difficult shifting from 1st-2nd - JeepForum.com
post #1 of 7 Old 11-30-2006, 11:47 PM Thread Starter
langston.4
i have a 2000 tj with 4'' suspension lift and 2 '' body lift and 35s. when i first got it there was no shift boot and everything ran/shifted just fine, although it looked like crap. i found one and put it in, and it hasnt caused any problems, however shifting from 1st to 2nd is difficult sometimes. it will grind in, or pop out sometimes, and only smoothly shifts in if i have the perfect angle. i have to pull real hard back and to the inside left(5speed, nv3550). downshifting from 3rd to 2nd is no prob at all very smooth. im assuming it has to do with the body lift obviously. so to correct the problem should i get a shifter extension, replace the whole thing with a longer shifter, or get a performace short throw shifter? any ideas, thanks alot
langston.4 is offline
post #2 of 7 Old 12-01-2006, 12:26 AM
blacktj27
blacktj27's Avatar
I have a 1.25" BL 1"MML and a 3.5 suspension lift and I had the same problem. I ordered a black universal shifter boot from JCWitney and put it on the stock ring. That solved my problem. The issue you are having is that the rubber shift boot is bunching up when you shift into second and causing too much stress on it. If you replace it with a cloth or leather universal boot it will not bunch up like the rubber one. That is why there wasnt a shift boot on there before.
04 TJ Sport (Black)
AFW front bumper, ARB snorkel,
windshild mount KC Daylighters,
dana 44, 3.73 gearing, KC fogs,
RE3.5, 32x11.5 Kuhmo MTs,
KC backup lights, PSC diff. guard,
LoD bumper/tire carrier,
1"MORE MML, 1.25" JKS BL,
Pioneer AVIC-N2, Ultimate Air,
Novak T-case shifter, Warn 9.5ti,
PSC dana 44 bomb shell
blacktj27 is offline
post #3 of 7 Old 12-01-2006, 10:08 AM
vector6
thats why the boot was removed...
I did the same thing to mine... but the no boot look doesnt bother me.
vector6 is offline
post #4 of 7 Old 12-01-2006, 10:39 AM
idgit0488
What type of boot did you put in? The stock boot? Is it rubber? I know a lot of people swap in an 05-06 shift boot that is a leather type material and seems to help that problem
I'm not an urban cowboy, I'm a country plowboy.
idgit0488 is offline
post #5 of 7 Old 12-01-2006, 02:37 PM
jfm_nbpt
2010 JK Wrangler
wow. whoever figured this one out saved me some coin. I just bought (bargain of the century) an '01 Sahara that is absolutely mint. My only concern was second gear. Popped the boot and problem went away! BTW rotating the ring 180 degrees and snapping it back in also helps.
jfm_nbpt is offline
post #6 of 7 Old 12-01-2006, 03:35 PM
SecondTJ
SecondTJ's Avatar
yep, shouldve left the boot off
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #7 of 7 Old 12-01-2006, 03:58 PM Thread Starter
langston.4
thanks alot
need help please (manual tranny shifting difficult when cold) chafalote TJ Wrangler Technical Forum 24 02-01-2016 07:31 PM
Spongy clutch/difficult shifting rob1525 TJ Wrangler Technical Forum 5 10-31-2009 07:37 AM
NP231 Shifting OUT of 4 Lo VERY Difficult Jim93YJ YJ Wrangler Technical Forum 7 04-03-2008 03:23 PM
Shifting different when cold or warm -final attempt at shifting problem. IAJack TJ Wrangler Technical Forum 12 01-20-2005 08:51 PM
difficult shifting nomad6 TJ Wrangler Technical Forum 3 01-09-2005 03:16 PM
