Do I have to do a MML with Daystar 1" Body lift? - JeepForum.com
post #1 of 10 Old 04-06-2011, 01:22 PM Thread Starter
boilerup1998
Is it necessary to do a MML with just a 1" body lift? If so, which one should I get to go with the above?
Thanks
boilerup1998 is offline
post #2 of 10 Old 04-06-2011, 01:26 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
No you do not have to . I did a 1" MML and Bl on my YJ and TJ just so I could do a Belly up skid plate
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 10 Old 04-06-2011, 01:57 PM
stuntjumper
You don't have to but I would recommend it. If your currently mounts are in good shape (which they should be on a 2006) then just go with a JKS MML. If they are not in good shape, replace them with some Brown Dogs. I replaced mine with Brown Dogs and it was super easy.
_____________________________________________
'98 - 4.0 - HP30 Front, 8.8 Rear, 4.88 -1.25" BL, Brown Dog 1" MML, 3.5" RE springs and crappy shocks - 33" Goodyear Duratrac on Crager soft 8's 15x8 - Toys By Troy front roll cage and custom welded rear roll cage addition.
stuntjumper is offline
post #4 of 10 Old 04-06-2011, 02:56 PM
RockMonster
If you have the time and money i would recommend doing a mml, it will help a ton if you ever decide to further mod your jeep.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #5 of 10 Old 04-06-2011, 03:19 PM
mediumdaddy
You dont HAVE to, but it will make your life easier. you wont have to mess with transfer case linkage, or your radiator fan shroud. plus a MML will slightly improve your driveline angles and slightly help out with any vibes you may have. do you run any other lift?
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #6 of 10 Old 04-06-2011, 03:32 PM
MCDavis
I installed a 1" BL on my LJ and the only thing I did was move the fan shroud...didn't even have to mess with the tc linkage. MML is nice, but not necessary for the BL.
MCDavis is offline
post #7 of 10 Old 04-06-2011, 04:57 PM Thread Starter
boilerup1998
I'm just running a 2" Skyjacker BB. Currently on 31X10.5 MTR with stock 15" Ravines. Going to be going to 33X12.5s so I was looking for a little more clearance.
post #8 of 10 Old 08-19-2012, 12:19 PM
gmanlax06
I know this thread is old but I just ordered this exact set up for my '06 LJ.
2" skyjacker and 1" bl so i can fit 33's.
Did you have any issues? My buddy is trying to convince me that i need a mml and that i will have problems slipping out of 2nd gear and rev.
Thanks
gmanlax06 is offline
post #9 of 10 Old 08-19-2012, 02:31 PM
CrankyGypsy
the slipping would be caused by the shift lever against the floor console. i have the 1" Daystar BL, the JKS MML, and AEV TT - mine popped out of 1st from a stop twice and i could see my console also move when shifting into 3rd and 5th. after a few days of driving, i just pulled the shift boot and looked at the ring that held it in. where there was contact, i saw indentations - i just trimmed it out a little at a time until it didn't rub. without an MML or TT, you can unbolt the shifter shaft and put a slight bend in the shaft.
2004 Rubicon
2005 Grand Cherokee Limited HEMI (fully optioned)
2005 Yamaha AR230HO
CrankyGypsy is offline
post #10 of 10 Old 08-19-2012, 03:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No, a MML is absolutely not necessary simply because you have installed a body lift.
I dunno why some always insist on pushing a MML for a body lift. #1 a MML is overkill, not inexpensive, and not such an easy thing to install. #2 a MML can alter drivetrain angles in a direction that is not always a good thing. The only thing I'd recommend is simply lowering the fan shroud down an inch to compensate for the radiator, which is mounted to the body, now being 1" higher than is optimal for the engine fan.
Getting
Jerry Bransford is offline
Which Body lift? Daystar 1" or JKS 1.25? tjeff TJ Wrangler Technical Forum 15 02-28-2011 12:39 AM
Daystar 1" Body Lift JeepsterFloyd YJ Wrangler Technical Forum 11 02-15-2011 10:15 PM
Daystar 1" Body lift blackdog1 TJ Wrangler Technical Forum 1 02-14-2011 08:34 PM
I" BODY LIFT BY DAYSTAR H2_RECOVERY YJ Wrangler Technical Forum 2 04-08-2005 10:54 PM
need help with a daystar 1" body lift cbrothers YJ Wrangler Technical Forum 1 10-05-2003 09:10 AM
