disengaged clutch noisy? - JeepForum.com
post #1 of 10 Old 01-14-2008, 10:03 PM Thread Starter
RSLary
2002 sahara 5spd. When out of gear and clutch is out its a bit noisy.
Not always, just sometimes. Push clutch in, noise gone. I understand what the process is but seems noisier than it should be and its not all the time.
I can depress the clutch once and release and it could be quieter than it was.
a few months ago I had to have the transmision replaced. Was told clutch and related parts all looked good and no need to replace anything.
jeep has about 75,000 miles
RSLary is offline
post #2 of 10 Old 01-14-2008, 10:04 PM
Rocky529
Rocky529's Avatar
It's normal for the AX-5 and NV-3550 manual transmissions... just the sound of your gears spinning.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 10 Old 01-14-2008, 11:12 PM
RamVA
I agree some noise is normal in that situation. If it's unusually loud it could be the bearings on the input shaft of the gearbox. I'm not sure if this happens a lot on Jeeps, but I had that issue on my 2nd Integra. If that is the case it won't hurt anything, it'll just be annoying.
FWIW when your foot is OFF the clutch pedal it is ENGAGED. Disengaged clutch is when the clutch is in (hopefully this makes sense). If it's noisy only when the clutch is disengaged/in, that's most likely the throwout bearing.
1997 Wrangler Sport
RamVA is offline
post #4 of 10 Old 01-15-2008, 11:33 AM Thread Starter
RSLary
Mine is when clutch is engaged, transmision in newtral. Sounds like you would expect but just louder than I think it should be. It has alway been kind of "chattery". If I disengage the clutch and release, it quiets down a little.
Are the gears I hear turning when engaged in the transmision or the clutch?
I recently had the transmision replaced (6 months ago)
RSLary is offline
post #5 of 10 Old 01-15-2008, 01:16 PM
RamVA
IF the clutch is out/engaged, gearbox is in neutral, and vehicle is not moving, then the parts that are moving are basically:
a) motor
b) clutch (both sides)
c) throwout bearing (though not under very much load)
d) transmission input shaft
As stated above, my bet is the bearings on (d), though (c) is a possibility.
Does it get noticably loader when you rev the engine (clutch engaged, gearbox in neutral)?
1997 Wrangler Sport
RamVA is offline
post #6 of 10 Old 01-15-2008, 01:26 PM
djt283
djt283's Avatar
Really depends on how noisy you're talking about. A little "rattle" from inside is normal. Mine has always done that. Using Royal Purple Synchrowhatever quieted it down a lot though.
djt283 is offline
post #7 of 10 Old 01-15-2008, 01:28 PM
RamVA
I should add - if it is in fact the input shaft to the gearbox making the noise, then it's probably not going to hurt anything if you don't do anything about it.
1997 Wrangler Sport
RamVA is offline
post #8 of 10 Old 01-15-2008, 01:29 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
Consider it a "Jeep Thing"
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #9 of 10 Old 01-15-2008, 04:51 PM
mmtphoto
I own and have owned a lot of stick shifts-suspect the throwout bearing, if you gently rest your foot on the clutch pedal and it changes, that's it.
mmtphoto is offline
post #10 of 10 Old 01-26-2008, 11:41 AM Thread Starter
RSLary
I just gave it a listen again. When clutch is engaged and trans in neutral it has a bold ticking noise. Sounds like playing cards in the spokes of your bike. Increaseing engine rps, increases volocity of noise. If I disengage the clutch to any degree and engage again it goes away. This process repeated will somtimes bring the noise back sometimes not. But it will always return on 2 or 3 attempts. Letting the clutch out easy decreases the chances of the noise returning. Letting out the clutch quickly, increases the chances of the noise returning. Seems the more forefully you engage the clutch the higher the degree of noise. Any thoughts?
As I stated in earlier post, I had to have the trans replaced this past summer and I addressed the condion of the clutch and they said all ok. However, the tech working on it was not one of the A team and his efforts caused them to have to keep jeep an extra week due to misdiagnosing trans problem. Not really sure on the details, they made it right when they wrote the bill but could this problem be result of any part of them putting it back together?
RSLary is offline
I want to start my Jeep with the clutch disengaged +GRAVES+ TJ Wrangler Technical Forum 45 09-26-2008 12:41 AM
Rattle when clutch disengaged... BucJeeper TJ Wrangler Technical Forum 5 09-13-2006 02:54 PM
Repetitive Clunking When Clutch is Disengaged 97 sahara TJ Wrangler Technical Forum 8 03-25-2006 03:24 PM
ARGH! Clutch pedal disengaged! evilpsych YJ Wrangler Technical Forum 2 01-02-2005 04:06 AM
clutch not disengaged bluegrass YJ Wrangler Technical Forum 1 09-11-2003 10:02 PM
