Disconnected Sway Bar on my new 98 TJ - JeepForum.com
post #1 of 9 Old 04-29-2012, 07:24 AM Thread Starter
TJ98JeremyPrice
Noticed today that my sway bar on my 98 is disconnected and can't figure out how it should go back.. when I push down hard to move it into position it doesn't want to move.. maybe some oil will loosen it.. but I don't see how it bolts on or anything.. looks like a ball and socket type of system.. what holds it down?
TJ98JeremyPrice is offline
post #2 of 9 Old 04-29-2012, 07:27 AM Thread Starter
TJ98JeremyPrice
If you look at my profile picture you can see what I am referring to...
post #3 of 9 Old 04-29-2012, 07:34 AM
MotoSoul
It is hard to tell from such a small picture but that looks like a stock sway bar end. In that case it isn't disconnected as it is broken. You would need to buy a new sway bar end link.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline
post #4 of 9 Old 04-29-2012, 07:38 AM
JEK3
JEK3's Avatar
Larger picture would help. Looks broken to me, as the other end (bottom of the vertical rod) is where it's normally disconnected from. I've never disconnected this end. Here's a pic of mine:
JEK3 is online now
post #5 of 9 Old 04-29-2012, 07:41 AM
JBTJ
It is broken and you need a new one. Is the jeep lifted?
JBTJ is offline
post #6 of 9 Old 04-29-2012, 07:50 AM Thread Starter
TJ98JeremyPrice
Yes it has a 3" lift.. and now that I see the picture above I see how mine is broke. How hard to replace and any suggestions?
post #7 of 9 Old 04-29-2012, 08:07 AM
JBTJ
Easy to replace, but don't get stock ones. You need a pair that will match your lift size.
JBTJ is offline
post #8 of 9 Old 04-29-2012, 08:34 AM Thread Starter
TJ98JeremyPrice
Can I just replace the disconnect links or since they are stock will I need to/would it be better to replace the entire thing?
post #9 of 9 Old 04-29-2012, 09:32 AM
JBTJ
You only need to replace the links, that is what's broken. The sway bar is fine.
JBTJ is offline
Sway bar disconnected Vin0363 TJ Wrangler Technical Forum 20 08-02-2011 10:32 AM
What to do with sway bar once disconnected? KelownaKen JK Wrangler Technical Forum 13 02-01-2010 04:41 PM
Can you actually see that sway bar is disconnected? VA_Rubi-Red JK Wrangler Technical Forum 4 08-05-2008 11:36 AM
no sway bar and disconnected? Jakesteads YJ Wrangler Technical Forum 11 08-18-2006 10:51 PM
disconnected sway bar? CF YJ Wrangler Technical Forum 7 12-10-2001 10:37 PM
