Distributor to ignition rail swap? - JeepForum.com
post #1 of 7 Old 07-01-2010, 02:28 PM Thread Starter
schlik
2010 JK Wrangler
Iíve been out of the jeep game for a few months, and Iím looking to get back in (withdrawal sucks!). Iím pretty dead set on another tj, but most of the ones in my price range have are older and have the distributor set up. Iíve personally seen a distributor take on mud and water and die. My question is is it possible to convert the distributor set up to a rail set up? And how hard is it?
schlik is offline
post #2 of 7 Old 07-01-2010, 02:41 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I think it would be a bit of a PITA, though I have never done or tried this.
You would need a different PCM and wiring harness at the minimum.
Wheelin98TJ is offline
post #3 of 7 Old 07-01-2010, 02:48 PM
mdm
Farm Wheeler
There are bosses cast/machined on the newer heads for the bolts that hold the coil rail down.
I've seen a coil rail TJ take on water and hydro lock. Possible solution? Stay out of deep water/mud? If you are doing something that can drown a distributor, you're doing something that can feed water down the intake.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 7 Old 07-01-2010, 03:36 PM
DevilDogDoc
Its funny that Jeep didnt think of that when the set that distributor so low, I had and old pathfinder that had it on top of the engine and it came with a nifty rubber cover on it from the factory that snapped together at the bottom, if I could get one like that for the TJ I would buy one in a minute for the peace of mind.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #5 of 7 Old 07-02-2010, 12:24 AM Thread Starter
schlik
2010 JK Wrangler
hmmm i guess I'll just have to be carefull, Thanks guys
schlik is offline
post #6 of 7 Old 07-02-2010, 10:09 AM
hatfield44
A little RTV on the cap and mating surface can help.
hatfield44 is offline
post #7 of 7 Old 07-02-2010, 10:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Or just apply dielectric grease around the seating edge of an unworn distributor cap where it seats. Worn distributor caps that let water and especially mud inside in are really less of a design problem and more of a lack of maintenance issue. It would be darned hard for mud or water to get underneath a properly fitting distributor cap in normal conditions.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
rail swap , ignition , distributor , tj , wrangler
TJ ignition coil rail on a yj?? jogreen YJ Wrangler Technical Forum 2 05-21-2009 03:57 PM
ignition coil/rail assembly, I need a high performance one sawick420 TJ Wrangler Technical Forum 20 08-28-2008 12:58 AM
2001+ Ignition Coil Rail Upgrade... Unscathed TJ Wrangler Technical Forum 4 01-05-2008 04:42 PM
Ignition rail problems Rebelleber TJ Wrangler Technical Forum 3 01-04-2008 02:49 PM
ignition rail on the '04 Wulf711 TJ Wrangler Technical Forum 6 11-02-2004 07:57 PM
