#46 | |
Pics!
Finally some pics to update with.
First is the new hood line I found some door protectors to clean up the cut with, it turned out looking pretty good. ![]() Here's a couple of shots of the engine compartment. You can see the new temporary air cleaner I'm using until I get a K&N. The fuel evap unit is turned 180, and I'm still thinking about where to put the washer fluid bottle. ![]() ![]() Flex pics for your enjoyment! ![]() ![]() If I get some extended fender flares I could get a couple more inches of stuffage out of the front. ![]() The back is just about perfect, but I may add to the bumpstops just in case. ![]() Then there's a shot of what I cut out of the back. I also found some red rustolium paint that was almost an exact match to the original paint. In the picture the paint looks a little funny, but it looks fine in real life. Not like anyone is going to look into your wheel well, I just want it to stop the rust. ![]()
#47 |
no radiator req'd
Put them flares under the knife and trim about an inch out of em. I used the blue 1" painters tape, and a steady hand with an exacto knife. Sanded the edges and voila! more clearance. My $.02, nice work btw
#48 |
badazzzzzzzzz
2004 TJ-L with 3-4" of lift, 35's, and no money The Unlimiteds shall inherit the earth. |
#49 |
I drove it around all day yesterday and had zero problems. I was worried about the check engine light coming on. I had a little kid that couldn't take his eyes off the jeep. Gotta say it's always fun having a car that you dreamed about when you were little
#50 | |
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#51 |
In the rear towards the windshield I cut off at 3 inches. The front tapered down to 2 1/2 inches. If I were to do it again I would just cut the line at 3 inches all the way across. This would solve a lot of the problems I had to deal with. It still turned out great in the end, but I do wish I would have seen it sooner.
#52 |
looking good, did you do anything with the fender to rocker gap yet ?
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
#53 | |
Not yet. Since it's really only cosmetic, besides the need for rocker guards, I'm just going to wait until I can afford the rokmens. Strapped myself picking up a new sailcloth top, but it was worth it. |
#54 |
#55 |
Great!! Thanks alot.
Just what I needed... Another excuse to cut on my Jeep. My wife will be thrilled! I popped my cherry on flush mounting my tail lights. There is nothing I like more than 20 doller mods that look great and have function as well! |
#56 |
i like how low and squat it looks with those 35s & 2" of lift.
#57 |
tjaaron,
Do you have any pics next to another tj with 35's and more lift so I can see the difference. I am trying to visualize it, but its difficult for me. You did a great job on that Aussie Lift. I'm still on the fence as to if I want to take the blades to my TJ.
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/ |
#58 |
Camel Jockey Express.
That thing looks spectacular. I just ordered some Genright fenders through Zach at A-Z am having them installed while I'm out here.............think when I get home I might get some measurements from you for the rear.
God made mankind, Sam Colt made mankind equal. 230gr @ 950 feet per second says you won't steal my property!! |
#59 |
GreenJip
I don't know anyone with 35s, but if I see someone around town with it I will try to take some side by side pictures. As to cutting the Jeep, it helps if your fenders are already in a bad way which mine were. I had no where to go but up ![]() |
#60 |
Mine isn't next to his obviously. But it is with a 3" BDS and 1" BL and 35s. Hope it helps a little...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
