Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > Models > Wrangler Forums Group > TJ Technical Forum
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old12-04-2007, 09:45 PM #1
tjaaron
DIY highline...took the plunge (updated with pics!)
I've been wanting to do this ever since I saw the original aussie thread. I purchased the jeep with some cheap 2 in lift and 32's, but came across a deal on 35's I couldn't refuse. I've never used a grinder, but I've done everything on the jeep myself. So with a deep breath I decided to go for it. A couple of before shots.
At this point I have a slight rubbing problem.
The first thing I had to do was cut the hood. I ended up taking the hood completely off to do this because I thought it would be a little easier. This part was very intimidating, my first cut!
I've taken the fenders off and I'm ready to fit on the cut hood. I think the Jeep looks a little sad here.
Now it's time to test fit the fenders. The fenders actually would wedge into place which made it easy for me to fit and look for mounting points.
I was able to use some of the existing mounting points on the front, just one hole up from their original place. I still had to add a new hole at the top. Then I used some long bolts I had lying around from another project to bend the inside of the fenders to their new place, and added another hole to make sure it didn't bend out in the middle.
Now with the fender bolted on it looked like it was ready to fly away. At this point I had to step back and think about how to bend it back down.
tjaaron is offline   Reply With Quote
Old12-04-2007, 09:47 PM #2
tjaaron
continued . . .
There is a brace holding the fender at the angle it was, just behind the turn signal, so what I did was cut the brace, and bend the fender down to the angle I wanted. Then I drilled a hole and used a bolt to hold it in place. I was thinking about welding it, and I may later on, but this way if I need to change the angle it won't be such a big deal.
Now with the fender bent flat it was time to admire how much more room I had there.
I did the same thing to the other side, which took a lot less time now that I new what I was doing. Then it was time to start on the back. I took off the flare and measured up how high I thought it should be.
Then went at it with the grinder. As you can see by this picture I didn't quite cut out enough. I'm going to take off the rear tires, because there just wasn't enough room back there to get it all.
The project is really starting to come around now and you can see what the finished product is going to look like.
I still have plenty yet to do. Drill the mounting holes for the rear fender flare. I think I'm going to pick up the rokmen rocker guards because they go well to well and I can cut the new angles into them. Then I have to start on the engine compartment. I've been fabbing up some new brackets for relocating the fuel evap unit and I think I've found a good spot for the washer fluid cannister. So hopefully it won't be too much longer until I'm able to take some flex shots.
Old12-04-2007, 09:58 PM #3
Scotch740
Scotch740's Avatar
Nice work, this is in my plans for the future to go from 33s to 37s but I hope to be making tube fenders by then. Have you considered boat sides? Maybe a little much for right now but would be a nice addition.
Again nice work and keep the updates comming!
FOR SALE: Genright HighLine tube Fenders, Wood Doors, Bikini top, Speedo Gear for 3.73s w/35"s
Scotch740 is offline   Reply With Quote
Old12-04-2007, 10:00 PM #4
NMLJ
NMLJ's Avatar
looks great but what do you have against bodylifts?
-2006 LJ-
IMPACT ORANGE jeep club #8
LJ owners jeep club #106
New Mexico jeep club #8
www.photobucket.com/sundaysrock
NMLJ is offline   Reply With Quote
Old12-04-2007, 10:03 PM #5
tjaaron
Hmmm. I've read some of the boatside threads, but never thought about it for my jeep I haven't seen one that looks finished. Since I've been concentrating on this for so long it doesn't even seem like an option. But I bet when this is done I'll wondering what to do next.
I've got nothin' against body lifts, that's for when I get 37's, and can figure out what to do about axles. But I've gained 3.5inches of clearance here, and there's no way I'm getting a 3in body lift.
Old12-04-2007, 10:59 PM #6
dragginwagon406
Excellent work. Be sure to post pics of the inner fenderwells and how the components are rearranged.
NW Ohio Crawlers
Ohio4x4
dragginwagon406 is offline   Reply With Quote
Old12-04-2007, 11:04 PM #7
1CleanTJ
1CleanTJ's Avatar
thats awesome, what measurements you go for to cut the hood and how did you decide ? thats a big leap and no going back ! but the results are awesome
99 TJ- 4.0/5-speed, 4" lift,35" MT baja claws,homemade highline (aussie lift) custom front/rear bumpers w/tire carrier, tabor 9000lbs winch, Olympic rock sliders, hella driving/spot lights, roof rack, dome light override switch, 62 LED flush mount taillights, 55watt reverse lights - money pit
generosity project -> http://onlyadollar.webs.com/ DIY jeep highline guide -> click here DIY highline guide
1CleanTJ is offline   Reply With Quote
Old12-04-2007, 11:09 PM #8
badoosh27
badoosh27's Avatar
Send a message via AIM to badoosh27
thats friggin sweet, i wish i had the nuts to do that to mine
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.07's, ZJ springs, 1"BB, 32" BFG All-Terrains and 17.5mpg
http://www.cardomain.com/ride/2634280
badoosh27 is offline   Reply With Quote
Old12-04-2007, 11:14 PM #9
Unlimited04
Unlimited04's Avatar
looks good! i've been wanting to do the same thing with tube fenders, but I can't bring myself to cut anything just yet. do you have any specific dimensions, especially on the hood? Also what is the distance from the tub to the base of the fender, or the amount the fender was lifted.
Unlimited04 is offline   Reply With Quote
Old12-04-2007, 11:21 PM #10
tjaaron
For the front I just cut along the line on the hood. This worked out pretty well, but looking back it would probably be better to cut a little more off the front of the hood. The hood line tapers slightly which causes a little bow in the fender when you match it up. I just bent it back with my foot, but I'm sure if I matched it up better that bow wouldn't have happened. The rear I raised about 3/4 of an inch lower than the front, mostly because it looked to high when I had it the same height. The front was lifted about 3 1/2 inches and the back a little more than 2 3/4. I can get you some more accurate measurements when I get home.
Old12-05-2007, 02:39 AM #11
john NC
lookin good, can't wait to see the finished product
john NC is offline   Reply With Quote
Old12-05-2007, 07:33 AM #12
red87yj
red87yj's Avatar
1987 YJ Wrangler
I like the idea of a highline job for my YJ. My only question is what do you do with the sides of the tub that now hang down? I know you could do some boat sides but what other options are there?
Later
Zach
87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped
3.5 BDS Lift and 1.25 inch shackles
35 inch M.T. Baja Claws
Ford 8.8 (welded) and Waggy 44 (locked) with High-Steer and 2 spare tires
My RigRater Score: 682RRv1.0 with a BOA of 31.54
TOO MUCH more stuff
red87yj is offline   Reply With Quote
Old12-05-2007, 08:15 AM #13
FLATFENDER54
FLATFENDER54's Avatar
Looking real good. I am also one of those guys that wants to do this but is kinda skeeeeered to cut on the jeep (my jeep is a 2001 BUT it still only has 35,000 miles on it) My brother has a 97 that i keep telling him ill cut on it for him -lol
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg
66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg
93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg
99 escort zx-2 my favorite lil gas "sipper" (who cares)lol
USMC "Semper Fidelis"
FLATFENDER54 is offline   Reply With Quote
Old12-05-2007, 08:18 AM #14
Unlimited04
Later
Zach
in the aussie thread mentioned above, the guy made rockers to cover them. i've seen others box in that corner with the rocker to tie into the sheet metal above.
Old12-05-2007, 08:52 AM #15
jcssurf
I see red X's...I want pics!
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline   Reply With Quote
Taking the plunge BiTMAP YJ Technical Forum 3 06-17-2008 04:20 PM
Took the plunge...again! KrasnayaZnamya JK Technical Forum 3 10-14-2007 02:04 PM
Just took the plunge mstout JK Technical Forum 0 07-16-2007 09:50 AM
Took the plunge KrasnayaZnamya JK Technical Forum 1 03-24-2007 02:12 PM
Took the plunge! commodore_dude TJ Technical Forum 15 07-18-2006 06:01 PM
The time now is 10:58 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
