Disable the SKIM (Sentry Key Immobilizer Module) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Disable the SKIM (Sentry Key Immobilizer Module)
Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock
Unread 03-09-2008, 05:56 PM   #1
Benny2Times
Does anyone know how to do this? I want to be able to get new keys without having to pay $120 for the transponder grey ones.
Benny2Times is offline   Reply With Quote
Unread 03-09-2008, 06:13 PM   #2
Benny2Times
I had lost my original Key, and it cost me $120 to get one key. I was thinking it would really suck to lose it again and I would like to have a spare.
Unread 03-09-2008, 06:25 PM   #3
stangman68inftc
I do not have this in my Jeep, however, I have heard of people taping a key (or just the fob for safety purposes) under the dash. Then they can use a key without a chip because the other one with the chip is already close enough.
Colorado Jeep Club member #87
stangman68inftc is offline   Reply With Quote
Unread 03-09-2008, 06:41 PM   #4
Benny2Times
Yeah but if it comes off while crawling, my rig would die, or even worse while driving down the express way.
Unread 03-09-2008, 07:20 PM   #5
Benny2Times
Yes, the grey is the transponder key. From the dealership I was told it will cost $60 for the key and $60 for the programming, plus you have to get your rig towed to the dealership. My girlfriend has AAA and we got a guy to come to my house. Her AAA plan covers $100 dollars of the cost, but the guy that came to my house charged $175 total, so I had to pay $75. It only took him 10 min and he told me that the cost for the actual key is $30.
Unread 03-09-2008, 07:33 PM   #6
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Buy the key from eBay for about $10-12. Have it cut at a locksmith for $3. Then you can program it in your rig with two original transponder keys you have.
2009 JK Rubicon (Daily Driver).
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta
Thunderstrike is offline   Reply With Quote
Unread 03-09-2008, 07:36 PM   #7
Benny2Times
I would, but I only have 1 key now since my girl lost my only set. And that cost me $75.
Unread 03-09-2008, 07:50 PM   #8
lockdoc
eliminate need for expensive keys
Greetings,
I offer this up as a simple solution only because I have done this to my 99 Sahara. Carefully remove the rubber portion of the key. Once removed you will find a white plastic holder with a transponder held in it. Remove the chip from the holder and glue it to the inside part of the shroud in real close proximity to the transponder antenna that surrounds the front part of the lock cylinder. It is a good idea to try random placings of the chip before making its new position permanent. You can now just use regular flat metal keys that are dirt cheap and I also like their small flat size, just right for a spare in your wallet. Responding to a comment made earlier on this topic, once started the vehicle will remain started even if the transponder is removed. However once turned off,the vehicle will not restart until the transponder is placed back in range of the antenna. One other thing to consider before doing this is insurance issues in the event your jeep is stolen.
lockdoc is offline   Reply With Quote
Unread 05-28-2008, 12:23 PM   #9
mill500
I've got the same thing going on with my 99 TJ. I've tried the 2nd key, it doesn't do anything either. Would this still indicate a bad key or a bad reciever/antenna?
One idea I was playing with was on my '04 Ram, I added the same system (it didn't come as OE). I had to re-program the computer with a DRBIII so it knew to wait for the acknowledgment to come back. I'm wondering if you could just "unprogram" the computer so it doesn't look for the chip and then shut down. I'm not all that excited with putting much $ into the fix.
mill500 is offline   Reply With Quote
Unread 05-28-2008, 01:28 PM   #10
BlueFlame
Based on the info in the many threads here, I would think that you could have a dealer to turn off the Sentry Key function. Could be wrong, but if you can add the column portion to a jeep that doesn't have it, then have it activated (the prgramming is already in all the computers) seems logical you could have it deactivated just as easily.
BlueFlame is offline   Reply With Quote
Unread 05-28-2008, 02:00 PM   #11
spyder6
Diddy Did It
spyder6's Avatar
it dosnt work, atleast how i tried it. Its not an RF signal for all i know, i think it actually travels through the metal of the key
'12 Jeep Wrangler Unlimited Rubicon | sPOD4x4 | SprintBooster | AEV | AFE | EVO | Aeroforce | HotHeadz | Cobra | Firestik | Currie | Nth° | ROKMEN | Poison Spyder | Motive Gear | Trucklite | DynaTrac | MOPAR | BILSTEIN | Eibach | Trasharoo | GOESKE | Synergy | WARN | Spydura | OR-FAB | Artec | Nemesis | RIGID | Black Diamond | PowerTank | Mav02 | SpringTail |
Bruiser Build
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote
Unread 05-28-2008, 02:31 PM   #12
2jhanna
x2 on the above
If you currently have 2 keys, you can and should do it yourself (before you lose a key). I bought one from ebay also, guy at Lowe's cut it for me free. Procedure to program is in the owners manual, plus an instruction sheet came with the new key.
http://cgi.ebay.com/ebaymotors/1998-...spagenameZWDVW
If you only have 1 key, you have to pay up, either at the dealer or locksmith (with a program module).
I have also heard that having the "key fob" in close proximity will allow a non sentry key work.
There is a thread that explains how the system checks for a valid key on this forum.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread 05-28-2008, 03:56 PM   #13
mrblaine
mrblaine's Avatar
The SKIM function is in all the ECM's. The only difference is it's either activated or not. Once activated, it can not be circumvented, deleted or turned off in the computer.
If you wish to have that done in the ECM, you have two choices. Either buy another ECM that doesn't have the SKIM function activated, or return the ECM to the Factory who will then return it to the vendor for reprogramming.
There are some work arounds for using the non Sentry keys that have been listed in this thread, but that's about it as far as deactivation of the function goes.
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote
Unread 05-28-2008, 04:11 PM   #14
JMayer
It's ridiculous to think that a dealership actually has the nuts to charge $120 for a $10 key and 5 minutes in their own parking lot. I was relieved that my local dealership told me they charge $40 for the key and the programming was no charge, and even then, that's $40 for a freakin' key. I know this post isn't helpful, but sometimes you just have to express amazement...
JMayer is offline   Reply With Quote
Unread 05-28-2008, 04:12 PM   #15
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Seems like it's not worth it to me. If it helps stop theft, leave it. You learned your lesson & got ripped by your dealer once... now you know you can get them cheaper and you can program it yourself... and you'll probably be more careful about losing your key now.
Just because you can buy a skim key on ebay for $10 doesn't mean that's what the dealer pays. The factory key (the one that says "Jeep" on it) has a list price of $50 from Chrysler. The dealer pays quite a bit more than $10 for that key. Some dealers also carry aftermarket sentry keys, but I can tell you that we pay more than $10 from our distributors for those as well.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
