#1 | |
disconnects front and rear
So I broke my stock front swaybar links again and I'm looking to get some disconnects for the front and rear...
I have an OME 2" lift. Any suggestions on what and where to buy?
#2 | |
Don't bother disconnecting the rear. I don't think you gain that much and it makes it really unstable. Do they even make quick discos for the rear? |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
JKS works well for the front. However, don't disconnect the rear as the TJ's coil spring suspension doesn't do well on or offroad with its rear antiswaybar disconnected. Disco'ing the rear can actually make it a tad more likely to flop or roll on really steep or offcamber terrain.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 |
try northridge 4x4 for buying the JKS quicker discos
http://northridge4x4.com/proddetail.php?prod=JKS-QUICKERDISCO2 |
#5 | ||
Gave me 4-5" off play in the rear and made it more stable on down hill with off camber
2010 4 Door 4x4 JK 06 Durango 20's Quote:
#6 | |
THIS is why you don't see mainstream suspension manufacturers making rear antiswaybar disconnects, because disco'ing the rear antiswaybar is a mistake and shouldn't be done. It's even hard to find Sliders any more because when disco'd, they actually degrade the TJ's suspension performance. And part of the above is just one reason why John Currie WON the US national rock crawling championships with fully connected Antirock front and rear antiswaybars. ![]()
#7 |
Jerry,
I have to disagree on the factory rear bar. It's coat hanger thin with about a 12" lever arm. I'll bet Curries bars were thicker. I've never run a rear sway bar on my TJ, and I'd like a larger then stock one for the front on the street. Pat |
#8 | |
And you need to actually look at Currie's rear antiswaybar, it's purposely a smaller diameter than the front is and about the same diameter to the factory's OE rear antiswaybar. And for the same reason the TJ's OE rear antiswaybar is that diameter, it's an optimal diameter for that location. If you ran the uber-tough rock crawling trails like are out in Johnson Valley Calif., you'd soon see why everyone with a TJ runs rear antiswaybars... and most run Currie Antirocks or Swaylocks up front. Besides, you can't have your cake and eat it too. You complain how the rear antiswaybar is too thin "like a coat hanger", then you choose to run without it entirely. If you feel the rear antiswaybar is too thin to do anything, then why did you bother to remove it? ![]() Don't forget... if disco'ing the rear antiswaybar actually helped, then we'd be seeing rear antiswaybar kits like we do for the front. But we don't because they don't help.
#9 |
I have Teraflex and like them alot. The JKS "Quicker Disconnects" are nice too. I wouldn't worry about the rear swaybar, leave it as is.
2006 TJ Sport 1995 YJ 2007 JK Sahara Unlimited www.GrassRootsJeepClub.com www.GrassRootsJeepClub.proboards80.com |
#10 |
what size
Thanks for the replies.
My ome 2" lift gave me more like 3 inches but it'll probably settle after some miles. Should I go with the 0-2" set? Does everyone with the actually drill holes it the frame for the part that holds the links once you disconnect? Also, what do you guys replace the rear swaybar links with when they break? Should I just get another set of stock links for the rear? |
#11 |
I need to preface this with; I've never wheeled west of the Mississippi River. I regularly wheel Tellico.
On sway bars, First they control body lateral roll in relationship to the horizontal plane of the axle. Sway bars are a torsional spring. Now, when the left rear goes up on a rock. The mechanical direct link connection also goes up. This in turn pushes up on the sway bar lever arm. This force is transmitted or lost depending on the diameter of the bar. greater diameter = greater resistance to twist. Sway bars are mounted in bushings to the chassis to allow them to twist. Ideally these bushings do not hinder motion. Because that is lost energy. Back to the story, We were up on the left rear. This caused the left link to go up and the left end to twist up. remember the bar is designed to go back to flat. So if the left goes up so shall the right. It's not going to go opposite. There for I conclude that the removal of the rear bar A) increases body roll on the street, B) increases flex, C) does not aid in increasing down force on the right rear. I believe Currie won due to keeping the truck flat and stable. My ideal set up for a TJ with 4" lift and 35's would be to have no rear bar and a front bar about 25% stiffer than stock. I can get into a whole thing about roll centers, turn in, corner weight, and weight transfer. But wont. Here are some good resources, http://www.bentleypublishers.com/product.htm?code=H690 http://auto.howstuffworks.com/question432.htm |
#12 | |
#13 |
for the front i have: jks quicker discos
for the rear i have: jks adjustable end links i bought them for the rear because the stock sway bar came that much down while flexing that it had contact to the handbrake lines. btw. your stock TJ had disconnects? i never heared that before.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer 35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA 12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan Jeep TJ Runicon Pics www.timbercrawler.de |
#14 | |
1) Right rear tire is firmly planted. Bar will twist as designed but cannot move up on the right side because bar is anchored by link on the right side. Bar is trying to resist left side moving up. 2) Right rear tire is off of ground. Right side has an opposite component due to unsprung weight on that side. Bar will twist opposite of left side as designed. Bar is still trying to resist left side bump. You present it as if the right side is disconnected or moving with the same bump as the left. Is this your intent? |
#15 | |
2) I see the reverse of the above happening. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
