Quantcast DIY highline...took the plunge - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > DIY highline...took the plunge
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 12-06-2007, 07:54 AM   #31
Unlimited04
Unlimited04's Avatar
Originally Posted by tjaaron
I just followed the these threads, the aussie originator really deserves a lot of credit. That guy did it all without knowing what the results would be, and started quite a craze. I hope it's not bad form to reference other forums.
http://www.ausjeepoffroad.com/forum/showthread.php?t=55352
http://www.jeepsunlimited.com/forums/showthread.php?t=785321
yea that black RHD was the first one I saw too. i've wanted to do it with tube fenders ever since, then rokmen prototyped the tube fenders! i can't wait for them to start selling them.
oh i'd cut some hood vents in the top while your at it. check out this write up: http://www.oman4x4.com/hoodventinstall.htm
Unlimited04 is offline   Reply With Quote
Old 12-06-2007, 03:04 PM   #32
Border Dave
Are you serious? I don't know if I could be trusted with someone else's rig. I'd be up for a joint effort that was well documented for the betterment of jeepers everywhere though.
I am very serious. I've been contemplating buying the AEV highline kit, but am having a hard time justifying the cost, especially when you figure in the prep work and paint. Also, I live in an apartment complex and can't work on my Jeep here. I'll PM you with my phone number.
David
Border Dave is online now   Reply With Quote
Old 12-06-2007, 05:01 PM   #33
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
Originally Posted by badoosh27
thats friggin sweet, i wish i had the nuts to do that to mine
It that's you're Jeep in your avatar then does it really matter if you cut the fenders...
To the OP, that looks awesome, great job...
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 12-06-2007, 05:23 PM   #34
Unlimited04
David
Keep me updated. I'm going to highline my jeep eventually and would like to see measurements and a well documented write up.
Old 12-06-2007, 05:36 PM   #35
tommaho
Good job, looks great. I'm working on finishing up my rears.
tommaho is offline   Reply With Quote
Old 12-07-2007, 09:30 PM   #36
Bottledbird68
Subscribing to thread cause I don't want to wade through 5 pages again to find it lol.
Post more pics when you're done!!!! Looking good so far.
96 ZJ 3.5" pro-comp on 33" MT/R's with black steelies
The family wheeling wagon. (Broken, but about to be better ;D) Edit, gave up and sold it lol. Concentrating on the TJ now :D
99 TJ Sport Her ride. 2" BB w/ 32" bfg MT's on black steelies
Bottledbird68 is offline   Reply With Quote
Old 01-02-2008, 02:44 PM   #37
GreenJip
Bump.........
Any updates on this thread?
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 01-08-2008, 03:41 PM   #38
1CleanTJ
so im finally thinking about doing this, I checked things out and have a few questions.
where did you end up putting the black box on the drivers side after you moved the fenders up,
what type of washer fluid bottle did you end up using ?
how did you make them fit up higher with the slanted part that follows the grille shape ? (the part where the fender/grill meet below the headlight, right behind the hella light)
1CleanTJ is offline   Reply With Quote
Old 01-14-2008, 10:55 AM   #39
tjaaron
Update
I was finally able to get back to the project. . . school, work, storms it seemed like I could never get back to it. But the weekend was sunny and my internet is back on so here's a teaser!
I think I'm about 90% done with it now. I was able to take it for a test drive yesterday, and boy am I happy with the outcome. I will try to get some pictures of the engine compartment up tomorrow, and maybe some flex pix
tjaaron is offline   Reply With Quote
Old 01-14-2008, 11:01 AM   #40
Oman Jeep
Sorry if I missed it... are you planning on boat-siding the tub?
Oman Jeep is offline   Reply With Quote
Old 01-14-2008, 11:07 AM   #41
tjaaron
1claentj:
The black box I turned 180 degrees and put where the washer fluid bottle was, I'll post pictures tomorrow. I still haven't sorted out the washer fluid bottle yet. The stock bottle might fit next to the brake cylinder, but it touches and I don't know if it will melt the bottle or not. For the bending I used the stock mounting location on the grill, drilled new holes in the fender, and used a long bolt with washers to bend it. There's a couple of pictures of the long bolts on the first page.
Old 01-14-2008, 11:10 AM   #42
tjaaron
I saw a great boat side thread on pirate, it could be done very well. I have zero welding skills however, so as soon as I pull some money together I'll probably use the rokmens for now. How's your "real" highline treating you? I think we started our projects at about the same time. I'm jealous.
Old 01-14-2008, 11:17 AM   #43
1CleanTJ
thanks, I finished mine up last night except for the bottom fender to body gap but for some reason I got a ticking coming from the leak detection pump, not sure if its a pinched or leaking line somewhere or what. It snowed all last night/this morning so ill probally check it out tomorrow. Have you figured out what your going to use for hood latches yet ? If not let me know I got creative with the stock latch and it worked out great and looks pretty decent still
Old 01-14-2008, 11:22 AM   #44
tjaaron
Wow you finished fast. I guess I didn't put to many hours in, just spread them out over a long period. I just relocated the stock latches, it seems to work well, the hood didn't fly up on the freeway, so that's a good sign.
Let's see some pics of yours!
Old 01-14-2008, 11:49 AM   #45
1CleanTJ
http://www.jeepforum.com/forum/f9/so-i-grew-some-balls-started-cutting-505912/
some pics, its not perfect but for less then $20 in supplies I can live with it
I still need to cut the rears and mess around with the front gap a little. Still not sure what im going to do with the bottom area yet. Been thinking about doing a piece of steel plate from the fender to where the body and rocker meet and tie it into my sliders
Glock Forum
