Old 02-02-2012, 06:40 PM Thread Starter
26679cj5
ok so that's answered then lol
26679cj5 is offline
post #6 of 8 Old 02-02-2012, 06:49 PM
RaggedOleMan
It may be doable without dropping it, but I dropped mine. Here's a link to my thread on here when I changed mine; Tranny mount
RaggedOleMan is offline
post #7 of 8 Old 02-02-2012, 08:00 PM
ble10
I did it this past summer. Sure it sucked, but I didnt wanna mess with the nutserts.
ble10 is offline
post #8 of 8 Old 02-02-2012, 08:16 PM
hustler905
If your TC skid nutserts are that bad, you're going to have to address that issue sooner or later. I say go for it now. If you plan on them spinning and have spare parts and spare time ready to go, they will probably hold together indefinitely.
hustler905 is offline
"Manual transmission fluid change" bigdogdaddy TJ Wrangler Technical Forum 103 02-10-2014 09:03 AM
3" lift kit, with Nthdgree LP Transmission mount. Jeeprogue TJ Wrangler Technical Forum 1 11-01-2011 02:28 PM
Can I combine a 1" MML & UCF tranny drop mount? mystangt TJ Wrangler Technical Forum 16 02-15-2011 11:07 AM
Will getting a 2.5" RC suspension lift change anything driving or transmission wise? ksutulsacat TJ Wrangler Technical Forum 8 03-15-2010 03:16 PM
Will 1" Motor Mount affect TC drop? jeepramnauth TJ Wrangler Technical Forum 4 09-25-2008 10:28 AM
