DIY Alignment Kit and Steps w/Pics... - JeepForum.com
post #1 of 70 Old 03-27-2014, 03:33 PM Thread Starter
robncar
robncar's Avatar
Performed an alignment this morning and thought I'd share my DIY alignment kit and method that I use to set toe-in on my TJ.
I was never happy with the "scribe a line", "bungee to the outside of the wheel", or "measure from one tire seam or lug to another" processes.
The kit contains:
2 - 48" Steel Square Tubes (marked at the center points and at tire diameter)
4 - Large Pony Clamps
2 - Small Pony Clamps
2 - Tape Measures
6 - 1/2"-20 Nuts with Washers
2 - Bullet Levels
Steps:
1 - Place on jack stands close to ride height and remove front tires.
2 - Use nuts and washers to secure rotors to unit bearings. <-- IMPORTANT!!! If you don't, you can't achieve any accuracy.
3 - Center steel tubes on the lower side of each rotor and clamp with large pony clamps.
4 - Use bullet levels to place bars into same horizontal plane.
5 - Run two tape measures from one set of steel tubes to the other at the marks representing the tire diameter, clamp one end of the tapes with small pony clamps making sure to not affect the tapes ability to record an outside measurement, and let the other end hang suspended above the ground.
6 - Compare the measurements of the two tapes. In my case, I've targeted the front to be 3/16" smaller than the rear for my 35's (toe-in). The actual measurement does not matter, just the difference between the front and back tapes.
Front = 57-10/16"
Rear = 57-13/16"
7 - To adjust, loosen the clamps on, and rotate the tie-rod until you reach your desired setting. You'll see the tapes slide on the tubes as the tie-rod is turned. I use the inside edge of the tubes for my measurements so that I'm not fooled by the curvature of the tape outside the tube.
8 - Once you're happy with the delta of the front and rear tapes, tighten the clamps on the tie-rod, keeping in mind the clamp positioning relative to any moving parts that may come into contact with them.
9 - Then, you can center the steering wheel by loosening the drag link clamps and rotating the link until your wheel is centered. Once it's centered to your liking, tighten the clamps on the drag link, keeping in mind the clamp positioning relative to any moving parts that may come into contact with them. You may need to repeat this step a couple of times after test driving the Jeep to get it just right.
Easy as pie...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #2 of 70 Old 03-27-2014, 06:58 PM
tjsean0308
Excellent write up thanks for taking the time. I vote to add this to the end all alignment thread.
tjsean0308 is offline
post #3 of 70 Old 03-27-2014, 07:11 PM
AntiPrius
That's a good write up. I do mine very similar except I only have one tape measure so I have to go back and forth a few times. It looks easier with two for sure.
AntiPrius is offline
post #4 of 70 Old 03-27-2014, 08:14 PM
RubiDee
Nice write up & pics...I do the same with two old hockey stick shafts(nice and straight)use bungee cords to hold to tires/rims and measure across...definitely looks easier to measure without tires in the way, but more work jacking and removing..
RubiDee is offline
post #5 of 70 Old 03-27-2014, 08:53 PM Thread Starter
robncar
robncar's Avatar
Yep, I tried the bungee cord on the outside of the tire method too and found it to be not as accurate due to tire sidewall variance. This method, with the bar under the rotor hat, is easy to duplicate. When you're trying to hold tight dimensions every bit counts, this method seems to be accurate and repeatable. To get that, I don't mind a little extra work.
Thanks for the comments, glad to help.
robncar is offline
post #6 of 70 Old 03-27-2014, 09:00 PM
purplepig
awesome! thanks! I see you are targeting 3/16" for your toe-in. Is that on 35's? Does anybody have info on what toe-in to use for different size tires?
purplepig is offline
post #7 of 70 Old 03-27-2014, 09:53 PM
Rangerz
Nice write up. Thanks!
"Jeeps Love Gas Stations"
Chris - Lost Wages, NV
2002 Dodge Ram 2500 Diesel, 2009 Lance 825, 2005 TJ,
Polaris RZRs.
Rangerz is offline
post #8 of 70 Old 03-28-2014, 09:53 AM Thread Starter
robncar
robncar's Avatar
Typically 1/16" to 1/8" but through trial and error I use 3/16" toe-in for my 35's. I know some jeeps seem to handle/drive better with toe-out too.
You're welcome!
This is something most folks can do, in the driveway, with a couple of tools, some jack stands, and this kit. Also, you can check it as often as you desire and experiment with different settings without another trip to the alignment shop.
robncar is offline
post #9 of 70 Old 03-28-2014, 10:37 AM
aparke4
Clear and concise write up! I think I am gonna tackle this today... Just got new tires and. Want to make sure they wear in properly!
aparke4 is offline
post #10 of 70 Old 03-28-2014, 10:43 AM
Tonellin
Very good writeup...thanks for taking time to shoot some pictures
I think I saw something similar written up by Jerry or stu maybe? Not as comprehensive and detailed as this writeup though
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #11 of 70 Old 03-28-2014, 10:46 AM
mike_dippert
mike_dippert's Avatar
I drilled holes in my bars and tighten them down on the lugs with spacers to clear the hub. Easy to get level and keep centered. I check it every time I rotate. It takes maybe 10 extra minutes.
mike_dippert is offline
post #12 of 70 Old 03-28-2014, 01:53 PM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
I use the tire seam method,don't even lift the Jeep and never had any wear problems, robncar.I'm too lazy to remove my tires to do your nice alignment as long as my tires wear evenly.Really nice write-up though. Moderators put it in the sticky!
TheBoogieman is offline
post #13 of 70 Old 03-28-2014, 02:43 PM
4xfiend
4xfiend's Avatar
Then it will never get read.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | Poison Spyder BFH rear bumper | Rokmen Mercenary rockers |
Originally Posted by Jerry Bransford
I DON'T FRIGGIN' CARE!!!
Originally Posted by Jim M
Please keep the facts to yourself; nobody here wants to hear them. This was a perfectly good internet argument until you came along with anecdotal evidence.
4xfiend is offline
post #14 of 70 Old 03-28-2014, 03:07 PM
Terrain Twister
Robncar,
I'm assuming your pulling both measurements roughly 17-1/2" from the center of the hub?
At that point where it's too much to list!
Terrain Twister is offline
post #15 of 70 Old 03-28-2014, 04:09 PM
jeepwrangler97
Nice write-up
I use some aluminum I bought from home depot & hop back & forth with one tape measure
Measuring off the tread seems like it'd be way harder/less accurate....at least for me
Sent by a messenger bird
jeepwrangler97 is offline
