Difficulty To Install Cruise On Non-Cruise Jeep? - JeepForum.com
post #1 of 34 Old 04-21-2009, 12:17 PM Thread Starter
rastaangel
Well, need less to say i have had to do alot of highway driving with my jeep lately and not having cruise is starting to bug me... How hard would it be to install a OEM or aftermarket cruise system on my 05?
rastaangel is offline
post #2 of 34 Old 04-21-2009, 12:19 PM
Rocky529
Rocky529's Avatar
You may or may not be pre-wired.... if you are pre-wired, it is just plug and play. If not, you have to wire in the harness that comes with the kit. You can purchase it off www.jeepsareus.com. If you are careful and take your time, you can do it in an afternoon. Comes with detailed instructions.. but the price recently went up because the TJ is no longer in production.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 34 Old 04-21-2009, 12:19 PM
NotURMailman
NotURMailman's Avatar
the OEM kit from Jeep is a breeze! And only a little over $200. Mine took me 30minutes and that included opening the box and cleaning up.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 34 Old 04-21-2009, 12:20 PM
NotURMailman
Yeah, what he said... I was pre-wired. Installing the new harness will add from 1-3 hours depending on your level of electrical experience etc...
post #5 of 34 Old 04-21-2009, 12:23 PM
jayhawkrichie
How can I tell if mine is pre-wired?
jayhawkrichie is offline
post #6 of 34 Old 04-21-2009, 12:25 PM
NotURMailman
There will be a large plug next to the vacuum canister on (your) driver's side fender. Even if you're not wired, it's plug and play (just more time consuming).
post #7 of 34 Old 04-21-2009, 12:48 PM
blackattak
Where do you get the parts- dealership? This is the 1st vehicle I have had in 20 yrs without cc sp would like it.
2004 LJ- 33X12.5 Mickey MTZs, Mickey Classic II wheels, 4.88 Yukon Gears, 3" BDS SL, Rockhard Rear Bumper with Tire Carrier & Rockers. Oil Pan, Warn Gas Tank Skid. & Differentials armoured, Iggee Seat Covers, Warn M8000 winch.AEV TT & tranny skid, radiator & steering box skids
blackattak is offline
post #8 of 34 Old 04-21-2009, 12:49 PM
NotURMailman
Like someone said above www.jeepsareus.com or the dealer. I showed my dealer the add at jeepsareus and he matched the price.
post #9 of 34 Old 04-21-2009, 01:15 PM
MisterO
Don't mean to hijack, but I was just about to ask the same question just different year.
I have a 97 manual transmission and was wondering if the same info as above applies to me??
My right leg is gettin real tired on long trips...
Thanks in advance.
MisterO is offline
post #10 of 34 Old 04-21-2009, 01:16 PM
NotURMailman
Install should be basically the same. The kit might be a different part number.
post #11 of 34 Old 04-21-2009, 01:35 PM
TravisHeim
Thanks in advance.
I was wondering about this too, I don't think cruise control was even available on the 97 models.
TravisHeim is offline
post #12 of 34 Old 04-21-2009, 01:37 PM
NotURMailman
Hmm... well then I suppose you will have to see if Jeep makes a kit for it or not.
post #13 of 34 Old 04-21-2009, 02:40 PM
cartwright27
pic?
does anybody have a pic of this plug so i can see if mine is prewired or not? i've been wanting to install cruise too.
cartwright27 is offline
post #14 of 34 Old 04-21-2009, 02:48 PM
Sccafire
This is from an 05 Rubicon with the 4.0. The pigtail you see is for the cruise control and located on the drivers side fender.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #15 of 34 Old 04-21-2009, 03:05 PM
R1Blueboy
I did the very kit from jeepsrus.. Mine wasn't pre-wired so the install was like 4 hrs.. You will have to unplug the grey connector on you're computer on the ps firewall and insert 5 new wires I think.. Been like 3.5 years since i did mine! Be carefull on that step and take you're time on the insertion of the wires and make sure they are seated where they need to be, and make sure the lightblue locking tab has them in place firmly enough.. Couple of the wires did that to me after 5mos of having it.. My mistake, and corrected, haven't had anymore problems!!! Pm me if you have any more Q's..
R1Blueboy is offline
cruise control install on RHD TJ NotURMailman TJ Wrangler Technical Forum 15 03-26-2009 12:15 PM
What would I need to install Cruise? dbshea TJ Wrangler Technical Forum 5 01-05-2009 02:22 PM
Cruise install in an '06?? bbredstang TJ Wrangler Technical Forum 3 05-18-2006 08:35 AM
97 Cruise Install geauxturbo TJ Wrangler Technical Forum 6 04-11-2005 08:42 AM
Ever install OEM Cruise On a 99 TJ? Drew99 TJ Wrangler Technical Forum 12 06-02-2004 06:29 AM
