DIY Shock Shifters - JeepForum.com
post #1 of 13 Old 07-08-2011, 06:37 PM Thread Starter
lupinsea
lupinsea's Avatar
DIY Shock Shifters
TJ Rear Shock Shifters
CONTENTS
1. Overview and Evaluation
2. Fabrication and Installation
3. Resources
1. OVERVIEW
The shock shifter concept was developed by Nth Degree and then acquired by AEV when they took over Nth Degree Mobility's product line. The idea is to relocate the lower shock mount outboard on the axle and provide a new upper mount to work with the new shock orientation. In contrast to a fully outboarded rear shock set up for long travel shocks there is no need to cut the frame and these shock shifters work with any stock shock or one scaled up for a particular lift. For example, they work with a 2" longer shock designed for a 2" lift, or a 4" shock designed for a 4" lift. In other words, there is a 1:1 correlation between lift height and the shocks this mod accommodates.
Benefits:
The point to this mod is that it provides greater clearance between the shock body and axle housing, which is especially important if the housing has been rotated for a SYE / CV driveshaft install. It provides greater clearance between the shock and the exhaust. It has an improve shock motion ratio and the new splayed arrangement improves handling and chassis control for the rear of the TJ. Finally, by moving the lower shock mounts outboard and behind the LCA (lower control arm) mounts it frees up additional ground clearance between the axle tube and the ground, meaning, there is less there for the axle to get hung up on.
Performance Evaluation:
As advertised, this shock arrangement does improve the handling of the TJ. The back end feels more planted and doesn't have the "wiggle" when going over bumps at a skewed angled. It is a subtle yet noticeable difference. This is one of those mods that may have just as much beneficial impact on street performance as it does on trail performance. And while I have not had a chance to hit the trails with these yet there is ample ground clearance under the axle housing. However, the lower shock mounts do hang down about 1.5" lower than the LCA mounts, but they are tucked tight against the tires where they'll likely not get hung up on rocks.
Time Evaluation:
Its an incredibly time consuming process to fabricate these since there is a lot of checking and double checking going on to make sure all the necessary clearances work out. Anyone thinking of making a set of these would be wise to simply buy the AEV shock shifters as you'll be time ahead when the project is done.
2. FABRICATION AND INSTALLATION
Measuring:
Before doing anything it is important measure the susupension at ride height to get a base-line on the shock shifter setup. The TJ should be loaded up with the driver's weight plus a standard or typical loading which would be any particular tools, spares, or gear kept in the Jeep as well as about 2/3 of a tank of gas. Then measure from the top of the axle tube to the top of the frame above the upper spring perch.
Measure the ride height between axle and frame with with a typically loaded TJ.
Prepping the Axle:
Next support the rear chassis on jack stands and remove the wheels, springs, shocks, and disconnect the swaybar links. Loosen (but do not remove) the control arm and trackbar bolts. And remove the foam bump stops from their retaining cups. The idea is to get the suspension set up so you can easily flex it out through it's range of movement without fighting the springs and bushing binding. Finally, weld on some mini-skids to box in the rear LCA brackets. Not only does this strengthen the brackets but also provides a base for the lower shock mounts.
Welding on mini-skids to box in the rear axle LCA bracket.
Cycle the Suspension:
Then cycle the suspension and observe how it moves. As the axle moves closer to the frame (uptravel) it shifts toward the driver's side. As it moves down (droop) it shifts to the passenger side. The housing pinion angle will rotate as it moves up and down. Note also that it is the passenger side rear shock that will govern all the measurements as this has the shortest up travel for the two rear shocks based on how the axle moves.
Relationship to LCA Mount and Upper Frame Hole:
Getting the shock shifters set up is a balance between the angle of the upper mount and how it relates to the lower mount. In general, the lower mount will line up with the outside LCA bracket plate. And the upper shock bushing will be almost centered over a hole just in front of the stock upper mounting location.
View of the upper shock mount location on the TJ's rear crossmember.
The white dashed line represents the approximate location of the outside face
of the lower shock bushing and how it lines up the outer LCA bracket tab. The
actual vertical location will be dependent on the compress shock length. In
this photo, a secondary lower mounting plate was tack welded to the mini-skid
in a later step. I marked on this plate the alignment of the lower bushing at
ride height and at full bump stop compression.
Upper Shock Mount:
Start work on the upper mount by cutting and drilling mounting tabs. The rear tab will span between the to stock shock bolt holes. The forward tab will be bolted to the front of the rear cross member and require a new hole to be drilled. I opted to match the new hole and fastener to the metric hardware used to secure the stock upper shock mount. Bolt the tabs into place.
Next the mounting plate needs to be fabricated. Use a piece of cardboard as a template to figure out the size of the rectangular open for the upper shock bushing eye and the location of the mounting hardware flanking this opening. The orientation will be perpendicular to the stock shock mount. The plate can be cut and drilled out of a piece of 3" x 1/4" plate steel, length will vary. It shouldn't be overly long but will need to be long enough to provide welding clearance for the various hardware. For the upper hardware for the new shock mount I used some carriage bolts. This means the holes for the carriage bolts need to be square. Drill the hole the same size as the squared shoulder of the carriage bolt and use the jig saw to cut out the corners. To cut out the square for the shock eye hold drill holes in the four corners and then cut with a jig saw or plasma cutter to connect the holes. Leaving a triangular point at one end of the plate will allow you to do a half-cut and bend to make placement on the Jeep easier.
Next, hold the shock in place and / or bolt it to the new mounting plate and hold the upper end in place and see where the lower end ends up. Keep in mind the relationship to the outer LCA bracket tab and lower shock bushing. Once you have it somewhat located tack weld the upper plate to the forward mounting tab. The tack weld should be strong enough to hold while allowing some tweaking of the plate.
Some pieces of steel were cut, drilled, and mounted as the start of the upper shock bracket.
A cardboard template was created and roughly test fit for the upper shock mount before
fabricating the piece out of steel. Note, to create the square upper shock bushing cut out
drill holes in the four corers and then cut between them with a jig saw and a metal cutting
blade. Clean up with a file.
The pointy end of the plate was partially cut through with an angle grinder, bent, and
then tack welded to the forward mounting tab. This provides enough strength and
yet adjustability to mount the shock and further bend the plate to the propper angle
in relation to the lower shock mount location (as yet To-Be-Determined).
Shock Length and Lower Shock Mount:
Next, determine the extended, compressed, and ride height lengths for the shocks you are using. Ideally, the ride height of the shock should be mid-way through the suspension travel. However, it is important that the shock does not bottom out before the axle reaches the bumpstops. To determine this length measure from the empty bumpstop cups to the axle spring perches. This is the full amount of up travel available and should approximately equal the amount of travel from the ride height length to the fully compressed length. Wire the shocks to set their respective lengths, fit them to the axle, and cycle the axle to see where everything ends up. You should get a good idea of where the lower mount should end up.
Now cut a 3" x 1/4" plate and weld it straight down and tangent to the axle housing and LCA mini-skid (see one of the earlier images). It should be oriented such that the lower shock tabs should land in the middle of the plate somewhere. Leave the plate oversized for now and trim it down later.
Fully compress the suspension to the bumpstops. Take the compressed shock and hold it to the upper shock mount plate. Mark on the lower shock plate where the centerline of the bushing eye is. This is where the lower shock mount tabs will go. However, the shock mount tabs will be oriented based on the ride height length of the shock and the ride height of the axle. So reset the axle to ride height and now hold up one of the ride height shock and mark that centerline angle on the shock plate.
Do check clearances between the shock body and the various suspension an brake components by cycling the suspension once everything is tack welded and the shocks are mounted. On my first tack weld I got the lower tabs too far outboard and had the rear disk caliper brake line bolt just barely kissing the shock body when one side was fully stuffed and the other was at full droop . . . too close for comfort. So I cut and moved the tabs in about 1/2"
The shocks need to be measured to determine total available travel. But it is
the compressed and ride height measurements that will be most critical.
Because these shocks are pressurized, some wire was wrapped around
the ends to keep them from expanding.
The compressed shock mounted on the upper bracket with the suspension
on the bumpstops to see where the lower bushing will rest when the shock
and suspension are fully compressed. Mark this location.
- Jay
lupinsea is offline
post #2 of 13 Old 07-08-2011, 06:38 PM Thread Starter
lupinsea
lupinsea's Avatar
The lower plate with the bushings axis marked where the shock and
suspension bottom out when fully compressed.
View from the top showing how the lower spring perch and upper bump stop
retainer cup are in contact when the suspension is fully compressed. This is
why it's important to remove the springs and bump stop.[/img]
Finish Tack Welding Bits and Pieces:
At this point it's easy to position the lower mounting tabs. Cut and drill some lower shock mount tabs and bolt them to the lower shock bushing. Make sure the tabs have clearance for the shock body. And stagger the drilled hole by approximately 1/4"+ further out on one of the tabs to allow the lower bushing to be rotated slightly in keeping with the back and inward tilt to the shock position. Mount the bushing in place and tack weld the tabs to the lower shock mount plate. Congrats, the shock orientation is now set. The rest of the modification involves cutting pieces of steel and tack welding them in place to box in the lower shock mount plate and the upper shock mount bracket.
A lower shock tab cut and drilled before the millscale is ground off for clean welding.
To get the proper alignment for the tabs: bolt the shock to the upper shock bracket
mount, then bolt the tabs to the lower shock bushing, press tabs/bushing against the
vertical mounting plate and align with the mark on the plate, tack weld. That's it.
Full Weld and Finish:
Remove the upper bracket and do final full welds. The lower axle can be left in place but it will be trickier to finish off these welds. After welding, clean up the steel and paint it. Reinstall the upper shock bracket and install the shocks. Torque everything to specs. Done.
Remove the tack welded upper brackets for final welding and clean-up. These were a bit
crude but perfectly functional.
The upper brackets re-mounted on the Jeep.
The final lower shock shifter bracket, fully welded up, trimmed, cleaned up, and painted.
This shows how much the lower shock mount is outbarded, you can
also see how tight to the tire it is tucked.
The lower shock mount is about 1.5" lower than the LCA bracket, but again, the ride
benefits are very much worth it considering how tight the mounts are tucked to the tire.
- Jay
lupinsea is offline
post #3 of 13 Old 07-08-2011, 09:48 PM
MayRoll
I like threads like these. I automatically scrolled down to see your fab work. Half way through I got thinking, I wouldn't do this it'll take me forever when I could simply buy from Nth. Then I read the top part...
Originally Posted by lupinsea View Post
Time Evaluation:
Thanks for your honesty. It is nice though to have the time and know how to complete worth while mods like this. Nice work.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #4 of 13 Old 07-08-2011, 10:57 PM Thread Starter
lupinsea
lupinsea's Avatar
No problem. . . I usually try and provide some kind of evaluation when I do a mod or upgrade and post about it so others can evaluate it for themselves. In this case the performance aspects are fine, it's just a real judgement call on fabbing something like this yourself or getting a kit.
AEV's kit is very nice and the top bracket (which IMO, it the bigger PTIA of the two) already fabbed for you, and in a nice stamping, too, not some kludged together welded steel chunk.
Then there is the learning curve on a project like this. It took me forever to get the first side done. . . checking and double checking everything, figuring out how to cut and shape the plates, etc. . . The second side I was able to get done in a few hours.
There still is some welding involved with the AEV kit but they cut out the most time consuming part, the design aspect, and have figured out the geometry for you.
For me as much time as I spent on this I did end up having more time than available funds. Especially considering I just got done re-gearing the front axle and had some "last minute items" I needed to get for the D44 axle swap. All the steel was left over stuff from past projects. My direct costs for this amounted to:
$6 - For 2-3 cut off wheels for the angle grinder
$6 - A pack of jig saw bi-metal blades (didn't have any)
$5 - Can of "professional" Rustoleum (it's nice stuff)
$8 - Various hardware fasteners
$5 - Small-ish square file for the carriage bolt holes
$25 - Out-of-pocket costs
So, at this point, it was only another ~$100 to get the AEV kit. . . and it'd be less if one factored in the cost of the steel (which you don't need much of).
In any case, if you LIKE doing stuff like this, by all means go for it. However, if you would rather go play with the Jeep and see doing mods as a means to an end. . . save up and get the AEV kit.
- Jay
lupinsea is offline
post #5 of 13 Old 07-14-2011, 01:23 AM
I FLEX
I FLEX's Avatar
Lol...jeez Jay, you make it look so easy.
- Micah
Muddy TJ
2001 SE 5spd | 33x12.5x15 Toyo MT's|
RE.BB with RE3.5 shocks | Anti-Rock
#13
(they are some what updated)
I FLEX is offline
post #6 of 13 Old 07-14-2011, 07:01 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
nice write up, and great fabrication. glad you got the bumpstops covered in there
reminds me....I've got shock shifters waiting to be installed with some N67L's....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 13 Old 07-14-2011, 07:59 AM
tucanbob
I need to do something like this to get more travel from shocks, but I have to wait b/c I don't want to do it multiple times like when I ditch the d35, or when I get a sye, etc.
so I wish there were a bolt on option.
great write up
99 TJ - SOLD
running jeep-less for now.
tucanbob is offline
post #8 of 13 Old 07-14-2011, 04:54 PM Thread Starter
lupinsea
lupinsea's Avatar
This and the track-bar bracket modification on the D44 swap are why the swap took 3 1/2 weeks.
That and I tend to work slowly on my Jeep. Get distracted easily looking and examining things and have to remind myself every so often to just "get something done" or I'll be staring at something all night long.
So... it's sort of easy if you have access to a welder and angle grinder.
Still, my advice if you want to do this is to just buy the AEV shock shifters.
- Jay
lupinsea is offline
post #9 of 13 Old 07-14-2011, 05:07 PM Thread Starter
lupinsea
lupinsea's Avatar
great write up
reminds me....I've got Nth shifters waiting to be installed with some N67L's....
I'm not sure this mod works really well for extended travel shocks or to free up more suspension travel.
For long travel shocks the issue is you're pinned in at the top by the chassis cross member so the only place to adjust anything is on the bottom end. . . at the axle bracket. And I think there is only so far down you want to extend that depending on wheel back spacing or wheel size.
As for freeing up more suspension travel. Hm. It lets you dial in where the "ride height" mounting point for the shocks is and match it with the amount of up travel you have. But otherwise this orientation follows almost a 1:1 motion ratio with the suspension.
As I say, it scales very well with "normal" shocks designed to work with corresponding lift heights:
Stock shocks w/ 0" of lift
2" lift shocks w/ 2" of suspension lift
4" lift shocks w/ 4" of suspension lift
It would work less well if you were trying to put on a longer travel shock to a shorter suspension lift, such as a 4" long travel shock on a 2" spring lift. If you're looking to do the later, say for an LCG build or something, then doing a full-on-frame-cutting shock outboard is what I'd suggest.
- Jay
lupinsea is offline
post #10 of 13 Old 07-14-2011, 06:19 PM
Unlimited04
it does work for long travel shock. here's a write up on how:
http://www.jeepforum.com/forum/f9/lo...antage-852221/
Useful Write-Ups:
Funny:
post #11 of 13 Old 07-15-2011, 01:28 AM
mudb8
want it rite or rite now?
mudb8's Avatar
Just remember not to get carried away with getting to close to the tire with the mounts, anything pas the center of the lower CA mount will cause the shock to come in contact with the frame whe the suspension is fully compressed on both sides at the same time.... relocating the upper mounts reduces the uptravel due to the mounts being extended downward, its better to cut the Xmember and go up through it with a box mount, which also requires a BL.
lower/outboard mount relocation alone will allow 10" travel shocks on 2.5" suspension with 4.5"+ uptravel...
nice job on the write up. lupinsea, I'm glad to see some are starting to understand how the supension components all work together.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #12 of 13 Old 07-15-2011, 10:19 AM
pdangerp
pdangerp's Avatar
I agree with Mudb8. My large bodied Rancho 9000XLs were coming in contact with the frame because I welded his bracket too far outboard. Had weld the pin to the inboard side of the bracket. Also, be aware that lowering that mount on the axle makes for a very likely drag point in the rocks. If you have the shock bushing too far down on the mount, when you drag over a rock, the shock will drag over too. Found this out the hard way too.
pdangerp is offline
post #13 of 13 Old 07-18-2011, 04:07 PM Thread Starter
lupinsea
lupinsea's Avatar
Yes. . . it's flipping amazing how much and in what directions our Jeep's axles move as they cycle through the suspension. Holy crap. It's not until you start trying to measure things until you realize just how much everything shifts, moves, rotates, etc.
- Jay
lupinsea is offline
anyone use Nth Degree Mobility Shock Shifters Rafikie TJ Wrangler Technical Forum 3 07-18-2008 04:37 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 10:43 PM
bds shock shifters TSWRA TJ Wrangler Technical Forum 4 08-15-2005 02:10 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 12:45 PM
