DIY TJ Door Holders/Mounts - JeepForum.com
post #1 of 5 Old 01-23-2012, 12:29 PM Thread Starter
02ws666
**IF THIS IS IN THE WRONG SECTIONS PLEASE MOVE IT. I ONLY EVER CHECK THIS SUBFORUM SO NOT SURE WHERE IT SHOULD GO**
So I was originally going to hang my TJ doors, but after a quick google search, found out that is NOT something you do to a TJ door because the welds will crack. So I went with a way to just make something to hold them. My build is very sturdy, and will not break/fall off the wall. I have tested it and it will hold up for TJ doors.
Supply List: Home Depot
1- 1x8 6ft Board 5.68
2- Heavy Duty Double Arm Hanger 6.54x2 - 13.08
1 box - 2-1/2 Coarse Drywall Screws - 6.47
6 - 5/16x2 Lag Screws .32x6 - 1.92
6 - 5/16 Cut Washers .12x6 - .72
2 - Eyehole Screws 1.18x2 - 2.36
Total: 33.05(thats with tax)
Basically as you can see from the pictures, I was able to mount the board on 5 different studs. I used 3 Drywall screws per stud, and also used a tiny washer.(didnt include in price cuz i got at different store)
I then attached the hooks/holders to the board using the lag bolts and a washer. They go slightly though the wood into the sheetrock, but I dont mind. Once complete, I attached the eyehole screw to the top and attach a small bungee cord to it so that it does not tilt off the holders. The bungee cords take no load, and is just for security purposes. This is very strudy, and should last a long time. Hope this can help someone in their attempt to make some TJ door holders/mounts/storage. I can take more pics if requested.
02ws666 is offline
post #2 of 5 Old 01-23-2012, 06:52 PM
Tumbleweed01
Here is another option for just a bit more $
http://skinnypedal.net/store/index.p...c0496f3358b5a8
Tumbleweed01 is offline
post #3 of 5 Old 01-23-2012, 07:03 PM
mark02tj
You could have also used 4 of something like this and screwed them directly into the studs. I've got some similar but without the slight bend on the end. I've used these for my half doors.
TONS of door storage options. I also modified a furniture dolly from HF to use to store my full doors on. It works pretty well too.
mark02tj is offline
post #4 of 5 Old 01-23-2012, 08:44 PM Thread Starter
02ws666
I didn't want to go directly into the studs cuz I wanted it to be reinforced hense the wood board. But yes all of these ideas could work. The fiancÚ parks her Beamer in the garage so I didnt want then falling lol
2003 Wrangler - Light Khaki Metallic - 4.0 w/ nv3550, Smittybilt Stinger, Warn M8000 Winch, 4 Hybrid lift, G2 Dana 44s w/ 4.56 and E-Locker in front 30 spline, Detroit in rear 33 spline, 33x12.5 KM2s
02ws666 is offline
post #5 of 5 Old 01-24-2012, 08:00 AM
Whobeme
2010 JK Wrangler
I like that this way supports the door from the bottom rather than hanging all the weight on the window channels.
Whobeme is offline
no cup holders! Nick_Knipp YJ Wrangler Technical Forum 33 05-10-2012 06:30 AM
New Cup Holders Help. dvdsjk JK Wrangler Technical Forum 29 04-26-2010 09:35 AM
cup holders... Intrepid4576 JK Wrangler Technical Forum 23 08-04-2009 07:13 AM
Cup holders NDynamite JK Wrangler Technical Forum 30 11-05-2007 10:36 AM
Cup holders ImaginaryFriend TJ Wrangler Technical Forum 16 07-25-2006 11:42 AM
