Quantcast DIY highline...took the plunge - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > DIY highline...took the plunge
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 12-05-2007, 10:05 AM   #16
Lostj
I wish I wouldve thought about doing this before I got tube fenders
lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00
44p '03p '6ı :5ɾɔ,37
s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47
The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad
Lostj is offline   Reply With Quote
Old 12-05-2007, 10:10 AM   #17
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
looks pretty good. I think doing the rokmens are a good idea.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 12-05-2007, 10:11 AM   #18
1CleanTJ
you can still do it, you wouldnt have to cut up tube fenders at all, just move there mounting point up some
1CleanTJ is offline   Reply With Quote
Old 12-05-2007, 12:24 PM   #19
tjaaron
Thanks for the compliments, I knew jeepforum would appreciate it. Everyone at my house is tired of hearing about my Jeep. For the sides I think I will just go for the rokmen sliders, boat sides would be cool, but I'm still trying to keep it stockish looking and I'm not a pro fabricator. I was literally shaking when I finished the first hood cut because I was so intimidated by cutting into the Jeep and I knew there was no going back. My girlfriend won't let me live that one down.
I went out and measured and the actual measurements for the new height is 3.5 inches in the front and 3 inches in the back.
As for the engine compartment, I'm still working on it. I'm bending some brackets to move the evap unit to where the washer fluid bottle was. I think the washer fluid bottle can move to next to the brake cylinder, unless it gets too hot. For the time being I'm going to attach a cone filter to the air intake, because I live in cali I'm eventually going to put a K&N filter on there before the next smog check because of the CARB cert.
tjaaron is offline   Reply With Quote
Old 12-05-2007, 06:31 PM   #20
GreenJip
WOW, you have got some big grapes to be cutting like that! Keep this thread alive. I can't wait to see the final result.
GreenJip is offline   Reply With Quote
Old 12-05-2007, 07:43 PM   #21
Border Dave
Congratulations! That's an awesome mod.
By the way, smog checks go by county, not by the state. In my county (Imperial), you only have to smog a vehicle when you sell it.
Border Dave is online now   Reply With Quote
Old 12-05-2007, 07:54 PM   #22
michaelg
I envy you. I love the look and have all the tools to do it with except for a couple below the belt i guess.
I agree with greenjip dont forget to post up final pictures
michaelg is offline   Reply With Quote
Old 12-05-2007, 07:59 PM   #23
PBR
do it with tube fenders
PBR is offline   Reply With Quote
Old 12-05-2007, 08:52 PM   #24
tjaaron
I just followed the these threads, the aussie originator really deserves a lot of credit. That guy did it all without knowing what the results would be, and started quite a craze. I hope it's not bad form to reference other forums.
http://www.ausjeepoffroad.com/forum/showthread.php?t=55352
http://www.jeepsunlimited.com/forums/showthread.php?t=785321
I just wish I took more pictures, it's such a great mod there really should be a good step by step that anyone can follow. It was pretty "easy" take it from someone who's never done anything like this before. Plus as of now I've only spent about 20 bucks on misc. nuts and bolts, some paint and cutting wheels. Granted I still have to purchase an air filter.
I just told myself that if it didn't work out then I would just upgrade to the heat reduction hood. The rest of it can be put back together, you'd just have the hole on top of the grill. But now I wouldn't go back, I love it. Other jeeps are starting to look funny with their low fenders
Old 12-05-2007, 09:30 PM   #25
Border Dave
If you want, I can deliver my Jeep to you and you can do it again to mine.
Old 12-05-2007, 09:56 PM   #26
M.DURITZ
I know exactly what you are talking about .
2001 Yellow TJ Wrangler | 4" Superlift | 33 x 12.50 x 15 BFG's | Front and Rear WARN Bumpers | XeNoN Flat Fenders
M.DURITZ is offline   Reply With Quote
Old 12-05-2007, 10:22 PM   #27
tjaaron
Are you serious? I don't know if I could be trusted with someone else's rig. I'd be up for a joint effort that was well documented for the betterment of jeepers everywhere though.
Old 12-05-2007, 11:07 PM   #28
fish4life
it looks pretty bad *** from the front .... from an angle you can see the fender's aren't made to be there.
Good job though on making it all symmetrical!! looks much better then a body lift of that size would
fish4life is online now   Reply With Quote
Old 12-06-2007, 01:20 AM   #29
tjaaron
Could you elaborate?
I've been going over it and I see some things that need to be tweaked, just wondering if others see the same things. I'm interested in Jeepers opinions, most non jeepers can't even tell that I've done anything.
Old 12-06-2007, 07:10 AM   #30
mexican_hippie
Looks awesome!
Just make some longer rockers and no one will notice the gap at the bottom of the front fender.
Texas, the only State to Have Ever Kicked Another Country's Butt
mexican_hippie is offline   Reply With Quote
Glock Forum
