dipstick broken in dipstick tube - JeepForum.com
post #1 of 24 Old 09-24-2009, 09:07 AM Thread Starter
1CleanTJ
1CleanTJ's Avatar
so my oil dipstick's plastic handle broke off while removing my battery as it hit it. it looks like the dipstick tube is pressed into the oil pan. is there an easy way to remove it or does the dipstick tube come off/on ? Dont like having no way to check oil level. the plastic is to far down into the tube to get with needle nose , its like 1.5" down at least from trying to get it out
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #2 of 24 Old 09-24-2009, 09:17 AM
jmasin
How about a small magnet on a string (i.e. what you'd use to fish out screws)?
You may have to shove it down there but maybe you can pull it out that way?
Of course that may be a completely idiotic idea because I guess I'm not really sure what the stick is made of...
'03 Sport, Patriot Blue
'04 C5 Corvette
jmasin is offline
post #3 of 24 Old 09-24-2009, 09:23 AM
Fropleyqk
Fropleyqk's Avatar
Thats what I was going to say.
If not magnetic get a scribe.
Fropleyqk is offline
post #4 of 24 Old 09-24-2009, 09:24 AM
Fropleyqk
Fropleyqk's Avatar
Actually, maybe a stupid idea but Id take a vacuum hose and try to suck it out. Couldnt hurt.
post #5 of 24 Old 09-24-2009, 09:27 AM
hockeyplayer21
i replaced the 4-cyl motor in my jeep and the used engine's dipstick was broken off in the tube, and the only way i could get it out was by taking off the oil pan and pushing it out. i tried everything, drilling a small hole and putting a screw in it, i'm sure there are other ways, but in the end i ended up taking the oil pan out
hockeyplayer21 is offline
post #6 of 24 Old 09-24-2009, 09:34 AM
rainmn
I broke mine while changing plugs, although when mine broke, the plastic piece left on the dipstick was almost flush with the end of the dipstick tube. Not sure how yours broke off so far down, so this may or may not work.
I searched a bunch of threads here for advice, and this is what worked for me. (Assuming you still have some plastic left on the dipstick.)
Take a small pair of vice grips, and gently squeeze the dipstick tube where the remaining plastic is on the dipstick. This will help prevent you from pushing it in even further.
For the next piece, I used a small curved pick from a Snap-on set I have. I heated the pick with a torch until it was glowing orange, then quickly stuck it into the plastic left on the dipstick and held it there.
After it cooled for a minute, I was able to release the vice grips and pull the dipstick right out.
rainmn is offline
post #7 of 24 Old 09-24-2009, 09:41 AM
mdm
Farm Wheeler
If you can't get a grip on what's left of the stick remove the bolt from the tab on the dip stick tube, pull tube from block, remove broken stick, reinsert tube into block, reinstall bolt, install new dip stick, and have a happy day.
Why remove the pan?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #8 of 24 Old 09-24-2009, 09:45 AM
gmiller0737
Easy solution ,I have removed several using the following method, Get a small pocket screwdriver heat the tip cherry red with a torch while it's cherry red gently push it in to the broken plastic letting it melt it's way in, Hold it still till cool then remove broken dipstick a piece of coat hanger may work if you don't have a small screwdriver.
gmiller0737 is offline
post #9 of 24 Old 09-24-2009, 10:20 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Why remove the pan?
It's done exactly like he stated.
GOLENJEEPTJ is offline
post #10 of 24 Old 09-24-2009, 10:31 AM
hockeyplayer21
Why remove the pan?
i needed to remove the pan because the pan on the used engine was rusted and dented so i swapped pans from my old motor. it was just convenient at the time.
post #11 of 24 Old 09-24-2009, 10:39 AM
klimb2xs
LOL! Mine broke earlier this year while doing an oil change. I got lucky because mine broke when I pulled it out to check the oil before I started. I just put some electrical tape around what was remaining to keep it from getting pushed down the tube.
What is everyone doing for a replacement dipstick? OEM or aftermarket?
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
post #12 of 24 Old 09-24-2009, 10:45 AM
mdm
Farm Wheeler
Removing the broken dip stick while you replaced the oil pan made since in this case.
However,
this made it sound like the only way to get the broken stick out was to remove the oil pan. I'd hate for someone with a broken dip stick to walk away from this thread and pull his oil pan off because he thought that was the only way to get the broken stick out of the tube.
mdm is offline
post #13 of 24 Old 09-24-2009, 10:50 AM
rainmn
Bought an OEM one from Jeepsrus. It was about 8 bucks.
rainmn is offline
post #14 of 24 Old 09-24-2009, 11:10 AM
vincec
I think the tube is held on with a bolt remove the bolt remove the tube remove broken piece rfinstall all done
vincec is offline
post #15 of 24 Old 09-24-2009, 11:35 AM
kswyg001
2010 JK Wrangler
according to a post by JerryBransford (about a month ago) the oil dipstick tube does come off. ill try and find the post
kswyg001 is offline
broken oil dipstick.... mpv1608 TJ Wrangler Technical Forum 5 08-15-2009 03:01 PM
Need a 2.4L dipstick tube McLovin TJ Wrangler Technical Forum 4 05-31-2008 09:20 PM
Oil Dipstick Tube... Greatwhite007 YJ Wrangler Technical Forum 1 12-23-2006 07:09 PM
Oil from dipstick tube jmhat98 YJ Wrangler Technical Forum 13 05-04-2006 07:53 PM
How do I remove the oil dipstick tube? korell TJ Wrangler Technical Forum 2 03-13-2005 05:56 PM
